Xr600 & xr650l aussie owners
Discussion in 'Australia' started by Kenno, May 30, 2013.
  1. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    12,671
    GodSowncountry Australia
    If the valves rotated and did as described, the bike would gain and lose power constantly. Compression-no compression-compression-no compression,......endlessly. This is not normal.
    It makes no sense unless there's some physical damage to something. I can kick mine over until the cows come home, it is the same compression every kick. Similarly, riding it there is no pulse of compression coming and going with the rotation of the valves. The description points to an underlying problem which may be the true cause of all the valve bending and camchain jumping, but who knows?
    One other thing to check. If you have raised the bars, the decomp cable can engage at full steering lock causing you to kick the piston into the valves. Worth checking.
  2. GSXR
    GSXR Trail Rider
    Sep 14, 2010
    1,883
    Sunshine Coast, Australia
    Valves rotating doesn't cause any loss of compression. They are designed to do it as pointed out.
    Anyhoo.... Ron50 has provided what I consider the correct answer to bennos concerns.
    To add further... only use Jaso MA2 oil in your XR. It's on the bottle
  3. benno.h
    benno.h cageracer
    Aug 14, 2010
    528
    Brisneyland, Arse-Trailer.
    Godsilla, I think we're saying the same thing, I just wasn't very clear earlier. Yes, compression does change exactly like that - push up to TDC (good compression) to get ready to start, decomp, sneak past TDC, give an almighty kick - nothing, and no compression for the next few kicks. A few more hard kicks and compression returns, and the cycle begins again.
    The valves *are* bent - I have the head off. They rotate in and out of positions where they seal - hence intermittent/variable compression. I can confirm this by shining a light at the bottom of the head and rotating the valves by hand.
    I don't have auto decomp or a cable for the manual decomp (home made lever down on the cylinder head).
  4. GodSilla
    Sep 21, 2006
    12,671
    :ear
  5. GodSilla
    Sep 21, 2006
    12,671
    No worries. I thought you were describing your fixed and running engine, my mistake.
    benno.h likes this.
  6. GSXR
    GSXR Trail Rider
    Sep 14, 2010
    1,883
    OK I'm out. In my 36 years engine building experience I've never seen a bent valve that will reseat itself with rotation. I'm also sure I never will. Then I read the bit about the home made lever and it's all coming together nicely. Keep it stock if you want to rock
  7. benno.h
    benno.h cageracer
    Aug 14, 2010
    528
    Are you trying to say my decomp lever is causing these problems? Really can't see how that would happen.
    As for the valves, well they definitely seal better at some points when I rotate them by hand - I can see it. As to what happens when I kick, that's only my theory.
    Valve guides were checked last time I replaced the valves and the machinist re-surfaced the valve seats to match the new valves so I assume (dangerous, I know) that everything lined up as it should.
  8. lookfar
    lookfar from the land of OZ Supporter
    Feb 13, 2011
    1,438
    D'aguilar
    Sounds like 4 new valves are needed.
    https://www.ebay.com.au/itm/New-Gen...0-Notes-W129/272213460200?hash=item3f612fc4e8
    https://www.ebay.com.au/itm/Genuine...m=361510007649&_trksid=p2047675.c100005.m1851
    Adventurepig and benno.h like this.
  9. *perko
    *perko Adventurer
    Aug 31, 2015
    82
    Sydney
    Perfect, makes a lot of sense now. I guessed I might have figured it out with everything pulled apart but always better to get the info straight from those who know.
    Very neat to have a way of disabling without removing and also keeping the kickback protection.
    There is definitely a lot of confusion as to how the whole system works, many people firmly believe it's black magic.
  10. lookfar
    Feb 13, 2011
    1,438
    D'aguilar
    Hey Benno, if you need a good head reconditioner, I use RPM Engines at Kunda Park (Maroochydore exit).
    They have done a few for me now, and also for a mate. Good value and really know their stuff.
    I have always supplied any parts that needed replacing when I dropped the job off.
    benno.h and GodSilla like this.
  11. Ron50
    Ron50 Long timer
    Oct 12, 2008
    2,884
    Canberra
    I can see how it could appear that the valves are sealing better at one point of their rotation IF the guides are also bent/deformed. Definitely worth checking. Bending valve stems more than once would put a lot of strain on the guides and could lead to their moving in the head or having the through hole become oval.
  12. benno.h
    benno.h cageracer
    Aug 14, 2010
    528
    Yeah, valve guides were inspected last time (I've been going to Serco at Woolloongabba) and were ok. I'm going to get some new valves and seat them and see what they look like - if they look like they seal up ok and I can rotate them without any obvious change in sealing I might not bother getting them professionally inspected.
  13. benno.h
    benno.h cageracer
    Aug 14, 2010
    528
    Thanks mate, I'm actually referring to the spring on the outside of the rocker cover that returns the manual decomp lever to the normal position - the XR650L doesn't have manual decomp.
  14. lookfar
    Feb 13, 2011
    1,438
    D'aguilar
  15. benno.h
    benno.h cageracer
    Aug 14, 2010
    528
    yeah... $60 is a lot for a spring! I've ordered one for an XR400. It's not quite the same but I'm hoping it might fit.
  16. lookfar
    Feb 13, 2011
    1,438
    D'aguilar
    NX650 head porn....
    Before
    After
    Squily and GodSilla like this.
  17. benno.h
    benno.h cageracer
    Aug 14, 2010
    528
    Man I love how clean everything looks after a bit of bead blasting...
    Got the head back on the XR today. New valves look the goods - everything lined up as it should. Here's a vid of the old intake valve:
    https://photos.app.goo.gl/BJPyfVRkPHsFjbJh7
    In the video, I'm rotating the valve (intake) by hand whilst maintaining slight traction (in the direction the spring normally would). An extremely bright LED flood light is shining at the underside of the cylinder head and the camera is pointing down the inlet tract. You can see that as I rotate the valve, it goes from no light to lots of light coming through. I do believe that at some points it's capable of generating enough compression on the kicker to make you feel like everything is normal, and then it rotates to a point with no compression at all.
    I'm still waiting on a parts order from Partzilla in the US to get everything back together. A bit under $200 AUD for cam chain tensioner, shaft, slider thingo, lower cam sprocket and a couple of miscellaneous bolts. Not too bad really - the local dealer wanted $157 for the tensioner alone.
    I've been working on cutting a blank rear guard to suit my new subframe for the last little while and it's coming up pretty good (IMO) but it's been a bastard of a job:
    https://instagram.com/p/BkI-6iinYI1/
    https://instagram.com/p/BkRzUbGHS9T/
  18. lookfar
    Feb 13, 2011
    1,438
    D'aguilar
    Took the XRs' camping in Northern NSW.
    Bloody cold... was -4 degrees C
    Riding on a fire trail.
    The XRs' in their element.
    Squily, thebigman and hoorang like this.
  19. hoorang
    hoorang .
    Feb 16, 2015
    1,016
    Curlewis NSW
    ^^ that last pic looks like it should have been in the sales brochure!
    lookfar likes this.
  20. lookfar
    Feb 13, 2011
    1,438
    D'aguilar
    If anyone has done the electric leg 650 conversion to the 600R, where did you put the battery?
    And, is the right sidecover the same between the XRL and the XR?
