XR250 build
Discussion in 'Hacks' started by Pete-NZ, Aug 16, 2011.
  1. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    Idea !
    Build a light adv hack for hunting / camping gear / guns:clap
    Has to be easly removeable "3 bolts"
    No altarations to the bike other than a sub frame.
    Bike has to beable to still lean...
    So start with the sub frame.. prob the hardest
    part of the whole build as yer have design constraints
    from the bike.. So I ended up with a sub frame I can live with..
    started on a slideing limiting strut to stop the bike falling over
    when parked but still let the bike lean..
  2. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    On the bike
  3. AceRph
    AceRph Be like Tom
    Jan 12, 2003
    24,876
    Kingdom of Gav
    :lurk
  4. sidecarstar
    sidecarstar Adventurer
    Jul 12, 2009
    17
    Middleburg,PA
    cool I'm going to do one with a lawn sweeper for my TTR110 pit bike. Why not make the task fun?
  5. SETHZILLA!
    SETHZILLA! n00b
    May 27, 2009
    5
    Looking good so far Pete, can't wait to see more pics. I am getting ready to build the same style of setup on my XR650!
  6. halflive
    halflive Been here awhile
    Apr 14, 2009
    659
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///D:%5CDOCUME%7E1%5Cklm10162%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:Arial; mso-fareast-font-family:"Times New Roman"; mso-bidi-font-family:"Times New Roman"; mso-fareast-language:EN-US;} span.EmailStyle15 {mso-style-type:personal; mso-style-noshow:yes; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt; font-family:Arial; mso-ascii-font-family:Arial; mso-hansi-font-family:Arial; mso-bidi-font-family:Arial; color:windowtext;} @page Section1 {size:8.5in 11.0in; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Looks like you can do some pretty welding. But please, for my sake. Weld some gussets on either side of the mounting struts. The weld would cope with a static force, but the length of the strut gives some mean force sideways, pulling and pushing from left to right.<o:p></o:p>
  7. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    Yes there will be gussets welded in...
    Hope to get the frame tacked togeather 2morrow at long last....
    keep getting side tracked...
  8. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    Keep getting side tracked...
    #8
  9. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    Basic frame tack welded togeather...
    steel is 25x25x3 RHS..
    The swing arm mount has to be shortened
    yet...
    #9
  10. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    A bit more progress...
    #10
  11. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    and this one..
    #11
  12. D.Bachtel
    D.Bachtel Been here awhile
    May 3, 2009
    510
    Nipomo ,,,, Where HWY 101 and HWY 166 collide!
    Looks to be well thought out Pete, and well constructed.
    I'm just trying to grasp the concept of a leaner in an off road situation or even an on road situation.
    Is it like having a folding tagalong dolly attached to the side of your bike?
    I want to see video of you getting light on some whoopy terrain ...:eek1
    Don in Nipomo
    #12
  13. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    A leanning car on a dirt bike is really a unknown..
    I have not seen another unit.. So I thought I would
    give it a go...If it proves to be no good I can relpace
    the slideing limiting struts & soilidly mount it...
    Pete
    #13
  14. D.Bachtel
    May 3, 2009
    510
    OK, you go first.. I'll watch.
    Don in Nipomo
    #14
  15. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    5,111
    Long Beach, California
    Owning an XR650R and having had the pleasure of riding a 'normal' hack, I'm really curious about this build and will be following it closely.
    I won't have to worry about catching air, much, since it's set up for the street, but I wonder if a damper of sorts would keep the chair from extending too quickly should you catch air in an off road situation. It should keep the chair from just dropping away but not prevent leaning and if you can find one that is adjustable you can fine tune it for a given situation.
    #15
  16. SETHZILLA!
    SETHZILLA! n00b
    May 27, 2009
    5
    Hey Don I'm gonna be building my own with Petes design as my starting point.
    When I start my build I'll get ahold of you. I live up in Santa Margarita, so you can come check it out.
    #16
  17. SETHZILLA!
    SETHZILLA! n00b
    May 27, 2009
    5
    Pete - looking good so far. Giving me alot of new ideas on my own leaner!
    #17
  18. ADpete
    ADpete Been here awhile
    Jul 4, 2006
    396
    Canbrerra Australia
    Looks Good so far . I have a ktm 640 lc4 and your breaf for this could aply to mine so I'll be interested to see how it rides off road (how rough it gets ) and on road .
    #18
  19. dakdakdave
    dakdakdave an older,wiser noob!
    Apr 20, 2009
    400
    Brisbane, Australia
    maybe not totally unknown.Australian trials championships 2010. My apologies to the original photographer.
    #19
  20. Pete-NZ
    Pete-NZ Long timer
    May 8, 2011
    1,371
    Thanks..:clap
    thats the first piviting dirt side car I have seen....
    Now I have a place to start a search for info...:ear
    #20
