Will these light mounts work on F700GS (meant for 800)
Discussion in 'Parallel Universe' started by mosey.levy, Mar 21, 2015.
  1. mosey.levy
    mosey.levy Long timer
    Jul 13, 2013
    2,515
    NYC
  2. mosey.levy
    Jul 13, 2013
    2,515
    NYC
    From twisted throttle (great guys)
    "We have not tested it on an F700 however when I look at the parts fiche I see that everything seems to line up.
    If you wanted to try it I would be willing to take them back if they do not fit.
    Please save this email for reference if you decide to do so #xxxxx as our policy normally does not allow installed parts to be returned.
    Cheers,
    and let me know how you make out, or what you decide. "
  3. nvklr
    nvklr Been here awhile
    Jul 11, 2008
    851
    Carson City
    :lurk
  4. Captain Excellent
    Captain Excellent Stay weird, or you'll be normal like everyone else
    Sep 25, 2011
    1,005
    North Vancouver, BC
    Funny this question comes up today. I was just meeting up with another inmate this afternoon to check out some farkles on his F700. I have the BMW mounts on a '13 F800GS with Denali D2s installed.
    From what I could see the chassis is the same, however the plastic faring wraps in tighter than on the F8 meaning that the end of the arm would be restricted. We didn't take measurements, so nothing is for sure.
    As an aside, we also noticed that the radiator is smaller, which allows for narrower plastics. Strange given its the same engine.
    I'd recommend taking up that Twisted Throttle offer. That's the best way to know for sure.
  5. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,189
    Lanark County near Ottawa ON
    The explanation for the larger radiator on the F800GS that I read somewhere is that it was anticipated that it would be more likely to be used in sustained low speed off road situations than the F650/700GS and thus needed the extra cooling capacity.
    Mike
  6. JRP
    JRP Old guy Supporter
    Apr 4, 2004
    1,616
    Hampden, MA
    This is where I put them on my F650..same as the F 700
  7. mosey.levy
    Jul 13, 2013
    2,515
    NYC
    Yah I was thinking about that placement. If I can't get it to work by the radiator then that's my next goto spot.
  8. J&K
    J&K Been here awhile
    Feb 20, 2013
    413
    Wasilla Ak
    Those lights up that high no one can see your blinkers. That light is to intense for oncoming traffic to see the blinkers. Imo
    #8
  9. Excite-Bike
    Excite-Bike Been here awhile
    Jun 5, 2011
    216
    San Francisco, CA
    So did you try it? Did they work?
    #9
  10. Dorito
    Dorito Dreamer and Doer
    Jul 31, 2010
    7,612
    Maryland
    #10
  11. mosey.levy
    Jul 13, 2013
    2,515
    NYC
    I got them to work by reversing them. So they work now but when you turn full lock a piece of plastic shrowd bumps over the mount each time making a plastic noise. Not ideal but it works and I like where they are.
    #11
  12. zero war
    zero war Zee
    Oct 14, 2009
    524
    North Bergen, NJ
    Any chance you took some pictures to show what they look like? Preferably with the lights off
    Zee
    2000 Triumph Thunderbird Sport
    2015 BMW F700GS
    #12
  13. gtiguy
    gtiguy Adventurer
    Jul 21, 2014
    26
    I got you Zee,
    I believed I flipped my as well. With my large light I wanted to use here I needed to move the light back so it would clear the forks range of motion. I made a tab to move it back 2 inches. These keep the lights inside and protected from wind drag & keeps a factory appearance. I did have to trim the plastic, its kinda shotty but it works, clears, and I just left it like that. ha.
    hope this helps :)
    cheers. gtiguy
    #13
    Evo35 likes this.
  14. zero war
    zero war Zee
    Oct 14, 2009
    524
    North Bergen, NJ
    Thanks. What's the size of those lights. In diameter I mean. I'm planning to use these as a friend has them on his gs1200 and says he was super surprised with how well they perform for the price. Cant figure out the first picture :(
    Nilight Led Light Bar 2PCS 18w 4" Flood Driving Fog Light Off Road Lights Boat Lights driving lights Led Work Light SUV Jeep Lamp,2 years Warranty https://www.amazon.com/dp/B00IY3YLCI/ref=cm_sw_r_cp_api_a6fhzbMJSSE7T
    Here's a better picture to give you comparable dimensions. I really don't wanna cut or shave any of the plastics.
    LASTLY ANY CHANCE YOU REMEMBER THE SIZE OF THE BOLT THAT FITS THE BRACKET TO HOLD THE LIGHT. I KNOW THIS LIGHT TAKES 5/16" or an 8MM BOLT AND MOST BRACKETS OR CLAMPS TAKE 10mm BOLTS.
    Zee
    2015 BMW F700GS
    #14
    Evo35 likes this.
  15. zero war
    zero war Zee
    Oct 14, 2009
    524
    North Bergen, NJ
    This is the place I was thinking I could add maybe some 20 x 60mm L - brackets so the lights are not too close to the radiator. I'll have to figure out a way that the bracket don't slip out sideways from the C shaped are I'm planning to bolt it to.
    Is this actually where the radiator guard clamps on?
    Zee
    2015 BMW F700GS
    #15
