winch advice?
Discussion in 'Hacks' started by JerryAtrick, Sep 28, 2017.
  1. JerryAtrick
    JerryAtrick Been here awhile
    Feb 17, 2015
    186
    Athens, GA
    New to sidecars...my dual sporting is growing more adventuresome and I'm worried about getting stuck or having to turn around in difficult places. I have zero experience with winches and other recovery tools. A quick survey reveals lots of educational resources re 4WD recovery and I assume most info crosses over. But I wonder if anyone can point me toward sidecar-specific recommendations. For example, the Warn XT17 portable winch for adventure bikes looks perfect (1700 pound capacity and weighs nine pounds) but it doesn't have "power-out," which seems like a really good (and perhaps essential) feature.
    Any winch or other recovery advice is welcome!
  2. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    11,035
    north of seattle
    Bar None, davebig and Kruzof like this.
  3. Strong Bad
    Strong Bad Former World's Foremost Authority
    Oct 29, 2007
    9,060
    Omicron Persei 8
    I have the Warn XT-17 winch which we carried along on the CDR & HOW routes that we did solo in our sidecar. I really like the strap mounting system rather than using a trailer receiver most guys seem to use. The strap allows you to pull from your anchor at obtuse angles from the rig. If you get out and about in areas with few large rocks or trees (common out here in the west) having a shovel and knowledge as to how to build a deadman anchor is important (I personally would use a pannier for my deadman anchor system). A very important accessory to your winch is a snatch block which allows for doubling your pulling power.
    All of that being said, knowing when you are about to get in over your head and turning around BEFORE you need to winch your way out goes a really long way!
    Bar None, TurTal, lnewqban and 6 others like this.
  4. braindead0
    braindead0 Head Fisherman
    Oct 4, 2007
    1,475
    Reno, NV
    I'd bring along a come-along/pow-r-pull for really stuck and a z-rig for lighter duty work. Have a tree saver strap handy as well, for both. If you have room a shovel and camp saw can come in very handy for recovery/trail repair.
    RetiredandRiding likes this.
  5. RetiredandRiding
    RetiredandRiding Retired to Ride
    May 22, 2015
    1,115
    Da Lat, Vietnam
    I was set to pull the trigger on a Warn and now you have me doing more research. Well done!
  6. RetiredandRiding
    May 22, 2015
    1,115
    Da Lat, Vietnam
    At ~64, I'm done with the exertion a come-along requires, even aided by physics. I want a motor.
    The Warn 92000 is about $85 with 2000 lbs capacity--fixed to the rig with a 19.4 lb shipping weight.
    The Warn XT-17 is about $420 with a few extras and 1700 lb capacity and portable, 13+ lbs shipping weight including extras, so say 9 lbs for the winch.
    Is the XT-17 worth the $200+ extra cost (figuring in the extras added to the 92000)? I'm new to this train of thought and would appreciate some guidance and if someone could please point out what it is I may be missing.
  7. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,687
    Your imagination.
    Then add heat and 100 percent humidity.
    Electric all day, every day, for me.
    Warn is a cool winch, but, there are cheaper options. I've used both. If selecting a cheaper option remember to check what gear ratio it uses.
  8. TurTal
    TurTal Been here awhile
    Jul 30, 2015
    796
    With coupon picked one of these up last year for $59.00
    After beating the shit out of it I was so impressed I bought a dozen of them for Christmas presents
    Everybody seems to like theirs
    Not bad for the money even if you burned it up in a year or two
    #8
  9. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    7,195
    Chambers Bay, WA
  10. RetiredandRiding
    May 22, 2015
    1,115
    Da Lat, Vietnam
    What's a good gear ratio?
    #10
  11. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    7,195
    Chambers Bay, WA
    Note Strong Bad's advice above--get a snatch block. [LINK]
    Which means you'll need a D-ring. [LINK]
    And a tree saver. [LINK]
    Here in the Northwest, wire cable turns rusty pretty quick. If you don't mind rust, no problem. If you DO mind rust, get some synthetic winch rope. [LINK]
    #11
    RetiredandRiding and davebig like this.
  12. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,687
    Your imagination.
    198:1 or better. Just like hookers, you get what you pay for.
    Have a look to see what happens to the line pull rating once the layers start feeding back onto the drum. Also, note the current draw.
    #12
    pops and RetiredandRiding like this.
