wont start wont crank wolf rx-50
Discussion in 'The Garage' started by paulmars, Sep 29, 2019.
  1. paulmars
    paulmars Adventurer
    Jul 31, 2019
    16
    florida
    regularly driven 2-4 times a week.
    wolf rx-50 with 49cc gy6 qmb139 engine.
    battery 12.x volts.
    full voltage at the starter push button.
    no voltage at the starter when starter push button is pressed.
    ideas?
    tks,
    paul
  2. Zoef zoef
    Zoef zoef Long timer
    Apr 19, 2009
    1,268
    Finn√ły Island, near Stavanger, Norway
    Starter solenoid defective would be my hunch, f it has one. Can be tested by bridging with piece of thick wire, with all safety precautions.
    gonerydin likes this.
  3. gonerydin
    gonerydin Been here awhile
    Feb 14, 2012
    545
    Iowa, USA
    Plus 1 for the starter relay.
  4. usgser
    usgser Long timer
    Nov 6, 2005
    3,580
    Westside WA
    +2 relay
  5. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    3,600
    Northern California
    At the least clean the battery terminals, and then clean the 2 high tension terminals at the solenoid, and check that the smaller wires are still properly connected there.
  6. paulmars
    paulmars Adventurer
    Jul 31, 2019
    16
    florida
  7. Hittman
    Hittman Been here awhile
    Nov 15, 2007
    227
    Minneapolis
    That is the starter relay. If you're reallllly careful you can jump the two posts there with an INSULATED screwdriver and if the starter spins then that's your problem.
  8. paulmars
    paulmars Adventurer
    Jul 31, 2019
    16
    florida
    #8
  9. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,940
    Hiding off Hwy 6, B.C.
    First pic is probably the CDI.
    CDI for "capacitor discharge ignition".
    Second pic? Only two posts so probably not a starter relay.Looks like an overload protection relay.Any markings on it?
    #9
  10. paulmars
    paulmars Adventurer
    Jul 31, 2019
    16
    florida
    first pic: xd2
    d11-hy
    151005
    2nd no pics.
    #10
  11. H96669
    Nov 20, 2009
    5,940
    #11
  12. paulmars
    paulmars Adventurer
    Jul 31, 2019
    16
    florida
    Tks. Batt voltage is 12.8
    Batt plus to one red on starter relay is 12.8. the other red onthis starter relay is zero volts.
    That same other red on starter relay to starter is 2.2 ohms.
    Confusing is that same other red on starter relay to engine gnd is 5.8 ohms.
    Ur thoughts?
    Tks, paul
    #12
  13. H96669
    Nov 20, 2009
    5,940
    You haven't shown the two small wires attached to most if not all starter relays.So for now my guess is that it is an overload protection relay.
    In any case......there you go:
    Ohms? As per your readings?Maybe some clues that the starter is cooked? Cooked from repeated long starting attempts from your previous problems with that Chinese scooter?Starters are not designed to operate under load for a longer time.That usually overheat them and shorten their life.
    Ohms readings ? Somewhat meaningless unless you tell us what scale was used on your Ohmeter.
    https://www.google.com/url?sa=t&sou...DEAE&usg=AOvVaw0RNJdEEuE52CJ6wlgm0nms&ampcf=1
    #13
  14. paulmars
    paulmars Adventurer
    Jul 31, 2019
    16
    florida
    start btn bad
    #14
  15. H96669
    Nov 20, 2009
    5,940
    :jack
    WTF!:lol3
    #15
  16. paulmars
    paulmars Adventurer
    Jul 31, 2019
    16
    florida
    It worked for a few days with new switch, now its dead again. Now both sides of the start switch have 12.7 volts even with key removed and brake not engaged. Switch is fine.
    Ideas?
    tks,
    paul
    #16
