Wow an actual fuse!
Discussion in 'Parallel Universe' started by bmwroadsterca, Feb 11, 2020.
  1. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    974
    Lanark County near Ottawa ON
    I just learned that the later years F700GS (and presumably F800GS) have fuse perched on top of the battery. It's a 30A fuse. The owner's manual describes it as the "main fuse" (voltage regulator).
    Anyone familiar with how and where it's wired in? Just curious since the bikes went without such a thing for most of the years they were sold.
  2. satur9
    satur9 angry black guy
    Mar 7, 2009
    837
    hfil
    Im pretty sure there was always a main fuse(ible link) directly off battery to prevent total bike meltdowns . It's the fuse box for everything else we don't have. If you're adding something. A separate battery harness ( with dedicated fuse for load). Is still you best bet.
  3. bmwroadsterca
    Jan 3, 2007
    974
    There is no such beast in the schematic wiring diagrams available in the Haynes manual nor have I ever seen one nor do I recall anyone ever discussing one in almost a decade of following discussions here. I am not referring to add-ons. I'd like to know what BMW changed - and why if possible.
  4. BetterLateThanNever
    BetterLateThanNever It turns out you can't delete your account...
    Dec 31, 2014
    2,538
    Ontario, Canada
    My '15 F7 has one. It also came with a BMW-branded battery tender that plugs into an SAE connector wired to the battery. I don't know enough about electrics to know whether that's an explanation, but FWIW...
  5. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,885
    South Jersey... Close to the Pines
    My 2013 F 800 GS had the fuse I remember it from when I changed the battery and the first time I had a headlamp issue before I realized there are no other fuses in the can bus system
  6. bmwroadsterca
    Jan 3, 2007
    974
    Now that's curious as over on F800Riders.org there's a fellow with a 2012 F800GS that saw the photo and said that his bike didn't have one.
    And I need to be tedious and say that none of this has anything to do with CANbus. Somehow most of the world seems to have equated using a module to control electrics (the ZFE in our case) to the CANbus (which is a Controller Area Network).
  7. bmwroadsterca
    Jan 3, 2007
    974
    We are likely not discussing that same thing. A properly installed SAE lead will have a fuse in it and I suppose one could locate that in the place shown in the photo. However the photo above is not an SAE lead.
  8. rcb78
    rcb78 Adventurer
    Dec 17, 2017
    88
    San Jose, Ca
    That was me, but it's a 2013. Original wiring intact and no fuse.
    #8
  9. bmwroadsterca
    Jan 3, 2007
    974
    Yes - I hit the wrong key - meant 2013. Thanks.
    #9
  10. NCD
    NCD Dirty Hairy Supporter
    Nov 13, 2008
    808
    NE Ohio
    2011 800 definitely do not have that fuse.
    #10
