XRL owners sign in.
Discussion in 'Thumpers' started by onaXR, Jan 18, 2006.
  1. Barron
    Barron M0DAH0LIC Supporter
    Mar 24, 2006
    3,324
    Yokosuka, Japan
    All this talk about three wheelers.... I thought I'd just leave this pic here. It's from another XR650L thread I follow.
    -Barron
    enduro16, Onederer, mbanzi and 2 others like this.
  2. fritzcoinc
    fritzcoinc Enjoying my last V8 Supporter
    Apr 30, 2008
    10,136
    Hockley, Tx
    It looks dangerous and that riding it is a lot of fun!!!
  3. fritzcoinc
    Apr 30, 2008
    10,136
    Hockley, Tx
    Grind the bevel on the inside ID till you can get the retainer plate on.
  4. tallbob
    tallbob Been here awhile
    May 23, 2005
    767
    Butt Mt. VA
    Pic of my new to me 08. I like it!
    enduro16, orrj, buzzword and 4 others like this.
  5. XRHondafan
    XRHondafan Long timer
    Oct 29, 2016
    1,986
    Exactly - these engines don’t spit that much oil
  6. XRHondafan
    Oct 29, 2016
    1,986
    #xrlife
  7. XRHondafan
    Oct 29, 2016
    1,986
    This was the separator that Jim Connolly developed. There is no doubt at sustained high revs the xr will spit oil.
    The Jim Connolly separator had steel wool inside it and as you said was plumbed into the side of the engine.
  8. Onederer
    Onederer Crunch Nugget
    Aug 24, 2008
    1,221
    At the bottom of your glass, staring back
    I've got several hundred $ of parts waiting to go on it. The only things I'm keeping are the frame and forks, but they'll be painted a different color.
    Someone actually put a good bit of time into building it, although some stuff is obviously scrounged parts. All those holes in the frame and fork gussets are drilled, not punched, and they're spaced really well. That took some time. It's got a hydraulic, cable operated disc brake on the rear sprocket.
    By engine speed, the way it was geared, it'd run 40mph. Ummmm...not with this hombre. Going to gear it for 25mph, which is still coccyx breaking speed.
    Barron and XRLated like this.
  9. john.thorp
    john.thorp Titan of Industry Supporter
    Jul 6, 2012
    306
    NYC
    here he is again folks, the town fool.
    haven’t been riding as much since is cold, every time i do it’s got a weak start. makes me sad. fired up strong as hell right up until three weeks ago.
    this is my battery, this is my tender. somethings wrong?
  10. XR650L_Dave
    XR650L_Dave Long timer
    Apr 3, 2006
    5,658
    Near Cortland NY
    I have the shorai.
    Lithium batteries have less amps when cold. You can turn on the headlight for a couple minutes before cranking and warm the battery. Cranking can drain it before it has a chance to warm.
    At 40F in my garage it cranks more slowly but starts reliably.
    If that tender does simple trickle charging it's OK, desulfating is bad for LiFePOS.
    If you charge at all you need to be sure the voltge does not go above the never-exceed coltage, I think it's 14.3?
    Lithium batteries have a lower max acceptable voltage when cold, it's a lithium thing.
  11. msteward
    msteward Long timer
    Sep 14, 2015
    1,172
    Spanish Fork, Utah
    They sell a different charger for lith batteries also.
  12. XR650L_Dave
    Apr 3, 2006
    5,658
    Near Cortland NY
    I use my battery tender to boost it up over the winter once in awhile, but the lithiums have very small self-discharge so really just needs a touch up infrequently.
    I don't see a need leave a lithium on a tender.
  13. john.thorp
    Jul 6, 2012
    306
    NYC
    this is all making sense. it *does* start reliably now that i think about it. it’s not like an actual weak battery like i’ve had before where it gets weaker and weaker and weaker.
    i’ll leave the headlight on before my next start and see what happens. i’m sure you’re absolutely right, but i can at least report back another data point
  14. sdf
    sdf Let's Ride
    Dec 8, 2013
    7
    North Georgia
    Are you trying to charge a 12 volt system with a 6 volt charger? There might be your problem.
    Olderslowerguy and Bell driver like this.
  15. LexLeroy
    LexLeroy Whiskey Tango Foxtrot Supporter
    Jan 2, 2011
    12,459
    Lexington, KY
    I think that it's 14.6 / 14.7 max charging voltage. At least that's what used to be posted on the Antigravity web site.
    Good reason to check your R/R output before popping for an expensive LiFePO4 battery.
  16. AZ TOM
    AZ TOM Long timer Supporter
    Oct 21, 2008
    6,922
    Prescott AZ
    DO we really need a lithium battery? Such a small weight gain for all the hassle!
    Wattner, gammel and Olderslowerguy like this.
  17. Steve246
    Steve246 Adventurer
    Sep 14, 2008
    17
    Good season commuting here in Wisconsin. 82 commutes on the 650L, 30 commutes on my wife's F650 for a total of 5488 miles. 015.JPG 018.JPG
    XRLated and AZ TOM like this.
  18. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,391
    San Francisco,Ca.
    DING DING DING
    We have a winner. :clap:clap:clap:clap:clap
    enduro16 and Olderslowerguy like this.
  19. arkansawyer
    arkansawyer Long timer
    Feb 9, 2008
    3,179
    Hot Springs
    Mine was over 4 lbs difference. That weight is out on the end of the bike up high. It made a small difference in some situations. If you're just riding on the pavement, probably won't notice.
    There's about a 50lb difference in the XR600R and XR650L. My off brand lithium battery gets not quite 10% of that back. Never had mine on a charger after about 4-5 years.
  20. JonBu
    JonBu Been here awhile
    Jun 18, 2018
    105
    Manchester, TN
    What is transmission inspection procedure? It is not cycling through the gears.
