Xenon lights installation - F800GS
Discussion in 'Parallel Universe' started by narcosis, Sep 12, 2009.
  1. narcosis
    narcosis GS800
    May 28, 2009
    96
    Sydney OZ
    Last week, I got a nice birthday present for my ride from a couple of friends - .​
    A kit of Xenon lights :clap
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" o:preferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <v:path o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" style='width:415.5pt; height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge001.jpg" o:title="P9120010"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    The box contains 2X - Xenon light bulbs, 2 thin ballasts (the silvery metal part) and all the cables. (The photo is showing only one ballast)​
    <o:p> </o:p>​
    So, as soon as the birthday hangover ended :freaky, I got to the job of actually installing them on my 3 months old GS 800.​
    <o:p> </o:p>​
    I had David help me as he is well experienced in installing all kinds of nice things on all kind of rides :wink:
    <o:p> </o:p>​
    The first thing was to find a place to attaché the ballasts at the best possible spot so it wouldn't get in the way of any cables or the steering.​
    <o:p> </o:p>​
    We started by taking off the side fairings and the beak.​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1026" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge003.jpg" o:title="P9120004"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1027" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge005.jpg" o:title="P9120006"/> </v:shape><![endif]--><!--[if !vml]-->
    <!--[endif]-->​
    <o:p> </o:p>​
    This clears some working space and lets you look around for the best place to attaché the ballasts.​
    <o:p> </o:p>​
    We have decided to attaché them just behind the lights…​
    <o:p> </o:p>​
    The steering frame has a kind of a metal bracket which holds the dashboard. ​
    This bracket looks like its just ready to have something attached to it :clap
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1028" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge007.jpg" o:title="P9120007"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    We did a dry run and found this place to be perfect.​
    There are some other places that look good for attachment but check your cables length and make sure the steering is not obstructed in any way side to side.​
    <o:p> </o:p>​
    If you think of getting a kit – try and get the thinnest ballasts available - this will help to tuck them away…
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1029" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge009.jpg" o:title="P9120011"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    Next, we used double sided sticky tape to attaché each ballast to the igniter​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1030" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge011.jpg" o:title="P9120014"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1031" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge013.jpg" o:title="P9120015"/> </v:shape><![endif]--><!--[if !vml]-->
    <!--[endif]-->​
    <o:p> </o:p>​
    Next, get the bulb house ready.​
    Taking the bulb caps/covers off is pretty easy - just twist it.​
    <o:p> </o:p>​
    These caps need to be drilled, to make way to the cables to go out and attaché to the ballasts. The caps already have dents in them which are (amazingly) in the right size I needed. :D
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1032" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge015.jpg" o:title="P9120019"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    Replace the original bulb with the xenon one and get the cables out through the drilled opening at the back of the cap.​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1033" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge017.jpg" o:title="P9120024"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    When both bulbs have been replaced, the caps can be set back to their original place.​
    We got all the cables coming out of the cap and wrapped them nicely.​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1034" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge019.jpg" o:title="P9120025"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1035" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge021.jpg" o:title="P9120026"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    Hooking the ballasts was the last thing left.​
    We attached both to each other with screws going from one side to the other while also going through the (nicely ready) holes in the steering bracket.​
    It's a bit hard to noticed the screws but they are there :deal
    <o:p> </o:p>​
    The cable tie was just for extra security.​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1036" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge023.jpg" o:title="P9120027"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1037" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge025.jpg" o:title="P9120028"/> </v:shape><![endif]--><!--[if !vml]-->
    <!--[endif]-->​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1038" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge027.jpg" o:title="P9120031"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    Last check to make sure the steering is not disturbed in any way, a check to see the lights are actually working, and fairings back up.​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1039" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge029.jpg" o:title="P9120033"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1040" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge031.jpg" o:title="P9120034"/> </v:shape><![endif]--><!--[if !vml]-->
    <!--[endif]-->​
    <o:p> </o:p>​
    And from the other side:​
    <!--[if gte vml 1]><v:shape id="_x0000_i1041" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge033.jpg" o:title="P9120036"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    <!--[endif]-->​
    <o:p> </o:p>
    <o:p>[​IMG]
    </o:p>​
    I don’t have photos to show the difference in light strength or width but I already had a night ride and it's worth every cent (Of the people who got me this as a gift) :D
    <o:p> </o:p>​
    This whole thing took about 2-3 hours and included going through a six pack during a summery <st1:city><st1:place>Sydney</st1:place></st1:city> day :freaky
    (No riding was done through and/or after this activity)​
    <o:p> </o:p>​
    While I got these photos on, I'll share my SW-Motech crash bars and Toratech engine and oil filter protectors…​
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1042" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge035.jpg" o:title="P9120018"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    (These already paid for themselves on the first bike drop while doing some off roading)
    <o:p> </o:p>​
    <!--[if gte vml 1]><v:shape id="_x0000_i1043" type="#_x0000_t75" style='width:415.5pt;height:311.25pt'> <v:imagedata src="file:///C:\DOCUME~1\zac\LOCALS~1\Temp\msohtml1\01\clip_ima ge037.jpg" o:title="P9120017"/> </v:shape><![endif]--><!--[if !vml]-->[​IMG]
    Any comments or ideas for future upgrades are welcomed :)
  2. Y E T I
    Y E T I Unpossible
    Apr 26, 2007
    8,521
    San Diego
    Looks good, nice clean install. Eventually I'm going to do my low beam that way. I want to keep the high beam "normal" to maintain the "flash to pass" capability.
  3. narcosis
    narcosis GS800
    May 28, 2009
    96
    Sydney OZ
    I thought the low/high beam flick would be a problem but apparently is working fine.