  13. ThePod
    ThePod Adventurer
    Nov 1, 2012
    67
    Portland, OR
    I'm with Turtal on this one. I have the HF 2500 lb winch mounted to my ATV. I use it to drag trees down after I've cut them off at the base. They get caught in the other trees around them. This little winch is a workhorse and has never let me down. The only downside is that it can only be operated from the wireless remote which is no big deal (unless you lose it!).
    #13
    TurTal likes this.
  14. TurTal
    Jul 30, 2015
    796
    Nobody suggested you buy a cheap winch R&R
    The badlands 2500 is a tough little winch for the money...I purposely tried to burn one up and that little puppy survived somehow
    Yes its slow and draws some high amps...they all do
    Unless you're the hardcore off road type the winch wont see much action
    It ends up being mostly eye candy
    But if you really think you need one and want to spend a little more coin the Smittybuilt XRC 4.0 is a solid winch for under $200
    Quick line speed...good amp draw...198:1
    3 stage gearing.....bla bla bla
    If you can afford it go buy an expensive winch and make sure its mounted properly
    Its like 2wd...when you need it and the shit aint to deep and you've got knobbies and you can actually get out then you're glad you had it
    The question really is how often does that happen
    If you're where the roads are shit and it rains all the time a $200 winch is cheap insurance and may lower your stress level a little not having to worry about it
    Hell any winch is good to have if you get stuck....even a $60 one from Harbor Freight
    If you dont want to take a chance on smokin the battery trying to escape with a DC motor than carry a manual winch around with ya
    #14
    pops, lnewqban and RetiredandRiding like this.
  15. RetiredandRiding
    May 22, 2015
    1,115
    Da Lat, Vietnam
    The first 3 are already on my list. And since the weather here in Dalat is very similar to the Pacific Northwest (one of the reasons I’m here), the synthetic line sounds like a good idea too.
    #15
  16. jaydmc
    jaydmc Long timer
    Sep 26, 2008
    1,543
    The Bad lands which's seem to work well, we often use the 3500LB winch, On my own bikes I prefer a WARN 3500 LBS winch with the synthetic cables. I like the synthetic cable a lot more the steel. I go with the 3500LBS winches rather then a smaller winch as winches are rated for how much of a rolling load they can handle at the first turn of the cable on the spool. The more wraps around the drum the less they will pull.
    Jay G
    DMC sidecars
    866-638-1793
    #16
    RetiredandRiding, brstar and TurTal like this.
  17. Strong Bad
    Oct 29, 2007
    9,060
    Omicron Persei 8
    The size and weight of the Warn along with it already having the synthetic line and knowing the quality of their product is what sold me. Sorry, but I only buy stuff from HF if it doesn't have any moving parts. Because a whole winch set up can be quite heavy, I shopped around for an aluminum snatch block and instead of using a D-ring, I use a locking carabiner and a ratchet strap used for lashing/tying gear works for the tree saver.
    #17
  18. usgser
    usgser Long timer
    Nov 6, 2005
    3,029
    Westside WA
    The Badlands are good winches. Be critical of the mounting. Some Ural dealers sell a goofy mount the bolts to the tub bumper. Bad idea. The front two bumper bolts are bolted to the tub sheet metal. You want the mount to bolt to the frame between the bike and tub. Don't know what kind of outfit you have but for a Ural, Kalaber(sp?)Creations make a decent frame mount that accepts a Badland. You want the winch forward enough so the cable isn't sawing into the tub nose. When stuck you rarely have a straight-on pull. I also wouldn't be overly concerned with line pull speed. Once you're stuck it's a bit late to get in a hurry. Most times all you need to do is move the rig a couple/ few feet to get unstuck. Love to have a winch someday maybe but don't like the idea of everything being based on a small mc battery. For my needs it's too much grief and expense to do it right.
    The Massdam rope puller works excellent for me. Lota cranks but they are easy cranks and I'm old. I run two 50ft lines(adjustable) so the puller isn't attached directly at the bike for more working room.
    #18
    TurTal likes this.
  19. norton(kel)
    norton(kel) vintage
    Apr 13, 2010
    2,521
    CO.
    [QUOTE Sorry, but I only buy stuff from HF if it doesn't have any moving parts.[/QUOTE]
    :imaposer:imaposer:imaposer
    #19
    Ridn3 and RetiredandRiding like this.
  20. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,047
    I’ve used one of these with good results .
    On sale for around $70.
    #20
