1. ADVRIDER Print Magazine!
    We're doing two more print magazines year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
WR250R Fuel Pump Problems
Discussion in 'Thumpers' started by ejtv, Jun 18, 2012.
  1. ejtv
    ejtv Per ipsum
    Aug 1, 2006
    1,781
    Mentally? Out west...
    Manufacture date 8/08
    Fuel pump would not prime after a couple of routine photo ops in Lockhart Basin. Temps in the 100 plus range. Only way to start the bike was push start downhill. Battery and all electronics OK. AM start in cooler temps OK. Thank God. Next day fuel pump stopped working altogether while riding at 35 MPH on Gooseberry Rd on the Fishlake NF. Temps were cool. After towing it for a few miles we were able to push start it on a downhill. Also needed a push start after refueling at Hite, high temps too. At this point I called the ride off and we headed back to Moab. Pump working OK last evening and this am. Waiting for shop to open to replace the pump.
    Very erratic behavior for the pump. Seems high temps could be an issue. I got to Moab from Denver in cooler temps earlier in the week and had no problems.
    My son has exact bike set up, same ride, 5/08 build. No problems.
    Has anyone else had this problem and did replacing the pump fix it?
  2. AustinJake
    AustinJake DR650 - Versys
    Aug 20, 2010
    6,642
    Austin, TX
    Older pumps, and pumps that have set up for periods of time develop a coating of varnish inside the tightly toleranced pump body. At high heat levels, the pump swells up and starts locking up, only flowing, cooling gas or extended cool down will allow it to work. I have tried cycling a varnished up pump in a bath of fuel injector cleaner and it could not get the varnish out. Pump must be replaced when exhibiting this behavior. This 30mm pump works with the WR250
    http://www.ca-cycleworks.com/fp-hus
  3. scottmac
    scottmac Long timer
    May 21, 2008
    4,016
    La Selva Beach, CA.
    The fuel pump is the weak spot on the '08 WRR's. The problem has been solved on later models and swapping
    the old pump with a new one takes care of the problem. I think the cheapest place you can pick up a new pump
    is Service Honda online for around $213.
  4. Wolfgang55
    Wolfgang55 Long timer
    Dec 24, 2006
    4,375
    Only N flowin river emptying in an ocean
    My wr250x has been in nearly all dirt since new it is an 08 w/ no issues. The NM desert is high & dry but not near as hot as some. I run it hard but keep a clean air filter & fresh oil/filter. Had one time, as you described. I think it was the brain of the FI telling the motor not to start up cause "IT" was just to over heated. I took it home, replaced the air filter even though it was not ready for a change & the next AM it ran like a raped ape on fire in Antarctica.
  5. AustinJake
    Aug 20, 2010
    6,642
    Austin, TX
    The CAcycleWorks pump is $130
  6. what broke now
    what broke now Petroleum Brother Supporter
    Jul 12, 2011
    3,144
    Bezosville
    How did you use It? Did you remove the original pump from the carrier and put the new one in it's place, or set it up loose in the tank?
    My wr has a replaced pump and it still failed me in a trail switchback out in the boonies. 80 deg. temps.
  7. jon_l
    jon_l Long timer
    Feb 8, 2008
    8,578
    Collingwood, Ontario
    Not being a dick, just offering advice you might be able to use. A search would have gotten 9,080 hits from this site alone re: this well-documented issue:
    This is how you search ADVRider:
    Google this "wr250r fuel pump issues site:www.advrider.com"
    Works with other sites too, like http://wr250rforum.forumotion.com/
  8. what broke now
    Jul 12, 2011
    3,144
    Bezosville
    'did replacing the pump fix it?'
    Beyond all the helpful pump swap how-toos and sources of minimum price pumps, what seems to be shaping up is that replacement with a Yamaha pump off the shelf is no improvement. I have a 2008 and changed my pump to end run the potential failure, and had one anyway. BigDog is currently writing up a ride report, and just replaced his second [or third?] pump. Whether your pump has the new black plastic part or not, seems to make no difference.
    I am hoping to hear that the cal cycleworks pump is the bomb.
    #8
  9. ejtv
    ejtv Per ipsum
    Aug 1, 2006
    1,781
    For those of you wondering, yes, I replaced the fuel pump with new Yamaha pump and this fixed the problem.
    #9
  10. Pantah
    Pantah Jiggy Dog Fan Supporter
    Oct 25, 2004
    13,175
    Scottsdale Arizona
    I had a similar problem two weeks ago when I flew to Phoenix to ride my 2008 north for the Pony Express Trail. The bike had 5500 miles on it and temps about 100. Not run since April. No fuel pump buzz at all. Fiddled with the elec connecter under the tank and she buzzed and fired. Loaded up to go but no more joy. Ordered a new pump from local dealer at $408. Said 3 days so I waited.
