XS650 Appresh
Discussion in 'Old's Cool' started by buffaloborn, Jan 12, 2011.
  1. MotoChuck250
    MotoChuck250 Not older than dirt
    Apr 26, 2014
    16,782
    Kansas
    Except for the exhaust system, that 650 looks right at home in that bike. :thumb
    hunter_greyghost likes this.
  2. hunter_greyghost
    hunter_greyghost XS650 Allroads Traveller
    Sep 10, 2008
    11,442
    Yass, Australia
    I'm thinking more like this when I get time
    But for the time being - I'm probably going for a quick build along these lines
    But using a 40mm fork 21" disc front-end off a TT250
    Cheers
    Baza
    CCitis, kenbob, Growl and 5 others like this.
  3. Scoozi
    Scoozi Long timer
    Jun 6, 2016
    1,132
    London
  4. Kris
    Kris Long timer
    Jun 28, 2008
    1,573
    Illinois
    CAB8270C-A7F0-479C-AEB9-7B35E7A91FC2.jpeg I just bought this ‘79 XS650 this weekend. Real clean and seems to run well. It was last licensed in 2009 but previous owner stored it correctly. I put a new battery in it and it started easily and after a few minutes of carb adjustment it was idling well. It seems like a fun agile bike.
    Webman, SportsterTom, Scoozi and 2 others like this.
  5. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    That was a good score.
    Apart from the few mod's it's already got, I'd be inclined to leave it alone and just ride it.
  6. Kris
    Kris Long timer
    Jun 28, 2008
    1,573
    Illinois
    Only mod will be a Illinois Blackhawks speciality plate.
  7. 2manyrides
    2manyrides shifty charactor
    Aug 17, 2008
    2,620
    Citrus Heights Ca.
    The red special above...
    Yep, looks to be well taken care of and unmolested. Rare thing these days!
    radguzzi and Kris like this.
  8. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    To me, the '79 was the pick of the XS'. On yours the bars and the seat are the only non original parts that I can see. Plus, the grab rail has been removed. I like the look of yours.
    Kris likes this.
  9. Kris
    Kris Long timer
    Jun 28, 2008
    1,573
    Illinois
    728478D7-9F0A-491E-AA99-64F5659B22ED.jpeg The bike has 30k miles but it is in really nice condition, previous owners must of loved the bike and took excellent care of it. I consider myself lucky to have found it, I am going to change the oil and filter this week . Is Mikes XS the best source for a filter?
    Webman and hunter_greyghost like this.
  10. tennessee thumper
    tennessee thumper Long timer Supporter
    Nov 3, 2007
    2,337
    Arkansas Ozarks
    Great bike, nice find.
    join this forum-
    http://www.xs650.com/forums/the-garage.2
    Most of your questions will have answers there.
    Mike's XS or 650 Central for parts.
    Find a good factory or aftermarket manual for your bike.
    Consider non-vacuum type petcocks. If your's are working good, run w/ it. When/if they start giving your fits, go to the gravity fed type.
    On the oil filter, there are two...both are reusable.
    Sump filter is the one you need to check and make sure it's in once piece. Have an oil pan gasket on hand, each time you drop the sump to check the filter/change oil.
  11. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,166
    Your imagination.
    It does have the appearance that someone cared for it.
    A good place to start learning about the shortcomings of the filters, then decide which way you want to head.
    http://www.xs650.com/threads/oil-filter.72/page-13
  12. redfishguide
    redfishguide Old Dirt Biker Supporter
    Dec 17, 2004
    1,258
    Beaufort, South Carolina
    While I like Mike's XS...... www.650central.com has been my go to for XS stuff and I have a lot. You might have to break down and use your phone but it will be well worth it.
    Jack and Buck
  13. hunter_greyghost
    Sep 10, 2008
    11,442
    Yass, Australia
    Spent a few days catching up with mates at the 'Autumn Leaf' rally between Tumut and Yass
    Had a great time even though I had to battle bad headwinds but it's only 90kms [57mls] from home and 50/50 tar & dirt
    Collected a trophy [again] - bit of a laugh, between me and the bike - we make 107yrs !
    Nice view heading home - overlooking Tumurrama Valley
    Not a style [ADV Rat Tourer?], that a lot of XS650 fans would build, has a strong heart, is needing some TLC [60k] - getting a full motor strip, rebuild & replace where needed
    Cheers
    Baza
    buzzword and Cactus Ken like this.
  14. redfishguide
    Dec 17, 2004
    1,258
    Nice!!!!!:clap:clap:clap:clap:clap
    Jack and Buck
  15. hunter_greyghost
    Sep 10, 2008
    11,442
    Yass, Australia
    Must get in and have a look for where this oil is coming from ?
    Have a good flow coming out on the lower left side - drive shaft / clutch rod are case splits, lips on seal outa - can change in situ but run the risk of pressure blow-out !
    gear shaft can be changed out easy and have a play with clutch plates etc, while in there !
    Did have some seal carriers which allowed in-situ changes but they compromised the chain type availability - couldn't run O-ring X-ring etc
    and because I do some silly things occasionally - I need that type of chain
    Cheers
    Baza
  16. retiredgentleman
    retiredgentleman Been here awhile
    Jul 3, 2011
    231
    Calgary Alberta Canada
    Hunter;
    Congrats on the trophy for combined 107 years. You're making me feel old...............my combined years is 113:lol3.
    1978 XS650SE plus 72!
    Yeah, these engines weep a bit of oil over time. Mostly the head gasket. I don't worry about it.............I just wipe it off occasionally. Try to keep out of those mud holes:lol2
    Cheers
    Retiredgentleman in Calgary.
    ausfahrt and hunter_greyghost like this.
  17. hunter_greyghost
    Sep 10, 2008
    11,442
    Yass, Australia
    Been quiet of late so not many rallies - between PTSD / Anxiety / Arthritis - all take their toll, physical loss of strength is a big kick for me !
    Doing the 'Alpine' on the 8/9 June, at one of the coldest places in Australia for a bike rally,
    probably doesn't compare to some of the rallies in the Rockies and all those high country places
    And I'm the only one that does the trip on an XS650 [2010 Yarrangobilly]
    Cheers
    Baza
    ausfahrt and Philthy64 like this.
  18. hunter_greyghost
    Sep 10, 2008
    11,442
    Yass, Australia
    Looking forward to an early start @ 0700 [sunrise] Saturday, up through the pine plantations to Tumut
    then up to Yarrangobilly for the 'Alpine' rally - 50 years this year, I started going to this one in '74 - feel old now
    Should be white like this -8c a few years ago, well rug up and keep warm !
    Cheers
    Baza
    Philthy64 likes this.
  19. Philthy64
    Philthy64 Been here awhile
    Sep 3, 2009
    841
    Have a good ride Hunter. Take some pic's if you get the chance
    Cheers
    Philthy
    hunter_greyghost and radguzzi like this.
  20. retiredgentleman
    Jul 3, 2011
    231
    Australia................going down to -8C ! That's just too cold for me.
    My XS650 was not starting well last year, but never thought too much about it. Well, this spring the battery died; down at only 10.2 volts. Battery was 6 years old. Installed a new battery and now it starts up real quick. Batteries don't seem to last as long as the used to ??
    I had bought an AGM sealed type, but the terminals just did not line up with my XS650 cables. I considered changing out the battery cables but too much trouble, so I exchanged the AGM for the old style flooded lead acid. I think my bike is happier anyway with the old original type battery:lol3
