WP Forks rust behind guard - improved cleaning procedure required
Discussion in 'Parallel Universe' started by JustPedal, Aug 27, 2016.
  1. JustPedal
    JustPedal Adventurer
    Feb 14, 2015
    59
    Australia
    After a post from rider on local FB group about rust on lower section of forks behind guard I removed the guard on my 2015 GS adventure and ...
    Cleaned up with a phosphoric acid based rust treatment and then silicon lube - I will now be cleaning and checking this spot regularly and will remove guard for full treatment each tire change.
    Canada Mike and Dorito like this.
  2. fattyboombatty
    fattyboombatty Been here awhile
    Feb 19, 2012
    142
    Central Coast, NSW
    I had the same issue pointed out to me when I had my suspension upgraded. Mine was not as bad as yours, but in the exact same spot. Pretty frustrating
  3. Snks
    Snks Been here awhile
    Feb 4, 2014
    579
    You boys near the ocean or something?
  4. BygDaddee
    BygDaddee Long timer
    Oct 26, 2012
    13,395
    Bris
    thanks for thread, interesting isn't it, I have the same spots as your smaller one, I remembered this thread from a while ago and had a good a look because I've got my wheel off.
    Its very strange how its in the exact same spots on everyones, and not even and area that has anything touching or rubbing it for stuff to just sit there. When I first read this I thought t must be where the fork gaurds and sitting up against something but its not.
    The spots are well below the fork sealing bottoming, cleaned up very easy with some fine wet and dry and I sprayed a bit of chain lube on it, a nice spot to keep an eye on and lube up every couple of months
