XR650R Thread!
Discussion in 'Thumpers' started by JustinT, Nov 24, 2008.
  1. Robert K.
    Robert K. Long timer Supporter
    Jan 1, 2014
    2,926
    MI, USA
    :beer
    She's a keeper!
    Bike is running great. Sounds phenomenal with the xr's only competition system. Hard to hang on it pulls so hard. Good color on the headers starting to appear. Putting in a new Hinson clutch basket with Barnett dirt digger plates and HD springs. After that, some new lighting. After that......buy a house, or use the house money to race the baja1000.
    We'll see how much she likes me if the ladder happens. You only live once right?
    pigjockey and Kai Ju like this.
  2. pigjockey
    pigjockey Hognuts the T-bagger
    Jan 25, 2014
    4,158
    Wisconsin A half dozen miles from ROAD AMERICA
    Better take me with you to Baja. I have a freight train R and a pretty stock one to bring as parts. So hurry up I’m getting old. :clap
    greasyfatman and Robert K. like this.
  3. TroopThrowback
    TroopThrowback Been here awhile
    May 11, 2013
    917
    I’d pit that.
    I mean I’d be happy to join on your baja efforts.
    Robert K. likes this.
  4. Friedom
    Friedom Onward and upward!
    Mar 3, 2013
    5,223
    The Golden City of Tucson
    Catching up on maintenance. New fuel line, petcock gasket, cleaned out the carb, and got rained on in the process. I tried to start up the bike, and after one fire a bunch of fluid poured out of the air box.
    Sooo I drained the "oil" out of the crank case. Out came a good gallon of fluid. Leaking petcocks are a danger to us all lol.
    Davethestick likes this.
  5. TroopThrowback
    May 11, 2013
    917
    Noooooo! Good thing you caught it before it froze your piston rings!
    Oz Nutter likes this.
  6. Friedom
    Mar 3, 2013
    5,223
    I've never heard of that, but I guess it does dilute the oil and affect it's ability to lubricate.
    Bike wasn't run in this condition as the carb was always too full to start up, so it just got a nice colon cleanse.
    pigjockey likes this.
  7. bigkuri
    bigkuri Long timer Supporter
    Oct 31, 2004
    1,276
    Auckland, New Zealand
    That's one way to flush your engine... :photog
  8. TroopThrowback
    May 11, 2013
    917
    When gasoline leaks out of your tank into your intake , it can leak past your valves and into the combustion chamber, and wash the oil away from your rings, freezing them to the bore.
  9. Friedom
    Mar 3, 2013
    5,223
    What would the sticking mechanism be? I don't see gasoline causing them to rust, heat, expand, corrode or fuse?
  10. pigjockey
    Jan 25, 2014
    4,158
    The fastest way to sticking or frozen rings would be from alcohol in the gas. Raw gas with alcohol absorbs moisture from the air and after setting for days can cause a terrible mess by washing out the oil and replacing it with watery gas. Instarust.
  11. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,008
    Wonder how your clutch plates fare in that mix.
  12. Skyva
    Skyva Adventurer
    Apr 26, 2019
    30
    Melbourne
    Hello, so I am back, trying to do more maintenance on the bike. I manged to clean the carb and put in new jets so ti is ready to go back on. I thought i should check the valve adjustment as well while I have the seat and tank off.
    Problem: I am solo so I cannot turn the back wheel and see the timing mark easily at the same time for TDC. But I cannot remove the stator cover. I have removed the 5 bolts but it won't come more than 5mm (1/4") away from the block. I also cannot seem to get the gear lever off. The lever sits up a bit so might block the stator cover if I could get that off further.
    The bolt holding the gear lever on the splined shaft loosened fine and the lever wobbles a little so it doesn't seem stuck, but it refuses to slide off the shaft. The manual isn't helping me.
    Any ideas? I am reluctant to brute force alloy components until I know I am not missing something.
    This bike is fighting me every step.
  13. Nikoutdoor
    Nikoutdoor Been here awhile
    Apr 20, 2013
    177
    NW Arkansas
    You have to take the bolt all the way out of the lever. There is a groove in the shaft that the lever slides on that the bolt interfaces with.
  14. Bigfury
    Bigfury Been here awhile Supporter
    Jun 21, 2016
    263
    Purchased a set of pannier racks from Off The Road located in Germany. Finally installed them. One problem is getting into the air filter. Anyone found a way around the problem?
  15. Desertskyy
    Desertskyy Always looking for an adventure
    Mar 25, 2007
    288
    So Cal-Ventura County
    Unscrew the inspection window bolt with an Allen wrench. No need to pull the whole cover
    Put the bike on a stand and put it in 5th gear and rotate the tire until the timing mark lines up
    In my 18 years of owning my bike I have never had my cover off to adjust my valves.
    Your bike should not be fighting you at all. I has been very well designed. Be patient and understand how and why it was designed the way it is. It all makes sense after awhile.
    Good luck
  16. greasyfatman
    Oct 18, 2014
    5,008
    I have some design for manufacturing in my back ground. Lots of shitty compromise that take a prototype that is great and turn it into the cheapest possible thing to build and sell.
    That being said the XRR is an engineered piece of Art. Yes some emissions compromise have been made. But dam what sexy use of aluminum.
  17. jm-2008
    jm-2008 Been here awhile
    Sep 19, 2008
    788
    South Eastern Australia
    I’ve posted this before some where in this thread but what I do is push the kick started through by hand till it comes up on compression, keep steady pressure at this point easing off as it comes up to TDC.
    It will likely bump over TDC slightly but no issue, at this time cam followers/rockers will be on the cam base circle - check/adjust valve clearances at this point.
    With practice you will get to feel when the piston is about to bump over TDC, if your slightly past it’s no issue as long as you don’t go half way down the stroke and are somewhere near TDC all will be OK.
    Once you get the hang of it there’s no need to remove the inspection cover and search for the T Mark.
    This method avoids issues with the decomp unit as well.
    JM-2008
    Gildus, theailer and pigjockey like this.
  18. Desertskyy
    Mar 25, 2007
    288
    Yes it is a piece of art
  19. esteyes
    esteyes Been here awhile
    Oct 6, 2019
    119
    Escondido in SoCal
    greetings all. looking for answers to a couple of questions about XRs Only exhaust (i recently snagged a used system and am "refurbishing" it):
    1. what is the diff between the two versions? i can't see any looking at their pictures and the descriptions don't say.
    2. the end cap sez it's an approved spark arrestor, but there is no screen. removal of the cap shows a relief cut in the plate that looks like a screen should/could be installed.
    3. the muffler to header fit is very loose (header od: ~ 44.5mm , muffler id: ~ 46.5mm ). there are no signs of silicone, so is there a packing piece a la oem to use, or a piece of tubing to fill the gap that i did not get from the seller? i also did not get a clamp for this joint and it appears there never was one based on the lack of marks
    4. i assume the muffler should be repacked periodically?
    thanx in advance
    neil
  20. Frostguiding
    Frostguiding Been here awhile
    Nov 17, 2014
    209
    Switzerland
    Advertised my XR for an optimistic price...
    Guy turned up with cash. I sold it.
    Oh dear.
    Bbasso likes this.
