X-Challenge Air Shock Problems
Discussion in 'Thumpers' started by W8-4IT, Sep 27, 2007.
  1. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    15,153
    Northside Brisbane, Qld Australia
    A heat gun on low setting for about a minute and it was nice and pliable and didn't go out of shape.
  2. johnnydanger
    johnnydanger Dangerous!
    Aug 7, 2006
    62
    Bellingham, WA
    If you're not seeing any metal banding you should be fine. There is a layer of metal mesh in the middle of the material.
    I heated mine over an open flame (my stove!) for 30-45 seconds to get it hot enough to bend. I tweaked it more round, and out away from the bladder. I ended up having to take about 2" off the bottom edge so it didn't touch the rear tire under compression.
  3. Muddler
    Muddler Long timer
    Dec 12, 2008
    1,136
    Dardanup, Western Australia
    Thanks Cruz, hair dryer and kitchen hotplates werent really the right tools. Dont know why my better half was getting a bit antzy?:huh What she doesnt yet realise though, is she has empowered me to visit the hardware store
  4. DiscoDino
    DiscoDino Long timer
    Jan 12, 2007
    1,825
    Lebanon/NYC
    Just heard from my dealer - my rear shock will be replaced under warrantee (~6,300 miles).
  5. Muddler
    Muddler Long timer
    Dec 12, 2008
    1,136
    Thanks for the feedback Cruz & JD. Do you think with the shorter guard you now run the risk of gravel coming off the wheel and damaging the shock?
    On another matter this is a fantastic forum, but Im having a bit of a problem with this thread, messages disappearing and pg9 disappearing. Is this common?
  6. dakardad
    dakardad Not waiting for anyone
    May 22, 2006
    447
    SLC/Boulder, Ut.
    I had a small spot that worried me, this is what I did.
    It was a warm day, concider this if you attempt this fix.
    Like you, I did not like the washer fix, it didn't seem to work right.
    On a warm afternoon-90s, I took the tail of the flap and bent it up, against the tire, so it was pointing against the direction of tire rotation.
    I left it there overnight. In the morning I flopped it back and used a hairdryer to get the right angle plus a little since I figured it would resist my efforts.
    Well, it worked. My tire has cut a small semi-circle in the bottom of the flap, but not enough to let any mud or debris onto the bladder and it does not rub on the bladder.
    I concider it fixed.
  7. olyflyer
    olyflyer Long timer
    Jun 26, 2006
    1,201
    Fremantle, Western Australia, Australia
    Is yours still under warranty Muddler?
    I'm heading in to Auto Classic in a week or 2 to hopefully pick my bike back up and I'll ask them what the deal is cause mine has the same issue and I only had mine about 9 months
  8. Muddler
    Muddler Long timer
    Dec 12, 2008
    1,136
  9. olyflyer
    olyflyer Long timer
    Jun 26, 2006
    1,201
    might see you there
  10. jack splash
    jack splash Two Sheds Super Supporter
    Jun 5, 2004
    3,036
    Pt Pleasant, NJ USA
    Why not, too easy? :D And you didn't spent alot of time and money? :D
    I ride east coast enduros and RallyMoto events, also spend many miles on sandy whooped out sections in the pine barrens and have 9000 miles on my bike since the washers were added, no flat spot, no leak.
    Just wondering what you think is wrong with that fix.:ear
    Jack
  11. olyflyer
    olyflyer Long timer
    Jun 26, 2006
    1,201
    personally i don't think you should have to fix it. I'll get the shop to do it incase it still suffs up, getting the most outta to 2 year warranty ;)
  12. ropedrag
    ropedrag Been here awhile
    Sep 6, 2008
    313
    Seattle
    I replaced my air shock with a Wilbers before I even had 1000 miles on the bike. Not so much that I don't like the idea as much as I did not like the "buck" effect when I grab a handful of front brake.
    Anyway, it sets in the garage unloved. If someones air shock dies and can not get it replaced under warranty, and, doesn't want to shell out the BIG $$ for a coil shock I'll make you a great deal on mine. I'm not actively trying to sell the thing but if I can help someone out I will.
  13. Muddler
    Muddler Long timer
    Dec 12, 2008
    1,136
    Im the same as Olyflyer, if its still under warranty Im want to make BMW fix it. I tried sticking some washers in but didnt really like the look or the fit, so I decided reforming the guard would be better.
    Im sure the washers are quite functional though
  14. Gas Can
    Gas Can Gas Can
    Jul 6, 2009
    41
    San Diego
    Im surprised it isnt already posted here but BMW has recalled the mudgard for the X Challenge. I got the new one installed recently.
  15. Mtrain
    Mtrain free range
    Jun 29, 2009
    446
    yeah, mine was replaced a while ago as well.
  16. tankgirl
    tankgirl Adventurer
    Oct 10, 2008
    14
    Pretoria, South Africa
    just as i pulled up at work this morning it felt like my shock had turned into a block of wood!
    doesn't seem like any air got out but has anyone experienced this and how do i fix?
    thx in advance!
  17. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    5,024
    Los Angeles
    Does the shock still look straight?
    from the angle in the picture you'd swear something inside the bladder got bent or broken.... ;-(
  18. Daithi
    Daithi Destination Unknown.
    Dec 18, 2007
    181
    Cork, Ireland
    There's a hole drilled through the shaft, my brothers XChallenge shock broke there.
    Sent from my SM-G920F using Tapatalk
  19. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    5,024
    Los Angeles
    So how did this end?
    Any news from Tankgirl?
  20. tankgirl
    tankgirl Adventurer
    Oct 10, 2008
    14
    hey, thanks for the concern guys.
    dealer confirmed that the shock is broke, and apparently also discontinued.
    so i am shopping around for a conventional shock to replace the ol' tennisball, which by the way lasted me about 107,000km...