    Meanwhile I pulled the old pump from the tank and fiddled with it. Seemed electrical, but I didn't know if it was the connecter or inside the pump. Eventually it buzzed. Third day dealer said another week. Shit! Nothing to do but try the old pump.
    Bought elec contact cleaner and sprayed all elec connections. Squirted in elec grease. Put all back together and refilled tank. Next 2500 miles over 9 days were flawless. Buzzed every time.
    The connecter under that tank is exposed to a rough environment. Probably should be cleaned regularly. I still took the new pump but will keep it as a spare since I fly to ride that bike and have flight constraints.
    #10
  11. lamotovita
    lamotovita DAMN SNOWBIRD! Supporter
    Oct 5, 2007
    3,621
    WA/AZ, USA
    Can someone explain how a bike with a non functioning fuel pump can be push started?
    #11
  12. rivercreep
    rivercreep Banned
    Feb 27, 2007
    3,243
    S.E. Pennsylvania (Reading)
    :ear
    Also out of curiosity I'd like to ask...
    Is there any way to install and external fuel pump on this bike and fabricate a different type plate to block off where the factory pump mounts so that it only has a fuel outlet there like a bike without a pump has? Or is it a recirculating type pump that takes the excess gas and pumps it back into the tank like my TU250 does?:ear
    #12
  13. strongbad
    strongbad Been here awhile
    Jun 21, 2006
    740
    Idaho Falls, ID
    My question also.
    #13
  14. ejtv
    ejtv Per ipsum
    Aug 1, 2006
    1,781
    Don't know how but in my case it worked many times. Recall that my pump problems were worst in extremely hot outside temps. I think, though I am not sure if it is physically possible, that push starting allowed cooler fuel to flow through the pump and tell the computer system it was OK to allow the engine to start. But if it is really not working, no, it cannot be push started.
    #14
  15. motoman250f
    motoman250f Been here awhile
    Aug 21, 2004
    833
    Hooold on.... You can just say your looking for a condensed version.. this rant sounds like a grade school kid.
    #15
  16. montesa_vr
    montesa_vr Legend in his own mind
    Mar 24, 2006
    2,063
    Another question -- am I mistaken that this has been mainly a problem for the original 2008 model year? Has it occurred on more recent models? If the fuel pump was not significantly revised until just weeks ago, why aren't fuel pump issues as common on model years 2009 and 2010?
    I suppose, if etingelefunts is correct that the problem is tolerances and materials, that a lot more of the original equipment fuel pumps will eventually fail.
    Regarding the Cycleworks pump vs. a factory replacement, I doubt we'll ever have enough evidence to compare their reliability.
    And while I can do Boolean as well as the next guy, I think it's usually lame to harass people for not doing hours of reading prior to asking a question.
    #16
  17. tmotten
    tmotten Lefthand ride Dutchy
    Jun 28, 2006
    2,705
    Calgary
    Great post. Glad this thread stays current. Unfortunately with FI, no fuel pump = no worky bike.
    Has anyone ever looked at an inline pump below the tank as a backup? I'm not saying to have there in place in case the main one fails. I realise that can't work, but with a 2 barb fitting in a longer hose it can be put in place easily. The main pump would have to be removed from the pump housing which is fiddly, but there is ample room for it under the tank.
    Are there install posts of that cycleworks pump?
    #17
  18. what broke now
    Jul 12, 2011
    3,144
    Bezosville
    Anybody here have the new part number? I would guess dealers will be wanting to move the original part # units before ordering the 2014 version. I am in the camp guessing that pump failure has nothing to do with the year of the bike.
    #18
  19. debaisley
    debaisley Long timer
    Apr 2, 2008
    1,593
    Big Bone, KY
    Old part number 3D7-13907-00-00
    new part number 3D7-13907-10-00
    anybody know when that new part number came out ?
    anyway I have an 08 , original pump , 15k miles , never a hiccup
    #19
  20. what broke now
    Jul 12, 2011
    3,144
    Bezosville
    You might try a PM to Austinjake on the first page of this thread. I think he put one into a Husky or KTM and wrote it up.
    I was able to disassemble mine and confirm that I could reassemble the setup, so if the components are sized the same, it should be pretty easy to fit up.
    Also there was a Greek rider on here who bought this pump:http://stores.ebay.com/Felco-Products/Yamaha-Fuel-Pump-/_i.html?_fsub=4427414011
    His post appears on the main wr board post # 36318.
    Several weeks later iirc, he reported that the task was completed.
    [ I would link the individual post , but don't know how, sorry]
    @debaisley: thanks for the part#
    #20
