1. eNewsletter Sign Up
Xr250lc
Discussion in 'Some Assembly Required' started by fiep, Aug 31, 2011.
  1. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    no relay, so far only a couple 100 miles with the light
    but
    why would the LED fry my regulator?
    yes, I admitt being electrically very little knowledgeable
    but willing to try and learn
    #61
  2. Tanshanomi
    Tanshanomi Your Favorite Uncle Supporter
    Jul 22, 2009
    2,704
    Heart of America
    Doesn't your DMV require a DOT high and low beam?
    #62
  3. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    I do?
    #63
  4. NortwestRider
    NortwestRider TRIPOD ADVENTURER !!
    May 25, 2008
    5,138
    3.7 miles North of Hell...SEATTLE....
    I had 3 LED lights on my Vstrom and i had charging problems.I put in a mosfet RR and it didn't help. I replaced the stator and it didn't help. I tested the new RR and it was fried ( worked good when I got it ). I finally talked to electrical engineer and he told me that without relays the LED's use so little power that they put power to ground( which is what EVERYBODY said was happening but could not figure out how ). I took off the LED's and put the stock RR back on and so far NO charging problems!!
    #64
  5. torgo
    torgo Adventurer
    Jul 28, 2007
    91
    Great build, just found the thread and read the entire thing.
    Regulators on most bikes are just shunts (short circuits) to ground and that is how they regulate the voltage. That is why they have fins to keep them cool. If you reduce the electrical load by replacing all your lights with low wattage LED's then the Regulator has to conduct more current to ground and that heats it up more. If the cooling fins can't disapate the heat then it burns up.
    Keep up the good work. :clap:clap:clap:clap
    #65
  6. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,023
    Reading,Pa
    Nice build,lurkers appreciate things even in an empty theater !
    Aren't there r/r setups that don't shunt excess to ground ? wasteful and costs power !
    #66
  7. Mollygrubber
    Mollygrubber Eschew obfuscation
    Feb 2, 2010
    1,670
    Vancouver, BC
    Inspirational work on my kind of budget! Nicely done, you make it look easy. :clap
    #67
  8. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    so far bike runs, light works, except for one time, when one of the stock plugs on the dimmer unplugged itself
    in the meantime:
    blasted, found and oldered shut
    the lil' black boch next to the chocke is a dimmer,
    thanks Shean-O and Veho :bow
    if nothing else she is a great conversation starter
    oh one more picture:
    a little OK, a lot blurry, but my #$%@ camera would not focus on the tire
    after the first ride in the mountains
    the stupid knobs bent so far they wear on the inside
    ordered a set of Duros 903/904
    Cycle Gear had the rear on backorder for weeks now
    as soon as I have both Else will get the more streetworthy Duros and the Kendas go on my next project, an 86 XR250
    OK, one last piece of information
    finally got around to put her on my bathroom scales
    back 66
    front 60
    in Kg with a full tank of gas
    not a slimline, but bearable
    #68
  9. DC950
    DC950 Microadventurer
    Mar 1, 2004
    3,509
    Seattle and Las Cruces, NM
    excellent. Thanks for writing all this up.
    #69
  10. 1Bonehead
    1Bonehead Fearless of Falling
    Sep 30, 2010
    1,124
    Marylanstain
    Where did you get the headlight? Dimmer?
    #70
  11. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    headlight ebay.de
    dimmer Amazon.com
    #71
  12. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    once again I changed my mind about what I want my XR250LC to look like,
    got to be slimmer, trimmer ...
    so out with the big ... my Euro-import has to go
    up for sale is my LED headlight
    here: http://www.advrider.com/forums/showthread.php?t=751496
    already have the next edition, more modern look
    the headlight with a smile
    #72
  13. malokam
    malokam Been here awhile
    Jul 13, 2011
    456
    Piedmont, NC
    :lurk
    I saw the ad in the flea market. But I am curious as of which one you are replacing it with.. Any pics of the replacement setup?
    #73
  14. Tukata
    Tukata ADV Demo Rider
    Jun 13, 2009
    1,770
    Canton, GA
    Sanjoh ( if you can ever get him to answer a pm,email :evil) makes some killer LED lights.
    Plus he test them to survive real world abuse, I mean use
    #74
  15. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    no offence, but Sanjoh makes auxilliary lights
    I even have some from him
    but that is not my plan
    I am thinking this headlight and an XR-off-road taillight,
    smallish LED turn signals ...
    #75
  16. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    8,154
    ADVmonster, CFL, WNC
    Polisport LED sounds good and probably works fine for daytime rding.
    This is about go on my Husky for some abuse. 3000 lumens in this configuration, includes dimming capability for low beam, full power on high beam. Oh and it only pulls 20watts on full power. DC only for now.
    #76
  17. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    I reserve the right to be bitchy
    #1 beauty is in the eye of the beholder
    #2 if you want to show your prototype fine,
    please start your own fred
    obviously not for sale on your page
    my bike is not a Husty
    and
    my bike will get a smiling face
    deal?
    thank you
    #77
  18. sanjoh
    Feb 13, 2007
    8,154
    It's working:D
    Didn't say anything about sale etc. I'm a motorcyclist that likes to ride his plated dirtbike at night, I need a lighting solution that enables me to see.
    Seems you might have the same need?
    I'd really like to hear more about why you took the led headlight off your bike:ear Is it just the "look"? I doubt you will find anything that is slimmer or trimmer than the stock setup, although it certainly doesn't have a smile:D
    Happy New Year:freaky
    #78
  19. fiep
    fiep Long timer
    Mar 9, 2005
    1,914
    GA
    :rofl
    what stock setup :rofl
    you can sure come up with something trimmer than NX250, can you?
    how about XR250L? pretty sure you can
    stock XR250R is kinda trim but at the same time awfully dim
    no, I don't care much about seeing at night
    this bike is a toy not a commuter
    the Dakar has Solistes, the Tiger has Solistes,
    Elsie just needs to be seen
    as I said: beauty is in the eye of the beholder :freaky
    #79
