Windscreen
Discussion in 'Parallel Universe' started by RangerJoe, Mar 26, 2014.
  1. JRWooden
    JRWooden never attribute to malice...
    Jul 5, 2008
    6,917
    North Carolina
    :lol3
    Yeah...
    We really need to enforce the collect some basic data to go with opinions. At the very least:
    Bike make & model
    Seat - stock or modified height & any additions/modifications to seat (e.g. air hawk / inflated sheepskin / ... )
    Height of rider & Inseam of rider - From which we could estimate the all-important: bottom-of-butt-to-top-of-helmet parameter
    Windscreen make/model/height
    and .................. what else?
    #21
  2. wheelan
    wheelan Adventurer
    Jul 6, 2007
    49
    Australia
    I cut my original down, mainly the wings that extend up on the left and right at the top, I then went and made a triangle cutout about 1 third up from the bottom. The turbulence almost disappeared, I cant take a photo now but if you look at the calsci screens you will see they all have a cutout which they describe as necessary. This works for me, I cant believe how much I was getting beaten up by the original screen esp when behind trucks.
    #22
  3. FredRydr
    FredRydr Danger: Keep Back 300 Ft.
    Aug 16, 2005
    4,452
    Carlisle Pennsylvania USA
    Aw c'mon. Opinions always win out over empirical data.
    Fred
    #23
  4. BlueRidgeKat
    BlueRidgeKat Daily Commuter
    Mar 20, 2007
    494
    BlueRidgeMountains of Virginia
    When it comes to windscreens I'm not so sure its so much about opinion as it is just the fact of what works for one person may not for another. So many factors... height, riding position, helmet. The bad part is you may have to go through 3 or 4 of the damn things before you find the one that works for you.
    By the way I only change oil every 8000 miles no matter if it needs it or not. :D
    #24
  5. JRWooden
    Jul 5, 2008
    6,917
    North Carolina
    Ok Fred and BRK ... we are going to have to enforce at least a FEW rules here ......... both of you hosers owe me a beer :lol3 :freaky
    #25
  6. Forrest39
    Forrest39 Adventurer
    Nov 2, 2010
    60
    Hollister, CA
    Anybody successfully install a tall windscreen on a F700GS that is compatible with Barkbusters? With the OEM screen, there is about 1/2" clearance.
    I like the stream, but after looking at this image, I'm doubtful it would install properly...
    Thanks in advance for any ideas. For my bride's '13 F700GS.
    Cheers, -Kevin
    #26
  7. Capt CF
    Capt CF Pontificating Nobody
    Jul 1, 2013
    1,308
    Northern Virginia
    Yes, I did a Givi airflow and it works with Barkbuster Storms. I had to have them a tad higher than I would have liked, but they clear completely at the turn stops. The Givi is controversial though. Some people say there is too much buffeting, but then others say...wait, nevermind, this is the same discussion with every windscreen. :)
    #27
  8. sorebutt
    sorebutt Long timer
    Jun 26, 2008
    2,643
    Lewiston,ID
    I installed a Madstat and it clears as well as the stock. It uses wings that attach to the fairing for lower protection.
    #28
  9. Forrest39
    Nov 2, 2010
    60
    Hollister, CA
    I got a response from the Z-Technik folks who said that the v-stream is a little wide on the lower part of the screen and that it would not work with bark busters. Thanks for the responses!
    -Kevin
    #29
  10. wheelan
    wheelan Adventurer
    Jul 6, 2007
    49
    Australia
    So I have been asked for photos, note the frosted part on the top was to cover up where I had scratched it, I just taped it off and wet and dried it. The hole cut out has been shaped to draw air through, dont know if it helps or not? As far as the tops cut off I just kept shaping it till it look right. Anyway cheap as chips, even cheaper.
    https://wheelan.smugmug.com/Suspension-shots-/i-TCmpn8K/0/XL/20140404_164635-XL.jpg
    Note the angled filing of the hole below.
    #30
  11. Arclite
    Arclite Been here awhile
    May 22, 2007
    150
    TBD
    ^what did you use to cut that hole?
    #31
  12. ebrabaek
    ebrabaek Long timer
    Jan 12, 2010
    5,745
    Grand Valley, Colorado
    I believe it was an Aussie triangular drill.
    #32
  13. wheelan
    wheelan Adventurer
    Jul 6, 2007
    49
    Australia
    dremel grinder, file for shape, wet and dry sandpaper to finish up.
    #33
  14. MotoRod700
    MotoRod700 Adventurer
    Nov 15, 2013
    50
    Grand Prairie, Texas
    That's awesome ... I'm stealing your idea and hoping for the best.
    #34
  15. firebolter
    firebolter Been here awhile
    Aug 24, 2005
    647
    Annapolis Mary-Land
    Looks like the CalSci screens! only a little lower on the screen
    #35