  4. PackMule
    PackMule love what you do
    Aug 8, 2005
    19,493
    New Hampshah
    Nice install. :thumb I presume the units are totally weathertight?
    How long does it take the high beam to come up to brightness (at night) when you flick it on? :ear
  5. alexcorral
    alexcorral Long timer
    Sep 8, 2009
    1,666
    Danbury, CT
    What's the make of your kit?
    F800GS bulbs are H&s right?
  6. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,931
    Nice work, thanks for the pictorial! Nifty place to attach the ballasts, which are practically out of sight :thumb
  7. narcosis
    narcosis GS800
    May 28, 2009
    96
    Sydney OZ
    The bulbs are H7 and the kit is "Tai Cahng Xenon HID Head Lamp"
    When flicking to high beam it does that instantly but still takes the lamp about 1-2s' to get to full brightness.
    I think it's not a big deal as the high beam on the GS is achieved by the reflectors around the bulb - so the "high beam" effect is instant even before reaching 100% brightness.
    The units are fully weather proff and as you might see in the photos, there is a rubber guard which sits nicely in the drilled cap.
    We though initially to put some silicon around it but it fits so nice, doesn't seem like it needs any help against rain.
  8. alexcorral
    Sep 8, 2009
    1,666
    Danbury, CT
    Does it sell as specific for motorcycles?
    I found (locally) one of these chinese HID conversion kits (35W) that sells with any bulbs you might need for $80. Not motorcycle specific though...
    #8
  9. narcosis
    narcosis GS800
    May 28, 2009
    96
    Sydney OZ
    The thin ballast kits are being promoted towards motorcycles but it is not a model specific.
    The only bike specific you need is the model of your bulb.
    I got H7 bulbs, as this is the GS 800 bulb model.
    #9
  10. nomadonwheels
    nomadonwheels Adventurer
    Mar 12, 2009
    29
    Sydney
    Hi Narcosis...thks for the installation report, I have the same kit and its been sitting in the box for a few weeks...I must get it out and have a crack at it!....I also have the Stebel Natalilus Ear cannon horn to install as well.....your not doing a install report on one of those are you??:rofl
    #10
  11. bikerfish1100
    bikerfish1100 Adventurer
    Jun 13, 2003
    93
    Loveland CO
    with HIDs, your "flash to pass" will continue to operate correctly. the problem is that those short bursts of on/off will (supposedly) dramatically shorten bulb life. that is the reason for the admonition against using f-t-p with HIDs.
    that said, i have HIDs on my R11S (love 'em!), and have occassionally used my f-t-p to signal other vehicles, and i have over 6 years of usage on my Polarion kit, no replacement parts as yet. generally, i just ride with my hi beams on during the day, and there's no need to f-t-p, as many cars just pull over voluntarily for me. i think it's so that they can investigate why their rear-view has suddenly become a puddle of molten glop on the seat of their car.
    #11
  12. ncooper
    ncooper starting again
    May 6, 2007
    101
    Harrisonburg, VA
    That is a very clean installation, thanks for taking the time to write that up!
    #12
  13. narcosis
    narcosis GS800
    May 28, 2009
    96
    Sydney OZ
    No, I dont have any install report on a Stebel, but let me know when you have yours online ... It's a little piece of equip I'm looking into and would love to see where you have decided to put it ...
    #13
  14. PackMule
    Aug 8, 2005
    19,493
    New Hampshah
    I realized while out riding last night that having an HID high beam on this bike isn't as much of an issue as my last bike, where hi/lo were combined in one bulb. Even if it takes a few seconds to hit full brightness, you've still got the full effect of the low beam in the mean time. Duh.
    The number of lifetime on/off cycles may do it worse than the always-on low beam, but to me I think the extra light will be worth it.
    Say you're on a long trip and lose one of the HID's for some reason. How easy would it be to reinstall a regular bulb to keep you going? Other than the hole cut in the back of the housing "cup", this mod is totally reversible, right? :ear
    #14
  15. soyanarchisto
    soyanarchisto Long timer Supporter
    Sep 1, 2005
    6,758
    Sunny PDX
    I have been thinking about this install on my bike as well. When I had HIDs on my airhead and one bulb went out (due to a short in the wiring--my fault), the stock bulb just plugged right back in. Simple.
    #15
  16. narcosis
    narcosis GS800
    May 28, 2009
    96
    Sydney OZ
    As Soyanarchisto mentioned, all it takes is sliding in the old bulb for it to work in case you lose the HID one.
    I used the space at the rear (just underneath the rear seat) to have my spare battery (and first aid kit).
    #16
  17. PackMule
    Aug 8, 2005
    19,493
    New Hampshah
    Spare battery?
    #17
  18. narcosis
    narcosis GS800
    May 28, 2009
    96
    Sydney OZ
    :D - my spare bulb of course
    #18
  19. PackMule
    Aug 8, 2005
    19,493
    New Hampshah
    Ahh! That makes more sense. :D
    #19
  20. DolphinJohn
    DolphinJohn Caveman
    Mar 17, 2007
    4,039
    Nature Coast, Florida
    Thanks, narcosis.
    After seeing this install and getting tired of looking at my big-ass ballasts sitting in plain view, I got a new set of HID's from VVME.
    They were only about $60-70
    They have the slim ballast, they look just like the ones in this thread. I went with the 4300 color to stay as white as possible.
    I basically followed narcosis' install, and now have a nice clean instrument cluster.
    The only issue I had was trying to find the right screws and nuts to work in the limited space on the ballast holes.
    I ended up just using zip-ties. They are very tight and secure so I think it will be ok.
    Didn't take any pics because I was rushing to finish before dark, as I don't have a garage.
    I will get some pics up soon.
    #20
