Winterizing fuel injected bike
Discussion in 'The Garage' started by MotorcycleWriter, Oct 27, 2019.
  1. MotorcycleWriter
    MotorcycleWriter Vis ad locum
    Dec 1, 2012
    2,938
    $$$ Valley, Utah
    I’ve not winterized a motorcycle before. Draining the tank seem like it’d be difficult and I wouldn’t get the fuel injectors clear anyway. Should I just use Stabil and run the bike a little before storing? Full tank or partial? Remove or disconnect battery? Put on a lift to get wheels off the floor. Recommendations for assuring radiator fluid is of proper mix? Brake fluid change? Anything I’m missing?
  2. theDoktor
    theDoktor Husky Racer
    Feb 2, 2011
    547
    Buffalo, NY area
    I fill the tank with non-ethenol fuel, add appropriate amount of Stabil, then drive a couple of miles. When I get home after doing this, I change the oil & filter, put the battery on a battery tender, and that's it. I save any brake fluid changes until spring- brake fluid absorbs moisture when exposed to air & the winters around here tend to be a bit moist... I change the coolant in the spring too. Just make sure you aren't running straight water in the cooling system before you put it up for the winter.
  3. t6pilot
    t6pilot Been here awhile
    Feb 15, 2011
    665
    huntington beach
    Marine grade stabil (purple)
    Full tank
    Battery on a tender
    Change oil and filter
    If bike has a center stand put it on it, removes some weight on tires, few pounds extra pressure in tires
    Make sure bike is clean(muck can turn to rust)
    Breathable cover
    Should be ready to ride in spring
  4. VX Rider
    VX Rider Long timer
    Dec 11, 2015
    5,978
    Phoenix
    Just keep riding the bike
    As long as there isn't snow or ice on the roads....
  5. RonKZ650
    RonKZ650 Been here awhile
    Jun 11, 2009
    960
    Lakewood, CO
    Fuel injected don't need anything. Probably best to fill with gas before storage, otherwise just let sit. Might take the battery inside, otherwise just charge once a month. Fuel injection eliminates the carb bowl stale fuel/clogged jets as there is no bowl to have small quantity of fuel which was what always went stale. Stabil does nothing, just fill up and don't bother with going to extremes.
    zaphoid and MotorcycleWriter like this.
  6. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,746
    Anchorage, formerly Spenard (hub of the universe)
    full tank, add Stabil, drive, change oil, pull battery, plug exhaust. thats what I do. still riding here in Anchorage AK but not for long....
    MotorcycleWriter likes this.
  7. Turkeycreek
    Turkeycreek Gringo Viejo
    Oct 26, 2010
    3,345
    Banámichi, Sonora, Mexico
    Head to Southern AZ and into Mexico. No winterizing needed.
    MotorcycleWriter and dtysdalx2 like this.
  8. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    36,191
    Pittsburgh PA
    I personally don’t do anything, it is ready to be ridden. This makes it easier to jump on the bike if we get some nice weather in the winter. If you don’t ride it at all, maybe start it every couple months and bring it up to operating temp.
    #8
    MotorcycleWriter and Bultaco206 like this.
  9. Bultaco206
    Bultaco206 Back-to-back motos suck Supporter
    Feb 11, 2007
    53,562
    Mineral Point, WI
    We have a 5-6 month off-season, depending. Other than making sure the bikes are clean, and on stands, the only thing I do is pull batteries and bring them in the house as my shop isn’t heated. That’s it.
    #9
  10. vfxdog
    vfxdog Been here awhile
    Jan 5, 2007
    791
    Santa Monica or London, depending on work.
    In my experience, pulling the battery and giving it a 12-hour charge every month or six weeks or so is better than just leaving on a tender.
    If the bike is in a fairly humid environment, make sure the gas tank is full to avoid rust.
    Stabil or Seafoam a must if you have ethanol gas.
    Oil change a good idea prior to layup.
    #10
    MotorcycleWriter, 23103a and Beezer like this.
  11. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    9,381
    NH
    I find winter is also a good time to get valve clearances checked, pull swing arms and repack the grease in the bearings, make modifications that are planned. Just a good time to get those things done to prevent downtime during the riding year.
    #11
    racer1735 and MotorcycleWriter like this.
  12. dtysdalx2
    dtysdalx2 Only a matter of time.
