Will she succeed…
Discussion in 'Airheads' started by Beam(st)er, Aug 10, 2014.
  1. Beam(st)er
    Beam(st)er Miss Adventurer
    Mar 26, 2012
    245
    Netherlands
    Hi all,
    For offroad traveling I've been using a G650X Country for a few years now.
    Although there's nothing wrong with that bike and it's probably the best bike for the sort of trips I like to do, it doesn't make me smile like my R80 mono does.
    That's why I decided to gain some weight, loose some ground clearance, use and carry a lot more fuel by replacing the X Country for a R80G/S.
    So I bought this…
    I think it looks :cry
    but now the question is will I succeed to build it into something beautiful to replace my X Country…
    The idea is to:
    service the engine including some tuning
    replace bearings and seals in the gear box and final drive
    lower the foot pegs
    replace the rims for excel's
    improve the front brake
    improve the suspension
    replace the exhaust system
    powder coat and paint everything
    and trying to create most of the stock G/S looks again
    jackd likes this.
  2. nick949eldo
    nick949eldo Long timer
    Jan 31, 2010
    2,129
    Inverary, Ontario, Canada
    Just ride it. It looks perfect as is.
    Nick
  3. mark1305
    mark1305 Old Enough To Know Better Supporter
    Feb 7, 2005
    6,709
    Merritt Island, FL
    Agreed, it has good patina and still the mostly stock look you want. That muffler doesn't spoil the effect at all. I'd say don't change much at all and put the money in the mechanicals, maybe upgrade the front with Racetech emulators to start, and do the basic engine tuning, clean every electrical connector on the whole bike and apply dialectric grease in them.
    Personally, I don't go for big front brake upgrades if its a dual sport bike like my F650 (which I have even used at Barber and Road ATL while dabbling as a track instructor). I go as far as getting the best pad/rotor combo so the brakes won't fade but won't be too sensitive in the loose stuff. But each to their own in braking preferences.
    Nice bike BTW.
  4. SpikeC
    SpikeC Been here awhile
    Sep 30, 2013
    383
    PDX
    I wish I had more garage space. I would love to have that bike just like it is!
  5. Mark Manley
    Mark Manley Long timer
    Apr 3, 2010
    2,424
    Wessex, England
    If you are looking for standard parts don't forget to give BMW a try, some are no longer available new but others are and the price can be surprising, I recently bought a new rear mudguard for my R80G/S from my local dealer here in the UK and it was £70 or just over $100. Also keep and eye on Motorworks and Motobins who both occasionally still break a G/S or an ST.
  6. Beater
    Beater The Bavarian Butcher
    Sep 3, 2009
    3,708
    Atlanta, GA, USA
    BRAVO.
    A quick question, you are going to replace and re-lace the rear rim? It's a standard 40 hole type? Excell Rim? Which one are you going to get? Can you post a linky?
  7. Thorazine
    Thorazine Likes exhaust fumes
    Sep 1, 2013
    1,467
    Lanesplittin Valhalla--Southern California
    Nick's right. This is a motorcycle, not a piece of jewelry. Fix what keeps it from riding at its best, then go ride.
    BTW, the bike looks as happy as you do--now get back on it and keep your eyes on the road/path, dammit.
  8. Beam(st)er
    Mar 26, 2012
    245
    Netherlands
    It might look ok on the pictures but if you would see it up close it looks like a mess.
    I think the fender is too long compared to the length of the swingarm.
    If I would leave this muffler on it will cure itself, because it's mounted like a chimney and it melts the plastic :rofl
    The fork that's in the bike now is already a lot better than a stock G/S fork, but before I made my decision to buy a G/S I have been riding at least ten different ones.
    The ones with a fork upgrade felt SO MUCH better and safer.
    I've been riding a few bikes with the gold valves and they were ok but I'm used to forks with a better damping system.
    You're right about the brakes but I'm replacing the front wheel and brake because it weights a ton and doesn't fit in my new fork.
    When I bought the bike it had a master cylinder which was way too big for the caliper, so I need to change it anyway.
    #8
  9. Beam(st)er
    Mar 26, 2012
    245
    Netherlands
    Thanks for the advice Mark.
    I always check the dealer prices first because I prefer original parts.
    Some parts I try to find second hand, like the rear frame.
    I found two on eBay but unfortunately that didn't work out…
    #9
  10. Padmei
    Padmei enamoured
    Mar 12, 2008
    4,114
    Nelson New Zealand
    Is that a DR Big seat & guard?
    Someone had a pretty eclectic parts supply.
    have fun with it!
    #10
  11. Beam(st)er
    Mar 26, 2012
    245
    Netherlands
    I'm going to replace the rear rim for an Excel 2.50"18 laced to the stock hub.
    I've just sent the hub to Haan Wheels and they'll take care of the rest.
    Sorry I don't have a link.
    #11
  12. Beam(st)er
    Mar 26, 2012
    245
    Netherlands
    I own the bike for a little more than one week now and this is what I've done the day after I bought it…
    A few hours later…
    Again a few hours later…
    At the end of the day :evil
    #12
  13. Beam(st)er
    Mar 26, 2012
    245
    Netherlands
    On the sort of trips I would like to make (Mongolia, Russia) with this bike, I don't like to run into trouble because of things like this.
    On both sides they used 800 head gaskets… but the bike has a 1988 R100 engine.
    #13
  14. hardwaregrrl
    hardwaregrrl Can't shoot straight Supporter
    Jan 26, 2006
    9,973
    Atlanta
    You guys don't get it......this is Prutsers better half. The last thing she will do is leave the bike alone!:lol3
    @Linda.....don't forget to list your G/S here Will you be bracing the frame as Bas did to the ST???
    #14
  15. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    4,706
    Fort Collins, CO
    Beam(st)er, what kind or brand is the boxes (and where do you get them)you use for storing your engine parts? I always keep everything separated but in good old cardboard, needless to say they don't hold up long.
    #15
  16. Ben Carufel
    Ben Carufel Boxer Addict
    Dec 2, 2010
    1,041
    San Diego
    #16
  17. Airhead Wrangler
    Airhead Wrangler Long timer Supporter
    Mar 4, 2008
    7,275
    Back in Seattle, FINALLY
    Yeah I think she knows somebody that works there. :D
    #17
  18. jellycow
    jellycow NX NX NX NX NX NX NX NX NX
    May 29, 2005
    1,513
    South side of the Netherlands
    For some reason I like the look of that rearend. What is it from and are you going to use it or replace by something more OEM?
    #18
  19. Beam(st)er
    Mar 26, 2012
    245
    Netherlands
    I won't forget, I'll register the bike when it's done.
    I will take the risk without the bracing because I'm not going to make it higher than stock.
    The boxes are made by Engels
    http://www.engels.eu
    It's a custom made rear frame which bolts straight on to the main frame and all the plastic parts say KTM on the inside.
    I'm not going to use it, I really like the original looks so that's what I'm aiming for.
    #19
  20. WVhillbilly
    WVhillbilly Long timer
    Oct 20, 2010
    39,802
    WV
    All is have is :lurk
    #20
