XR400 swingarm bolt
Discussion in 'Thumpers' started by DrLewall, Dec 11, 2009.
  1. miguelitro
    miguelitro I like the ads, in fact, give me more ads.
    Nov 4, 2008
    2,353
    San Diego, CA
    I dealt with this on an xr650r and kept dumping pb blaster in there and then riding and racing the bike. One time, after 6 months, i went to put more pb blaster on it and the damn thing near fell out!
    Mike
    #81
  2. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    24,747
    Burbank CA
    when i took mine out, i had the same problem. the issue is not the swing arm bolt is seized, but there are sections of the bolt that is rusted and built up on the surface, thus the diameter is now too big to go through the bearing or bushing. the more i pushed it, the rust just get jammed inside and made it more difficult to slide.
    i used lots of liquid penetrant, wd40, etc., then combination of hammering and impact wrenching until the rust powder dripped down. it took me 3 nights.
    try not to mushroom the bolt end. i used a driver (similar to a punch with a step) that went inside the hole with a little shoulder resting against the bolt tip.
    the swing arm bolt was pitted and thrashed.
    good luck!
    #82
  3. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    14,895
    Out in the NM Dez somewhere
    I've welded a slide hammer onto the head of a stubborn swingarm bolt to get it out. They work pretty well and compared to beating it out from the other end, the threaded area doesn't get deformed which has the potential to compound the removal problem. Used a 3/8 rod about 16" in length with a 3~5# weight. Unlike a hammer, you get a solid concentrated hit each time, doesn't tear up the frame where you miss with the hammer ether. Add lots of PB a couple times a day of a period of 3 or 4 days before hand.
    #83
  4. DrLewall
    DrLewall Master of bating
    Aug 20, 2008
    46,421
    Banned Camp
    Excellent idea! :thumb
    I am gonna quote this in the first post so that those looking for help, may avoid the nitemare
    #84
  5. RideFreak
    Apr 17, 2009
    14,895
    It's all about sharing the knowledge, Happy New Year!
    #85
  6. ImaPoser
    ImaPoser adventure imposter
    Jun 9, 2002
    17,861
    Cincinnati, Ohio
    So. Is the general consensus to try to get it out and keep it lubed, but if it's stuck, to just let it go and deal with it when it becomes unavoidable? I swapped out my rear spring a few weeks ago. everything else came apart no problem. Swingarm moves free, no issues, but I tried taking it out with no luck. Hit it with an impact a couple times and tried getting some PB blaster in on it, but nothing. I went ahead and put it all back together and figured I could find a way to just work on it over time, but I don't really see a way to get something like PB blaster to soak in and do any good without laying the bike on it's side and letting it work its way in. :scratch
    #86
  7. MartiniUp
    MartiniUp Long timer
    Jul 14, 2010
    3,528
    TX
    :thumb:thumb
    #87
  8. Purch23
    Purch23 Dirtbiker
    Nov 20, 2013
    321
    Oxford, CT
    Same with my bike. Swingarm moves freely. I say yes just leave it for now until it becomes an unavoidable issue.
    #88
  9. Purch23
    Purch23 Dirtbiker
    Nov 20, 2013
    321
    Oxford, CT
    How about this? Wrap safety wire around the end of the swingarm bolt and loosen the swingarm nut backing it into the safety wire. Maybe try and duct tape the nut and wire for added support so the nut doesn't fall off one day while riding. PB blaster the SA pivot points regularly. Keep riding the bike like that. Tension on the SA bolt and pivot points may eventually brake it free if the PB blaster penetrates well enough.
    Thoughts?
    #89
  10. RideFreak
    Apr 17, 2009
    14,895
    The problem is the area where the bolt goes through the motor, it corrodes which is like it's growing in diameter. I'd deal with it or plan on just leaving it forever, I doubt it's going to free up to where it gets easier.
    Another removal method that might work is to get it in a press, with force applied to the threaded end, spin the bolt with an air wrench at the other end at the same time, maybe throw some heat at the engine cases too. The combination of some serious pressure and rotation might do the trick.
    #90
  11. mekros
    mekros Adventurer
    Oct 5, 2011
    70
    There is a similar problem on a different Honda (CRM250AR). I used a product called liquid spanner and had to lay the bike down on both sides to let it penetrate, it did the job well, I could just drift the bolt out and clean it up.
    Can anyone tell me what the length of your swingarm bolts are, and the length of the threaded section?
    Sent from my HTC Sensation XL with Beats Audio X315b using Tapatalk
    #91
  12. Stretch67
    Stretch67 Mad Scientist Supporter
    Mar 22, 2006
    22,011
    Bent, But Not Broken
    #92
  13. mekros
    mekros Adventurer
    Oct 5, 2011
    70
    Excellent, thanks
    #93
  14. Est650
    Est650 Adventurer
    Mar 14, 2014
    13
    Estonia
    Very interesting reading
    I have a 1993 klx 650 which has never had its pivot bolt removed. I once tried to tease it out but now I know how stuck it really is :eek1
    #94
  15. mekros
    mekros Adventurer
    Oct 5, 2011
    70
    Can anyone tell me the length of your rear axle bolt is, as well as the threaded section?
    #95
  16. G600
    G600 Been here awhile
    May 18, 2009
    555
    Iceland
    Rear wheel axle?
    #96
  17. mekros
    mekros Adventurer
    Oct 5, 2011
    70
    excellent, thanks
    #97
  18. hondahead
    hondahead n00b
    Jul 6, 2012
    9
    Yeah it's stuck. I don't need it out yet. But it's stuck good! I have a new swingarm if worse comes to worse.
    #98
  19. CCTigers
    CCTigers Adventurer
    May 4, 2014
    12
    SE USA
    There is a local guy offering a 97 xr400r for 900 obo. He says it runs great, has 2 new tires, but the swingarm bolt is not original, but he has one on order. Should I even go look at it?
    #99
  20. fuel-cycle
    fuel-cycle 3 wheels or less 49CFR571
    Aug 30, 2005
    450
    Right outside this lazy summer home
    Yes!
    Then use this if you buy it. Kroil is amazing stuff.