    Aug 1, 2004
    25,282
    Moneyapolis, MN
    :y0! Can we leave November 1st?
    Anyway, I just get Non Ethanol fuel in mine and keep it clean in the garage. I use it once in a while in the winter when it gets in the 40's.
    #12
    Bultaco206 and MotorcycleWriter like this.
  13. Turkeycreek
    Oct 26, 2010
    3,345
    #13
  14. theDoktor
    Feb 2, 2011
    547
    Buffalo, NY area
    When I lived in Texas, I rode year round except for the few days we had ice storms. Typical morning commute was on dry roads with temps in the mid to high 20's. They didn't use salt/brine except when ice storms happened. When I moved to upstate NY, riding season ends fairly early, although I tend to push it a bit. As long as they haven't salted the roads & no ice on the road, I'm good to go. Riding here typically ends around Thanksgiving and restarts early to mid April. I've ridden as late as Dec. 26 a couple of years ago. The salt they use here corrodes the bikes terribly, and I've had bad experiences with black ice while riding, particularly on early morning rides. (Gone flat side down so fast my feet never left the pegs!) So when the salt goes down for the first time of the season, the riding season is over for me.
    Even though my current street bike is fuel injected and lacks the float bowls of carbed bikes, I prefer to not take a chance of the tiny ports in the injectors getting clogged with gelled fuel- hence the Stabil + non-alcohol fuel. Last year I broke a wrist on my dirt bike & my street riding season ended early without being able to prep the bike for winter hibernation. It still had a nearly full tank of the usual crap gas. I just added Stabil to it, ran it for a bit, and all was good for the winter. Battery still went on the tender tho.
    #14
  15. JT105
    JT105 Let's Ride!
    Jun 24, 2014
    465
    SE Michigan
    This is how I store my EFI bikes and carbureted power equipment:
    Marine Stabil (1oz per 5 gal) and TCW3 2-cycle oil (1oz per 5 gal) I n the gas tank.
    Go for a short ride to get treated gas through the system.
    Change oil and filter.
    Ride to the gas station and top off the tank with gas.
    Store on center stand with a breathable cover.
    Connect battery tender.
    Say goodnight for the winter.
    The TCW3 marine 2-cycle oil and full tank of gas prevents rust and corrosion in the gas tank and fuel system. I use it in all my small engines. It really helps protect carburetors but also lubricates fuel pumps and injectors. The small amount of oil equates to a 640:1 mix. Hardly anything to foul the plugs but enough to keep a protective coating on everything. In the spring, just ride. The fuel will still be fresh.
    JT
    #15
    MotorcycleWriter and theDoktor like this.
  16. dtysdalx2
    Aug 1, 2004
    25,282
    Moneyapolis, MN
    #16
  17. racer1735
    racer1735 Long timer
    Dec 30, 2005
    1,359
    Amarillo/Canyon, TX
    I live in West Texas (actually the far North part of the state, but for some reason we call it 'West)....my riding season extends year-round. However, we get days, sometimes a week or so, where we get snow, ice and temps in the low teen's (such as this week). My bike is fuel injected and always gets ethanol-free fuel (at least when I'm in the region....can't speak for what's available away from home. I also dump a suitable amount of Stabil or Sea Foam in the tank before I fill up. My ride to the gas station is 15 miles, so I know the stabilizer has plenty of time to get circulated thru the system. My bike may sit 2 weeks or so between rides, but I've never had an issue starting or running (same procedure with my former carbureted bikes).
    #17
  18. showkey
    showkey Long timer
    Jun 25, 2007
    2,411
    Wausau
    FI bike you may get away with doing nothing...........but............
    Another vote for full tank, non ethanol, stabil and battery maintainer which will pretty guarantee you will no storage issues.
    This Seafoam thing keeps coming up, its naphtha, pale oil and alcohol........so.........you hunt down and pay extra for non ethanol fuel. Than add % alcohol back in ........that makes no sense.
    #18
  19. 1greenmachine
    1greenmachine Long timer
    Aug 28, 2010
    4,554
    green bay, wi
    Throw some stabil into tank and fill it up and go for a ride and park it. In spring I start it up and go for a ride.
    #19
  20. petertakov
    petertakov Been here awhile
    Jun 19, 2012
    896
    Why?
    #20
