Would like to Lower a 650gs twin, any suggestions?
Discussion in 'Parallel Universe' started by Promach 1, May 30, 2011.
  1. Promach 1
    Promach 1 Promach 1 Supporter
    Mar 9, 2007
    370
    NW Montana, Flathead valley
    Need some ideas or suggestions on lowering a 2011 650gs twin.
  2. tedder
    tedder irregular
    Jun 8, 2004
    8,795
    Portland
  3. Truckin_Thumper
    Truckin_Thumper low profile
    Jun 28, 2007
    29,572
    Denton,TX
    OK, forgive me right off the bat....
    How damned short are your legs? :huh
    I have a 30" inseam ( actually 29", but dont tell these FFs that) and I have no problems with a 650GS, nor a 1200GSA, or a 950/990.
    IMHO, lowering them ruins the suspension. Bumps suck more, hard leans are more hairy.
    BUT if ya gotta do it follow the links above
  4. baldrick
    baldrick Moto-Geezer
    Aug 31, 2005
    424
    Leave the suspension alone and cut down the seat.
  5. bobobob
    bobobob IN HOC SIGNO VINCES
    Feb 11, 2011
    11,035
    On a hill
  6. Tom Morrison
    Tom Morrison Adventurer
    Mar 7, 2011
    45
    Calgary
    I'll sell you my lowered version rear shock and side stand from my 2010.
  7. Bruce Caldwell
    Bruce Caldwell Long timer
    Jan 25, 2003
    1,046
    Brazoria , Tx.
    My dad just got a new F650GS three days ago with the factory lowered suspension because he's 81 years old & dropped his previous bike (1200GS) a lot & thinks the lower the better. I got to ride the new bike quite a bit today & I think it's horrible, the suspension that is. Possibly even dangerous. I'll play around with the adjustments a little & see if that helps.
  8. huckleberry
    huckleberry BACK ROAD BOMBER
    Sep 19, 2008
    1,108
    N.E. Pa.
    I have a standard f658 and thought the suspension was terrible as it would sag the front 2" under just the weight of the bike, add my 220 lbs. and you only had about 2" of travel left. by adding a 5/8" preload to the front and a wilbers shock to the back i now have good suspension action which will absorb a pothole or good sized bump. To go shorter than stock unless you weigh 90 lbs is a mistake in my opinion as there just is not enough travel to absorb road hazzards.
    #8
  9. Tom Morrison
    Mar 7, 2011
    45
    Calgary
    Damn, not looking like I'll get rid of that shock. In truth, I replaced it with an Ohlins as well as adding Ricor Intiminators up front, the difference in ride is stark and for the better.
    Before hitting a pot-hole at highway speed was harsh to the point of being hairy.
    Now it is a lot less harsh.
    Also with the lowered suspension, the bike does not turn as well given the increase in rake.
    #9
