Wristpin bushing play
Discussion in 'Airheads' started by permoljen, Jul 28, 2021.
  1. permoljen
    permoljen n00b
    Apr 11, 2021
    6
    Denmark
    Hello
    When checking for play in the small end conrod-bushing. I find NO play in movement direction. But i can feel i a very little if i wiggle the wrist pin, from side to side. How much is acceptable? And how should i check for play?
    model BMW r65gs
  2. tennessee thumper
    tennessee thumper Long timer Supporter
    Nov 3, 2007
    2,814
    Arkansas Ozarks
    Perm,
    I pondered this on a 90s earlier this year.
    Bearing shells and con rod bolts are not very expensive to replace, if you are in that far to the engine.
    Made sense to replace as part of a new top end/cylinder refresh, in my case.
    There was/is a post on wear/play for those parts somewhere here, if you can find it.
  3. robtg
    robtg Long timer
    Jun 29, 2007
    1,899
    san jose
    Wear limit 22mm+.040 or .8661+ .0016". Measure with micrometer and snap gage or dial bore gage.
  4. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    8,912
    It is supposed to slide side to side (or end to end depending on how you look at it). With new wristpin clips installed (always) it should be minimal but present. If it can rock, not good.
