XR650R Thread!
Discussion in 'Thumpers' started by JustinT, Nov 24, 2008.
  1. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    4,907
    Inspect it as well. There is not much of a standard for the overall width of a chain. The XR was around before some of the fancy chains that maybe wide. Your little keeper plate may get knife edged. I ran an oring chain with a master and had no problems.
  2. pigjockey
    pigjockey Hognuts the T-bagger
    Jan 25, 2014
    4,026
    Wisconsin A half dozen miles from ROAD AMERICA
    I routed my decom. Cable wrong after installing bar risers. Every time I turned right sharp it would kill the engine. If I left the bars turned it had no compression. Simple fix, reroute the cable. Never was a problem after.
  3. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    5,057
    Long Beach, California
    That small triangular corner on the exhaust rocker arm is acted upon by the Lifter Lever and opens the left exhaust valve when you use the manual decompressor.
    The Decompressor Cam automatically operates the rocker arm as you kick the bike over, and the Reverse Decompressor Cam prevents damage to the engine on kick back.
    Gildus, theailer and Friedom like this.
  4. Beejaytee
    Beejaytee Been here awhile
    Nov 20, 2016
    297
    That’s not true. It has a sensor that very accurately tells temp. The caveat is that the bike has to be running because the fluid won’t come in contact with the sensor otherwise. I have one along with oil temp and a trail tech sensor and they are plenty reliable and accurate.
  5. bigkuri
    bigkuri Long timer Supporter
    Oct 31, 2004
    1,269
    Auckland, New Zealand
  6. JakeTheSnake0528
    JakeTheSnake0528 Adventurer
    Apr 24, 2020
    86
    San Antonio
    Trying to source a part for the decomp where it sits in the head. Just noticed an oil leak coming from where the cable connects to the mechanism. It seems it has worked itself out maybe 1/4” and I’m wondering if a seal or something went bad. Having a tough time figuring out what the specific part would be called.
  7. thouk
    thouk Been here awhile
    Apr 11, 2006
    306
    Lincoln, Ne my hometown, Where I'm freezin
    Just wanted to show the slow progress in rebuilding my BRP from about 2008. I finally installed the Rox risers. Tony
    greasyfatman likes this.
  8. bigkuri
    Oct 31, 2004
    1,269
    That's an interesting steering damper.
    Guano11 likes this.
  9. thouk
    Apr 11, 2006
    306
    Bigkuri,
    It came off I think a Crf450r. I bought it a while ago. Doesn’t feel like it’s worth the effort I put into getting it mounted. I’m surprised you didn’t notice my new bar cover???
  10. bigkuri
    Oct 31, 2004
    1,269
    The risers or the pad? Nothing to see there... ;) But that damper is very cool. How'd it mount to the headstock?
  11. thouk
    Apr 11, 2006
    306
    Bigkuri,
    I was making a joke. I actually have a few things I wondered if people would notice the missing locking gas cap on the Clarke tank. The stabilizer that you pointed out. And of course the risers that I pointed out.
    bigkuri likes this.
  12. Kai Ju
    Jul 29, 2009
    5,057
    See my post 32203 on this page. There is a short 6mm bolt that screws into the cam cover that retains the decompressor shaft.
    JakeTheSnake0528 likes this.
  13. JakeTheSnake0528
    Apr 24, 2020
    86
    San Antonio
    Beautiful. Thanks so much.
    Kai Ju likes this.
  14. Gravis1982
    Gravis1982 Been here awhile
    May 31, 2019
    179
    Edmonton
    Best replacement parts to buy in 2021? Lots of forums out there from 2004 with dead links and companies that no longer exist. I just bought a 2001.
    Brake pads: oem Honda pads? (yes)
    Rims: stockers seem good enough
    Calipers: too expensive to upgrade
    Rotors: ?
    Brake lines: steel braided, not sure which brand
    Sprockets: ?
    Chain: oem chain seems great, yes?
    Carb: stock seems fine if uncorked.
    Exhaust and header: xrs only?
    Case saver: xrs only?
    Battery and electrical upgrade to run various devices:?
    Rear shock rebuild kit:?
  15. bigkuri
    Oct 31, 2004
    1,269
    OEM pads are by far the best I've used, no squeals and good power while lasting well.
    Gravis1982 likes this.
  16. jm-2008
    jm-2008 Been here awhile
    Sep 19, 2008
    786
    South Eastern Australia
    The front of the plate looks like it's sitting
    Have seen some early rims crack at the weld were ends are bounded together so worth a careful look.
    JM-2008
  17. Robert K.
    Robert K. Long timer Supporter
    Jan 1, 2014
    2,919
    MI, USA
    Just a few more things to tidy up and it will finally be ready to rip.
  18. bigkuri
    Oct 31, 2004
    1,269
    That's superb. Nice bike!
    I've been doing a bit of googling/searching for an entire seat... I cannot seem to buy a new seat in NZ, nor subframe. Both are beat up, getting worried that the subframe will fail on a big hit, and the plastic seat pan itself has also taken a hiding over the years.
    Asides from having a bespoke subframe and seat made, any options come to mind?
    Robert K. likes this.
  19. Robert K.
    Jan 1, 2014
    2,919
    MI, USA
    Thank you bigkuri!
    I've heard that Honda still sells new seats but haven't checked into it myself via local dealer. They sure aren't anywhere on the internet. Could be ear say but it may not be either. Honda may still sell sub frames also however I'm not sure.
    Used subframes pop up occasionally on ebay, however they run anywhere from 200-350 dollars a pop from what I've seen. I was looking into subframes myself before giving the bike to an uncle who lent a hand and some knowledge in extracting a stubborn bolt out.
  20. brayjay
    brayjay Been here awhile
    Oct 1, 2013
    382
    British Columbia
    There is a brand new oem subframe on ebay and it says it's in Australia. Just a hop skip and a jump for you.
