XL500Scout- Restomod
Discussion in 'Some Assembly Required' started by shinyribs, May 12, 2018.
  1. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,549
    Oakland, CA
    Is RFY the brand? Ebay shocks, I assume?
    Nice work on the piston. I think I see that you chamfered the edges of the ports? Good. Sharp edges are how you get cavitation. Did you do the work on a mill?
    For the peanut gallery, one of the limitations of the ability to adjust damping via the shim stacks is the ability to flow through the piston. Which is why the original piston is so comically bad, and the new piston is an improvement.
    If you have a rotary table and wanted to commit about 300% more effort, you could do pistons with "wagon wheel" trapezoidal ports to get more open area on the pistons.
    Also, rebound is a fixed value that only needs adjustment when the oil degrades in velocity (the only force inputs for rebound are the spring and bike weight.) If you iterate, try reducing rebound port area until it becomes a problem. That gives up more piston real estate so you can bias the port area towards the compression side for a wider range of adjustability.
    Bowler and shinyribs like this.
  2. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    6,285
    The South
    Thanks man, I appreciate that.
    AK650 likes this.
  3. shinyribs
    Sep 24, 2011
    6,285
    The South
    Just turned the majority of the piston on the lathe, did the ports with a drill press. I don't own a mill...yet!
    Yes, the RFY are the shocks you see on eBay. That is the actual brand name of them.
    If you look close at the should you'll notice the compression stack isn't really a shim stack at all. It's a wavy washer and larger, solid washer with scallops on the ID. So the each wavy washer would hold the scalloped washer up to the valve to block the outer ports. The fluid had to flow through the wavy washer, through the scallops in the washer and then through the inner series of ports. Then, in the reverse direction(compression), the wavy washer would flatten to allow fluid through the outer ports. The tension of that wavy washer was the shim stack. :lol3
    The way I have it now, the fluid has to flow around the OD of the compression shim stack and get in to those straight grooves you see cut in to one side to access the inner ports for rebound. It's cheesy, but I was running out of room!
    AK650 likes this.
  4. Roadracer_Al
    Aug 5, 2007
    2,549
    Oakland, CA
    Very interesting setup! Orifice damping but with a directional cutoff. Tricky. Clever. If it works well enough, that's all you need.
    AK650 likes this.
  5. shinyribs
    Sep 24, 2011
    6,285
    The South
    True, but it wasn't working well, thus the new piston. The other piston was so loose in the bore I think most of the oil was just blowing around the outside anyway. But yeah, the check valve approach was kinda neat. Not a lot of options with a 1" diameter.
    Roadracer_Al and AK650 like this.
  6. Roadracer_Al
    Aug 5, 2007
    2,549
    Oakland, CA
    I wonder if a 3D printed piston would work or if the forces are too high...
  7. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    700
    Carool, NSW
    They can 3D print titanium now $$$$
    Fast Idle and AK650 like this.
  8. DeepBarney
    DeepBarney International Bumbler
    Jan 7, 2014
    3,335
    Wichita, KS
    Yeah, PA-66 nylon should be up to the task. But like mentioned above powder metal printing is readily available too.
    AK650 likes this.
  9. shinyribs
    Sep 24, 2011
    6,285
    The South
    The shims bend pretty easily, so I don't think the forces are very high, but I'm not sure if you would have issues with a "plastic" valve flexing or not. In my imagination, I think the two biggest issues to overcome would be a surface finish smooth enough to seal against the shims properly and a body sturdy enough to also seal properly ( not flexing) causing erratic damping. I'm sure a solution could be come up with. That would definitely open up some possibilities with port designs!
    AK650 likes this.
  10. shinyribs
    Sep 24, 2011
    6,285
    The South
    My ignition switch plastic clip holdy in thingys got damaged in a crash and it let the key kinda jiggle around in the dash. It was pretty annoying. I never use the key ( it's literally just a kill switch- it doesn't turn anything "on") except for pulling the key out in public places, but it was getting on my nerves.
    I didn't want to just glue it in place, so I made a little bezel to retain the switch against the dash plate. Turned up a ring on the lathe to match the contours of the switch, welded it to a piece of rod, then worked it down with files. I'm pretty pleased with the outcome! I need a long night of quiet shop time. This was just the project to do the trick. No more jiggling :)
    I have some other projects in the works. A fork brace for this bike ( test ride was VERY good), a cartridge conversion (which may end up being adaptable to nearly ANY fork), and some other odds and ends...but it felt nice making this little piece. It's been a joy just looking at it getting on and off the bike. Nobody will ever know the hours put in to it. The next guy who ends up with this bike probably won't think twice about it. I don't know why that makes me laugh. :D
  11. oic
    oic Business is ALWAYS personal
    Sep 6, 2014
    2,166
    Directly under the earths sun.
    AK650, shinyribs and DeepBarney like this.
  12. dbarale
    dbarale Squiddly slow
    Oct 20, 2008
    2,752
    Western NC
    Thanks for the idea! I have the same issue on my DR350 and that’s a great fix. Off to the garage to look for some scraps of aluminum.
    JagLite, AK650 and shinyribs like this.
