Wrapping the cat converter on a 1290
Discussion in 'Hard. Core. (1090/1190/1290)' started by DakarBlues, Oct 19, 2019.
  1. DakarBlues
    DakarBlues One-everythinged man
    Dec 12, 2005
    1,538
    The pink lake less circled
    Folks,
    do you think it's a good idea to wrap the cat converter on the 1290 R?
    I just want to have the heat reduced, anyway winter is setting in, it's not an urgency anymore though.
    Maybe get the new decatted stainless steel headers from Dobermann Performance ($395)
  2. rick danger
    rick danger The further adventures of
    Dec 24, 2005
    10,108
    Oneonta, NY
    A nice se of remus headers just went on the flea market for $300. Kind of pissed I didnt snap them up for future use. Probably could get your money back any time for that price....Yeah, I know ,has nothing to do with wrapping tha cat.
    DakarBlues likes this.
  3. 3rdgeargrndrr
    3rdgeargrndrr Long timer
    Jan 19, 2017
    1,206
    Sacramento
    I have long held concern over any wrapped exhaust on these bikes , especially where the cat sits, is moisture retention and corrosion. YMMV
    Rock709 likes this.
  4. Trailryder42
    Trailryder42 Long timer
    Oct 3, 2006
    1,437
    Amarillo, Texas
  5. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    2,468
    Denver, CO
    Unless you're concern heat on your right foot only then don't bother. Wrap the rear header instead
  6. thirsty 1
    thirsty 1 Rider Supporter
    Feb 9, 2009
    4,075
    Top Hat - Seattle Wa.
    Wrap the whole damn exhaust. :D Use all 50’ feet.
    Oldschoolrocker likes this.
  7. spova
    spova Been here awhile
    Nov 28, 2009
    455
    PNW USA
    Please post up a pic of that heat shield mounted once you get it. Id like to see the coverage it provides on the cat.
    Trailryder42 likes this.
  8. Its not Ginger!
    Its not Ginger! Long timer
    Jun 9, 2016
    1,079
    Oxford, UK
    I went down this rabbit hole myself, the 1290 is a definitive improvement on the 1190 - I had both side by side and measured header and cat temps and the 1290 was significantly cooler.
    I put the insulated rear header on both bikes, although the 1290 was better it was still not great, and the insulated header helped a bit, but I still got heat.
    The problem is not really the cat, it does not get that hot on the 1290, you have to hold your hand quite close to feel the heat radiating, it certainly is not what causes the backs of your legs to melt in high temps!
    After much pissing around, adding some wrap, measuring temperatures and riding around I concluded that the heat issue is down to a bloody great big cylinder and cylinder head protruding under my nuts....
    ...I reckon the only 100% fix is to pull the plug caps off the rear cylinder head ;-)
    #8
    RichardC, twinrider and thirsty 1 like this.
  9. Saltboxlad
    Saltboxlad Long timer
    Jan 13, 2015
    3,129
    Wales, UK
    Or buy a GS:puke2
    #9
  10. kevinA
    kevinA Been here awhile
    Feb 23, 2010
    579
    Southern California
    Thinking of painting the pipe with high temp exhaust paint to seal it and prevent corrosion under a wrap and then putting on a cheap metal exhaust shield before wrapping over that. With people talking about using like 2000 degree resistant heat wrap I was kind of nervous. I took a temp reading after getting home last night and leaving the bike on and the temp of the rear header after a long ride then sitting left on was 480 degrees at the hottest. Thofught it might have been higher. I’ll measure the cat later.
    #10
  11. kevinA
    Feb 23, 2010
    579
    Southern California
    Taking readings from different part of the exhaust, the hot parts are at the header, for several inches at ~480 and fairly quickly cools down to about ~280. Taking a reading on the cat gave a reading about 300 but starting an inche AFTER the cat, the temp jumped back up to 480 range. So the area after the cat for a few inches is where it is actually getting extra hot, not the actual cat. I guess wrapping the actual cat might help it heat up faster to optimum operating temperature if you are concerned about emissions, but after the cat is where its hottest.
    #11
    rick danger likes this.
  12. Trailryder42
    Oct 3, 2006
    1,437
    Amarillo, Texas
    Took my wrap off today and installed this shield by Design Engineering. Shouldn't have the concerns of corrosion over time, as the cat is open to the air. The shield has stand-offs that prevent the shield itself from touching the pipe and air can circulate around it.
    #12
    MaddMatt, Bundu and spova like this.
  13. spova
    Nov 28, 2009
    455
    PNW USA
    Oh nice, that's more coverage than I expected. Looks good.
    #13
  14. DakarBlues
    Dec 12, 2005
    1,538
    Does the cat guard have foil heat shield?
    #14
  15. Trailryder42
    Oct 3, 2006
    1,437
    Amarillo, Texas
    They describe it as "Dual-ply aluminum impregnated glass/woven silica construction". It's not "foil" lined.
    #15
  16. Wheedle
    Wheedle I love inflatable fun!
    Apr 11, 2004
    4,075
    Newnan GA
    Previous owner wrapped mine. I've been contenplating pulling it off and seeing how it goes.
    #16
  17. Its not Ginger!
    Jun 9, 2016
    1,079
    Oxford, UK
    I noticed little difference when I tried wrapping, insulated rear header helped a little and the best mod for comfort was a "cool cover"
    #17
    ls6777 likes this.
  18. Rock709
    Rock709 Been here awhile
    Jun 20, 2012
    513
    Newfoundland, Canada
    I've always heard that wrapping can trap moisture, and the increased temps can bake/crack the pipe and welds. I think some exhaust company void warranty if a wrap is used. My vote is for not to use. YMMV
    #18
    ls6777 likes this.
  19. mokibear
    mokibear Been here awhile
    Nov 13, 2010
    370
    Montrose CO
    Cool cover?
    #19
  20. mwzl
    mwzl mwzl
    Nov 27, 2008
    163
    Cambridge, MA
    Indeed, the Cool Cover makes a significant difference
    #20
