winch advice?
Discussion in 'Hacks' started by JerryAtrick, Sep 28, 2017.
  1. Tkacsman
    Tkacsman Adventurer
    Oct 14, 2017
    72
    Washington
    Here is a video how to for winching motorcycles. It will be similar for your sidehack and you could certainly use a cheaper/heavier winch than the Warn XT17 at just over 8lbs. I've had one of these since before they were available and still abuse my pre-production winch pretty bad. The winch in the video is a current production version.
    www.pssor.com
    #21
    cateyetech and High Octane like this.
  2. Bar None
    Bar None Old School Dude
    Mar 2, 2007
    10,812
    WNC SWFL
    If I was just out riding I'd turn around and go the other way.:lol3:lol3
    #22
    Bobmws likes this.
  3. Strong Bad
    Strong Bad Former World's Foremost Authority
    Oct 29, 2007
    9,077
    Omicron Persei 8
    One of the first things learned off roading into technical terrain is that you NEVER winch your way in, you only winch your way out!
    #23
    cwroady, SherpaGoon, davebig and 5 others like this.
  4. claude
    claude Sidecar Jockey
    Mar 17, 2002
    5,756
    Middleburg, Pa. (Snyder County)
    i prefer the ones with power in and power out and even a remote control. necessary ? only nice when you need it. BTW in any case get a snatch block slso.
    #24
    pops likes this.
  5. norton(kel)
    norton(kel) vintage
    Apr 13, 2010
    2,528
    CO.
    HaHaHa. One of the rigs I have now (davebigs old one) was built by Claude and I am glad it has a winch mount front or rear, as I didn't need to winch myself in to far, but I really needed it to winch myself out. :lol3
    #25
    Bobmws likes this.
  6. dengwynn
    dengwynn AT LARGE
    Sep 3, 2007
    192
    A comealong can be used with or without a snatch block never runs out of electricity, weighs less and (in my experience) pulls better than a cheap small winch. Motorcycle tire chains help when traction is limited.
    50 years ago i got a street bike stuck in quicksand. The little multiple pulley thing I had was worthless but I layed it over on its side and slid it out sideways on a tree limb
    #26
  7. bk brkr baker
    bk brkr baker Long timer
    Jul 19, 2006
    8,813
    The Bluegrass
    Yeah , no. In those conditions leave the 600 lb. behemoths in the garage and go out on 250 lb. bikes with full knobbies .
    #27
    SherpaGoon and davebig like this.
  8. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    9,092
    Minnesota
    As near as I can tell most sidecar folk qualify for senior citizen discount so if your riding alone or with an 18 pound dog use good judgment. Other than that rope or strap pullers will do allot of work with little extra complication.
    If you got to have a winch think about mounting one in the middle of the rig using the synthetic rope and put a fairlead at each end of the rig so you can pull either direction.
    #28
    brstar, Bobmws, BigFatAl and 2 others like this.
  9. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,048
    On my last rig the winch was up front BUT I cut some 2” pipe in half ( length wise) and welded them on the bottom of the car frame so I could run the cable underneath to winch backwards.
    #29
  10. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    3,103
    Same trailer, different park, FL
  11. triumphsidehack
    triumphsidehack Been here awhile
    Aug 30, 2010
    286
    Nowhere Indiana ,on the outskirts of Darmstadt
    Looks like she's got's herself good footing ( probably got lug souls on those six inch spikes ) and a good grip , But I'm a'feard the little wench is gonna git rope burns on her paws without proper hand protection " ATATT MISSY " yikes:jinx
    #31
    Bobmws likes this.
  12. Mr. Cob
    Mr. Cob Howling "Mad", Adventurer
    Aug 8, 2001
    10,924
    Granite Falls, Washington State, USA
    Howdy All,
    I have had this winch on the Predator, for the last five years, here it is mounted on the front of the rig.
    The winch can be moved from the rear, its normal carry position, mounted in the rear it can pull you back out of something you should NOT have driven into, mounted in the rear it puts weigh where its needed for traction and is protected from the harm of running into something. I have it setup so that all you have to do to transfer from rear to front is unplug the electrical quick disconnect and pull a pin out of the receiver, takes about 15 seconds to transfer the winch from one end to the other. I don't use it often but it darn sure handy when you do NEED it.
    Dave
    #32
    pops, cateyetech, Bobmws and 3 others like this.
  13. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,048
    Finally got around to mounting a winch on the new KLR rig.
    #33
    cateyetech likes this.
  14. usgser
    usgser Long timer
    Nov 6, 2005
    3,034
    Westside WA
    #34
  15. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,048
    I'm seriously considering mounting another 2,500lb on the back !!!
    They are cheap,work really well and I have a coupon for $47 !!!.
    Sent from my iPad using Tapatalk
    #35
  16. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,048
    Nope but what the hell by the time I build the the receivers it’s just as cheap to mount another winch and I enjoy doing that kind of thing !!.
    I setup the frame for a rear winch when I built it !!.
    I really makes no sense ( but neither do sidecars)and that’s ok with me !!
    And as far as weight go’s I’m running without a passenger 99% of the time do another 15lb or so won’t really matter
    #36
    Bobmws likes this.
  17. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,048
    And I knew it would get under the skin of some people on this forum !!.
    And that is just a added bonus !!
    #37
    Bobmws likes this.