  13. shinyribs
    Sep 24, 2011
    6,285
    The South
    That's great :lol3
  14. shinyribs
    Sep 24, 2011
    6,285
    The South
    Cool! Please post pictures of what you come up with.
  15. shinyribs
    Sep 24, 2011
    6,285
    The South
    This bike has been giving me fits past couple weeks. Can't really blame the bike, though. Carb'd bikes don't tolerate dirty fuel tanks, and boy was my tank bad. The Kreem liner ( not my fault!) started failing and was releasing itself and lots of rust with it. Between fuel issues and a sticking choke, I didn't have much faith in the bike. The stuck closed choke would just leave you stranded, or having to pull the airbox roadside so unstick it :dirtdog Then the rust started clogging the works. Ride over a rough patch and end up with a plugged pilot jet...again :becca
    I've cleaned a fair few tanks in my time, but never with "perfect" results. Vinegar, electrolysis...noting really seemed to work well. So I did some research and gave it an honest effort this time. After battling flash rust on initial attempts, I now have tank cleaning down to a science. :lol3
    Here's the portions of the liner I was able to pull out. That largest piece is about 12" x 12".
    An idea of what we were dealing with.
    I whipped up this little deal to scrub off the majority of the loose stuff. It worked really well! Piece of 1/2" EMT ( electrical conduit) and a 2' length of 5/16" jacketed cable. The jacket keeps the cable from unwinding on you. Just trim off the end of the jacket to fray the cable out. The hook in the EMT lets you steer around inside the tank easily.
    Even after using the Tank Snake, still had lots of rust and Kreem hanging on to stuff though. But here's the process that worked best for me.
    1- Slosh MEK around inside. Apparently MEK is the full strength version of Acetone. MEK eats Kreem like it's angry at it.
    2- Dump out MEK and give that a quick rinse out with mineral spirits- Just because MEK is so nasty and will melt paint instantly
    3- Slosh around some Muriatic acid. This stuff is brutal, but won't touch paint. It'll eat the rust in a matter of minutes.
    4- Dump out the Muriatic acid an replace with phosporic acid AKA Prep and Etch from Kean strip.
    5- After dumping the Muriatic acid you will get flash rust within moments. Prep and Etchwill remove the flash rust on contact.
    6- Move the tank around ( or completely fill it) with full strength Prep and Etch to keep everything coated.
    7- Dump the Prep and Etch and let air dry
    8- Coat with Marvel Mystery Oil
    *Be sure to neutralize the Muriatic if you are disposing of it. I dumped my acids back in to their containers since they are still effective to be used again*
    Leave the Prep and Etch in place for a few hours. It removes the flahs rust instantly, but it needs time to fully convert it. Let it work or the flash rust will return. After a few hours, drain the Prep and etch and sop up any puddles inside the tank with rags. Doesn't need to be completely dry. You want a film of Prep and Etch as it will create a phosporic layer that actually inhibits rust. After it dries, slosh some Marvel Mystery Oil around inside the tank.
    Like new :clap
    Petcock bung. This was nearly completed covered in Kreem before. Spotless now!
    Note the kinda chalky looking line right at the seam line? That's where the phosporic acid did it's magic, converted the rust and left behind a light, gray residue. No flash rust! Coated that with some light oil and left it over night. She's now all back together with a full tank of gas and fresh lines and filter. This will give me a huge confidence boost in this bike's reliability again.
    I didn't take pics once I got my hands in all the chemicals, but I also completely disassembled the fuel cap. It has a multi layer plate system that creates a really clever slosh-proof vent. But it has a small hole that can rust closed easily. Had to derust and treat that as well. So, if you have one, take a look at it.
    Happy trails folks, and keep your fuel tanks clean! :ksteve
  16. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,330
    Denmark
    Great job =)
    shinyribs likes this.
  17. JimRidesThis
    JimRidesThis Local celebrity
    Jan 2, 2012
    1,171
    Cumbria, UK
    Very thorough, it really does look like new inside! Hopefully that should be the end of your fuelling problems :thumb
    Perhaps you should get ‘Tank Snake... the motorcycle restorers flexible friend’ on the market. :D
    todd900ss and shinyribs like this.
  18. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    4,509
    Clark Co, Wa
    Fantastic job!!! I love homebrew solutions that work this well. :clap
  19. shinyribs
    Sep 24, 2011
    6,285
    The South
    I can't take credit for the Tank Snake. A buddy on another forum came up with that many years ago. I'm sure glad he shared the idea, though, because it's a lifesaver!
    JagLite and JimRidesThis like this.
  20. shinyribs
    Sep 24, 2011
    6,285
    The South
    Got a package from @Brtp4 earlier today. Says it fits a Kawi, but that never stopped us before.
    Activation rod was a touch long, but everything else looked good. Easy job!
    Bit tough to see, but the slave cylinder is tucked in there. Figured it wouldn't hurt to leave the cable in place for a backup in case something goes kaput. If I travel far from home I'll just toss the stock clutch perch in the toolbag. Doubt I'll ever need it, though. Very reliable little units.
    Ready to rock! Feels soooo much better than stock. $52 well spent. Thanks again, BP :beer
