wr250r front wheel alignment problem (bend triple clamp)
Discussion in 'Thumpers' started by tkey_cn, Sep 6, 2020.
  1. tkey_cn
    tkey_cn n00b
    Feb 14, 2019
    4
    china
    My bike is a 2017 wr250r. The previous owner may have a big crush on the left side. After I got it and rode it, I feel the front wheel is pointing a little bit to the left side and the handlebar is not very stable at slow speed. So I checked the upper and lower triple clamp found out that the left side of the upper and lower are all 1mm lower than the right. But the front wheel axle is very smooth to slide into both axle holder, based on my experience this should incident that the front end is aligned. By the way, the handlebar does not bend. So I'm confused does this 1mm bend caused the front end out of alignment feeling? Should I check other parts or just replace bent triple?
  2. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    19,547
    The bad side of the PNW
    Usually the forks bend before the triples on these. That whizzelberry triple is a beast.
    Not to say that it's impossible, but it certainly won't be the only damage if it was schwacked that hard. Can you reach out to the previous owner and ask what happened?
    Navin likes this.
  3. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    47,638
    Pittsburgh PA
    They are probably not bent, just out of alignment. Loosen the triple clamps up and twist the front wheel until it is straight.
    Bitingdog and Navin like this.
  4. tkey_cn
    tkey_cn n00b
    Feb 14, 2019
    4
    china
    I have done that, the problem is still there.
  5. Yinzer Moto
    Jun 13, 2008
    47,638
    Pittsburgh PA
    If the fork legs are bent, removing them and rolling on a flat surface will show the bend.
    Even if the triple clamps are bent, you should be able to align the wheel so it is straight.
    I have taken a lot of really hard crashes and twisted the triples many times, just loosening and straightening everything always fixed the problem. The only time I have seen forks or triples actually bent, many other components of the bike were destroyed and well as the rider.
    Bitingdog, Navin and Bultaco206 like this.
  6. Navin
    Navin Long timer
    Sep 22, 2009
    29,518
    Do the fork tubes slide out of the clamps easily?
    Bitingdog likes this.
  7. eddie bolted
    eddie bolted BOING!!! Supporter
    May 31, 2009
    9,014
    st. clair pa.
    Loosen everything but the top triple clamp then compress the front forks a few times (that SHOULD align everything)then start at the bottom triple clamp and tighten that then the axle then the axle clamps!
    Navin and Bitingdog like this.
  8. Bitingdog
    Apr 2, 2015
    19,547
    I've been destroyed without bending anything :2cry
    #8
    Navin, Bultaco206 and Yinzer Moto like this.
  9. Yinzer Moto
    Jun 13, 2008
    47,638
    Pittsburgh PA
    :photog Yup, usually that is the way it happens. I get destroyed and the bike is perfectly fine.
    #9
  10. Navin
    Navin Long timer
    Sep 22, 2009
    29,518
    China rider on a Whirrrrr? Strange daize indeed!
    #10
  11. tkey_cn
    tkey_cn n00b
    Feb 14, 2019
    4
    china
    the lower is a little bit tight, but from other riders youtube videos, it seems normal on wr250r. yeah, I'm a china rider, and I do not understand the words "whirrr" and "daize", sorry for that.
    #11
    Navin likes this.
  12. Navin
    Navin Long timer
    Sep 22, 2009
    29,518
    Try the above advice and you can also rotate the upper tube 90 or 180 degrees to see if anything changes.
    Wirrrrr or Whurrrr is a pet name for the WRR, and day/daize. Just joshing aboot. (Canadian for about).
    #12
  13. tkey_cn
    tkey_cn n00b
    Feb 14, 2019
    4
    china
    I plan to take the whole front end apart and measure all parts ( I want bike to be a perfect condition).
    Dual sport bike is a rare thing in China indeed (people usually use it as a dirt bike), and the motorcycle market in China mainly focus on street bike and big adv bike(gs or africa twin etc), but we have very good off road environment in the northwest part of China ( plus no law will restrict you off-roading).
    #13
