X-Challenge "Hardless" Guard parts...
Discussion in 'Vendors' started by kutch, Jun 20, 2008.
  1. TymeRider
    TymeRider Been here awhile
    Apr 8, 2005
    394
    Sunnyvale, CA
    If you're OK with the cost and shipping to USA, you can buy a set at HotRod Welding in the Netherlands:
    http://www.hotrodwelding.nl/product.php?id=9
  2. MTDewX8
    MTDewX8 Been here awhile
    Feb 4, 2006
    505
    I only stopped making them because I moved from where I had the hook up.
    but if you take the files to a water jet place with material they should be able to make them for you.
    that is all I did.
    best of luck
  3. mtncrawler
    mtncrawler Long timer Supporter
    May 17, 2003
    1,626
    Fort Collins, CO
    Yep, thanks, I was just trying to find a local/less expensive alternative.
    Thanks, no worries, I already have quoted the work locally. I just wasn't going to pull the trigger if someone else had an order in the works. As you know you need to have sufficient interest to make it economical. I can live with my hand plasma'ed set now and can make another out of Stainless when ready.
  4. Niedz
    Niedz Been here awhile
    Oct 2, 2010
    648
    Bucks County, PA
    if you just want a set for yourself; a hacksaw, hand drill, and some files would definitely do the trick.
  5. MJS
    MJS Long timer
    Dec 23, 2005
    2,956
    Off the grid in San Felipe, Baja
    Instead of water jet you could see if someone with an EDM machine could make them for you. My local WJ guy wants way to much $ for small runs. I have a local industrial saw shop that does sharpening and also has an EDM machine. They charge by the time it takes to cut per inch. For small runs or one-offs this has been cheaper than WJ.
    For steel I have a local guy with a cnc plasma that's even less $.
    Just a suggestion.
    Mark
    Stromius likes this.
  6. Fasco
    Fasco Adventurer
    Jul 25, 2014
    58
    Northern Italy
    Hello there. Any chance to get the drawing/measures fo the protection parts?
  7. MJS
    MJS Long timer
    Dec 23, 2005
    2,956
    PM sent
  8. SaTaNaX
    SaTaNaX Forero Maniaco Compulsivo Supporter
    Jan 9, 2007
    66
    Murcia, Spain
    I need it too, thanks in advance.
    Saludos desde EspaƱa :freaky
  9. Zeus99
    Zeus99 Been here awhile
    Apr 3, 2015
    186
    Croatia
    Are the drawing/measures for the protection parts still around?
    If there's a chance to get them that would be awesome! :)
  10. Niedz
    Oct 2, 2010
    648
    Bucks County, PA
    email me ill shoot em over
  11. kutch
    kutch That fell off where?
    Jul 15, 2005
    586
    Here, There and trying to be Everywhere.
    uski and andrewgore like this.
