Woodmans BMW/SWM
Discussion in 'New Zealand' started by innathyzit, Jan 17, 2014.
  1. innathyzit
    innathyzit AKA Woodman
    Dec 30, 2008
    2,669
    Nelson NZ
    Also have near 3 inches more travel. Seem okay on a ride round the block but will test them proper later on.
  2. Night Falcon
    Night Falcon Structural Failure
    Dec 25, 2008
    9,006
    New Zealand
    all adjustable are they?
  3. innathyzit
    Dec 30, 2008
    2,669
    Nelson NZ
    Yup got compression and rebound. Originals only had rebound. never did like the front end on this bike*, sorta felt nose down to me and was hard work on rocky terrain going slow as it just sorta bounced off everything. Definitely better at speed than the beemer and especially the klr on the rough. A bit of suspension work would have fixed it, but these forks came up real cheap on tradme so I thought it was worth a go, and even if they didn't work that well there should be some good bits like the compression adjusters that could be built into the originals. Only took a couple of hours to swap them over.
  4. Box'a'bits
    Box'a'bits In need of repair Supporter
    Sep 26, 2008
    4,516
    Wellington, New Zealand
    What are they, & what are they off?
  5. innathyzit
    Dec 30, 2008
    2,669
    Nelson NZ
    Marzocchi shivers, stock forks on Husqvarnas since ages ago. Same as what are on my SWM, Off a TE250 (2007 I think). Basically just slid in.
    Night Falcon, bikemoto and Box'a'bits like this.
  6. Night Falcon
    Dec 25, 2008
    9,006
    New Zealand
    have the same complaint with the XC's front end. Hoping some lighter oil and progressive springs might help but not confident, old showa design straight from 1970. 2015+ come with WP forks. love or hate ktm.... at least they're well sprung'd
  7. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    591
    NZ
    Forks on the 690 are pretty harsh on rough rocky ground. Running front tubliss below 10 PSI makes a huge difference. Settles the bike right down and makes it a hell of a lot more fun.
    Look forward to hearing how the new forks go. The change in geometry from the higher front end will make a big difference to the way the bike turns I would imagine. Then again more travel and plushness might mean they will compress more under braking and turn just as well as the shorter forks.
    We expect you to push them to their limit and report back. Preferably with photos of limit reached/exceeded :D
    innathyzit and Night Falcon like this.
  8. Night Falcon
    Dec 25, 2008
    9,006
    New Zealand
    at least you can tune 690 forks!
    +1 on the photo intel :lurk
  9. innathyzit
    Dec 30, 2008
    2,669
    Nelson NZ
    Just went for a hoon at the Skunkworks Appleby River Top Secret Moto Farkle Test Ground and Bike Wash Facility.
    Quite unbelievable the difference they have made to be fair, it now handles offroad like a dirt bike should, even turns faster and better, in fact the improvement in the turning part and stability over rough terrain is quite remarkable. Thinking that now the ergos are closer to the Husky TE610 which this bike originally derived which were apparently a pretty good offroader. The speed wobbles, which didn't really bother me have dissapeared to. Well up to 130k. Didn't go any faster. Think I will just leave these forks as they are.
    DLRuapuke and Takataka like this.
  10. Box'a'bits
    Sep 26, 2008
    4,516
    Because your bike is heavier than the TE250 you derived these from, do you think the forks have a bit of sag? If so, that may bring the geometry back nr the original? But give more compliance
  11. innathyzit
    Dec 30, 2008
    2,669
    Nelson NZ
    No, sag is near the same as the original forks so the bike is sitting and feels a lot higher at the front, and I have no idea how these forks have been set up in regards to spring and oil weight. TE250 has 300mm front travel same as TE610. SWM has been reduced to 210mm.
  12. innathyzit
    Dec 30, 2008
    2,669
    Nelson NZ
    Suspension tuning day today.
    Difference between static and race sag with 15 litres of gas is 30mm on the front end. That is okay in my books, which makes me think that the TE250 forks have had stiffer springs installed. Played with the setting a bit and set them up to as optimal as i could get and went for a test ride and am still amazed at how much better the front end is. So compliant over the rough rocky stuff and also soaks up some quite large bumps at speed incredibly well.
    Had a look at the rear as well as it was just so harsh. The dampening was on its lowest setting e.g. little or no dampening. I think I set it there before the Oz trip thinking that the weight of all the gear would effectively supply enough dampening. Anyway, set it about midway and reduced the spring tension a couple of turns. Result, totally different bike (unladen). Very happy with the result.
    vsaltao and Takataka like this.
  13. ztaj
    ztaj jatz
    Jul 22, 2008
    1,362
    Nelson-ish New Zealand
    Wondered why you weren't in the office today...
  14. DLRuapuke
    DLRuapuke Been here awhile
    Oct 29, 2008
    294
    North of the South NZ
    I dont think youll see much of him at all now..............................
    bikemoto and innathyzit like this.
  15. innathyzit
    Dec 30, 2008
    2,669
    Nelson NZ
    Yeah, itching to get out for a decent ride but off to Oz for a couple of weeks on Monday so further testing will have to wait.
    DLRuapuke likes this.
  16. Mark_S
    Mark_S Fair Weather Faggot
    Jun 13, 2007
    2,657
    Kapiti NZ
    Again?
    lifestyles of the rich and famous?
  17. Box'a'bits
    Sep 26, 2008
    4,516
    Now he's not running an Airhead he has more free cash....
  18. Muzz67
    Muzz67 Unadventurous
    Dec 6, 2013
    946
    Brightwater,New Zealand!
    Someone mention 'free cash"??
  19. innathyzit
    Dec 30, 2008
    2,669
    Nelson NZ
    What is that force that compels us to ride up the snottiest, eroded, steepest track that we see. Seriously I spent a couple of minutes talking myself (not out loud) out of riding up this, and agreed with myself that riding up would be a bad idea as it looked damn near impossible. As soon as I let the clutch out to ride away that mysterious force took over.
    It didn't end well.
    On the up side, the new forks are fantastic......
    Te Hopo, DLRuapuke, vsaltao and 4 others like this.
  20. Takataka
    Sep 26, 2014
    591
    NZ
    I know the feeling. Riding home after an honest (but failed attempt) still feels OK though I reckon. Even better is when you go back later and slay it..
    I tend not to try things if a fail is too dangerous though.
