XR650R owners.
Discussion in 'Australia' started by jack82, Mar 12, 2009.
  1. crash n bern
    crash n bern Long timer
    Mar 5, 2007
    1,844
    Brisbane Oztrailia
    I bought a TM from Tom at TD Hatrick for my KLX650C 20 years ago. He sold me the same one they sold for Harley Sportsters. I think it was the 42. I guesstimated the jetting to get it running and then played around from there. Got it running nice without too much trouble. But I seem to always fluke jetting in a naive sort of way.
    A lot of people seem to swear by the Eidelbrock carb for the XR. I have no experience with them or with XR’s for that matter, other than reading a lot about them as I’ve always liked them but never gotten around to owning one. Although some of the asking prices are getting a bit silly now.
    I would probably go with GSXR’s advice as from my experience buying expensive carb’s often don’t offer much advantage over the stocker.
  2. GSXR
    GSXR Trail Rider
    Sep 14, 2010
    1,886
    Sunshine Coast, Australia
    Some of the Seppo boys are raving about the Lectron carbys, although it appears to be mainly the show n shine / sumo brigade. Can't say I've ever seen a pic of one out in the dirt, but haven't really taken much notice
  3. zoro
    zoro Been here awhile
    Dec 9, 2010
    609
    Cairns, Australia
    My preference would be to stick with the stock carb to be honest.
    Can the idle mixture seat be removed/ replaced?
    I have access to a lathe and can make one if i can remove the old one without wrecking it or the carb body..
  4. GSXR
    GSXR Trail Rider
    Sep 14, 2010
    1,886
    I've got one here with a broken air screw zoro. I've had couple of clever mates spend many hours trying carefully to get it out but no luck yet. Don't want to damage the housing as you say. Fiddly bloody things
  5. pigjockey
    pigjockey Hognuts the T-bagger
    Jan 25, 2014
    3,682
    Wisconsin A half dozen miles from ROAD AMERICA
    I’ve got a stocker carb with the throttle and cables like new if your interested. With the stock jetting. Came off a very very low mileage rrrrrrr.
    Oz Nutter likes this.
  6. zoro
    Dec 9, 2010
    609
    Cairns, Australia
    PM sent.
  7. zoro
    Dec 9, 2010
    609
    Cairns, Australia
    Buggered if i know how to quote to two different replies without doing this twice...
    GSXR, if i get my hands on another carb I'll have a red hot go at removing the seat also. If i have success with it I'll post it up here, surely it cant be that hard.
    GSXR likes this.
  8. XR4play
    XR4play motrobikes, motorbikes, brum brum
    Apr 18, 2018
    32
    queensland
    i've fitted up 2 tm40 pumpers and ended up going back to stock both times! I couldn't get them jetted well enough to be happy i did get some well improved fuel range usage but at the cost of performance,
    tm42 won't fit easyly needs to bottom of the tank reshaped to fit in im told and still sits on an angle. sadly the fcr carb won't fit properly either
    all the best sorting yours out mate
  9. Syc08
    Syc08 Been here awhile
    Nov 16, 2014
    221
    Sydney Australia
    My tail light and speedo light is very dim.
    Test light confirmed the same under the seat for the tail light.
    Any had this problem and know the fix
  10. kipo
    kipo South Australian Tiger Resistance Group
    Jan 8, 2007
    3,131
    Port Augusta
    Just put new swing arm and rear linkage bearings in, tightened everything up and I have a tiny bit of play somewhere in the linkage. It's that tiny I don't think it's an issue but anyone else had this?
  11. empiredownhc
    empiredownhc Adventurer
    May 8, 2013
    87
    Hunter, AUS
    Yes, something similar on my 600. Turned out was the bearing at the top of rear shock
  12. kipo
    Jan 8, 2007
    3,131
    Port Augusta
    Cheers, that's what I suspect it is.
  13. Bhart89
    Bhart89 Long timer Supporter
    Nov 12, 2013
    1,489
    Indianapolis, IN
    Is anyone using a trash can wind screen on an XRR with a Baja Designs kit headlight? If so, how do you like it? The more I use the XRR at speeds over 50mph the more wind protection I’m looking for.
  14. crash n bern
    Mar 5, 2007
    1,844
    Brisbane Oztrailia
    Not an exact answer, but one that may offer an idea. I got a strip of aluminium and bent it around my headlight cowl and bolted each end to the bark buster mounts. I then cut a screen out of a 20 litre (5 gallon for you guy’s) drum and pop riveted it to the alloy strip. It was one of those last minute before a long ride jobs and its still there. Saved drilling into the headlight cowl and it looks pretty good.
    Bhart89 likes this.
  15. xrsism
    xrsism Been here awhile
    May 12, 2017
    336
    Is that flexible or going to cut your head off with a sharp stop?
  16. HPBRP
    HPBRP Adventurer
    Aug 28, 2014
    24
    Just after some info on which rims to use for motard setup TIA.
  17. Bhart89
    Nov 12, 2013
    1,489
    Indianapolis, IN
    I have Warp 9 cush hub rims in the standard 18/21” size. I love them. They also make a SM setup.
    HPBRP and Oz Nutter like this.
  18. HPBRP
    HPBRP Adventurer
    Aug 28, 2014
    24
    thanks for the input
  19. crash n bern
    Mar 5, 2007
    1,844
    Brisbane Oztrailia
    Yeah, flexible. Way more than any lexan windscreen. Maybe I should of mentioned it was a plastic drum. Did see a bloke going on the APC rally that had an aluminium one though.
  20. GSXR
    GSXR Trail Rider
    Sep 14, 2010
    1,886
    Have you still got this PJ?
    How did you get on with yours Zoro?
    I need a stock carby for a customer bike. Anyone on Oz got one for sale?
    Also chasing a rear master cylinder, caliper and mount bracket.
