XT225 Custom Tank Build
Discussion in 'Thumpers' started by underkill, Nov 20, 2008.
  1. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    10,591
    Anchorage, formerly Spenard (hub of the universe)
    Surface rust will not bother the POR 15. They have a special cleaner, but I used phosporic acid etch (available fron auto paint stores) as I already had some.
    Braze is a good way to fill gaps between sheets if the sheets lap... this is done at the factory ... well at Kawi for sure. I have also seen Yami & Suz fuel tap bolsters brazed in.... good stuff.
    Good luck.... looks like a great project.
    #21
  2. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    70,321
    Enjoying your tank build..:thumb
    :lurk
    #22
  3. kubiak
    kubiak Long timer
    Nov 25, 2007
    4,837
    madera california
    i cant wait to see how much it holds! i built some bigger tanks for my xr650l.stock is 2.8 and my last tank i built is 6 gallons.its so fun to finally fill it to see how much it will take!
    #23
  4. grizzzly
    grizzzly The Pre-Banned Version
    Apr 29, 2007
    4,499
    socorro NM 505-five five zero-2583
    #24
  5. underkill
    underkill Horsepower Junkie
    May 24, 2008
    1,710
    Port Orchard, WA
    Well last night we finished up the tank. No pictures yet because for some reason the internet isn't working at home. :cry
    Put it in the bathtub and filled it repeatedly with a 1L mountain dew bottle. (gasoline + caffeine = fun!). Got 28liters before it was full!!! :eek1 :huh :D
    The problem was that it was leaking pretty bad... :cry
    but we figure even if it leaked a full gallon while we were filling it, we still got at LEAST 5 gallons out of it! :clap :freaky
    So tonight we'll try to get some tank sealer and finish welding up the leaks we found and hopefully do a final volume count! So excited! I was hoping for at least 5 and it looks like we have it! Now my fuel range will match up pretty well with Blinkerfluid's 640A.... awesome! :lol3
    #25
  6. Blinkerfluid
    Blinkerfluid Long timer
    Feb 23, 2008
    1,181
    Port Orchard WA
    Doesn anyone know how much heat does it take for brazing?? Will the little butane torches work, or do I need to use oxy/acetalene?? I really just need to get a TIG, but they're so expensive.
    #26
  7. griffo1962
    griffo1962 Long timer
    Oct 24, 2006
    1,926
    Boonah, Qld, Australia
    I know a lot of guys use MAPP which I think is lpg/oxy?? I much prefer my oxy/acy. Brazing takes a lot of heat but with the thin wall tank you might be ok with the MAPP. I don't think the straight lpg torch will even do that tho'
    Hopefully someone who actually knows what they are talking about will chime in here.
    g:D
    #27
  8. Randy
    Randy Long timer
    Sep 14, 2002
    5,762
    Newnan, GA USA
    800*F is the US standard. Internationally it is 450*C which works out to around 842*F. Whatever... MAPP (a blend of LPG and acetylene) is commonly used because it burns much hotter than propane but is more convenient than oxy/acetylene bottles. You can buy small MAPP set-ups at hardware stores but if you already have o/a you can just use that. Brazing works well but does require a pretty tight fit between pieces to be joined for it to "wick" properly. At this point your best plan is probably to grind out the porous areas and reweld, grind flush, test, repeat until you get it sealed up. Thin steel is difficult to weld but good technique helps. A good 110V MIG machine might work better than your 220 machine, for the thin gauge metal of the tank, if you have access. You may want to change your shielding gas too depending on what you're using now.
    Thanks to you both for the detailed write-up.
    #28
  9. acejones
    acejones Long timer
    May 14, 2005
    5,437
    MS. Gulf Coast and Puerto Vallarta, MX
    I'm very impressed and envious.
    #29
  10. underkill
    May 24, 2008
    1,710
    Port Orchard, WA
    Finally got the internet working at the house, so here are some new pictures!
    Finished boxing in the side pieces:
    Here it is sitting in the bath tub with aforementioned 1L mountain dew bottle custom measuring device.. :rofl
    Here are some comparison pictures with the stock tank:
    Quite a bit bigger isn't it?
    Also got a few pictures of it on the bike:
    So there ya go! It's not terribly pretty yet... We're still tracking down leaks. :cry There were quite a few big ones and now we're down to the annoying pinhole leaks... Hopefully sometime this weekend We'll get it all sealed up and Ospho the tank to get the rust out of it and then I can seal the inside and then get on to sandblasting the outside and start making it pretty! :evil
    Also, isn't that tank just begging for a rally fairing? just sayin.. We got all winter and I get bored easy...
    :freakycheers!
    #30
  11. Blinkerfluid
    Feb 23, 2008
    1,181
    Port Orchard WA
    Well you guys are right, the butane torch isn't quite hot enough.. it gets just hot enough to get the brazing rod sticky, but thats it.. not need anyway, I just went and got my oxy/acet bottles filled so I can use that.. Only problem is I don't have a tip small enough to braze the sheet metal.. I did practice with a couple 3/16th inch steel plates we had laying around.. got htem to stick together well enough to support my weight.. Brazing is definitely a little different but I think I could do it well with a little practice.. didn't want to try it on the tank though.. I've chased down and fixed most of hte big leaks.. just a few spots that seep now, so hopefully soon it'll be leak free.. then we'll do a tank sealant on the inside just to be safe.. Thanks for all the compliments btw.. and the help. :freaky
    Oh, and I filled the tank up with water and weighed it to get a better estimate of the volume.. should be right around 5 gallons :clap
    #31
  12. johnnyandjebus
    johnnyandjebus Been here awhile
    Sep 5, 2006
    532
    Kingston ON
    blinkerfluid
    I have been watching this thread with interest, great job on the tank so far. From the pics it looks like the size of the tank will blend in quite well with the bike. Keep up the good work and please keep posting.
    #32
  13. underkill
    May 24, 2008
    1,710
    Port Orchard, WA
    Started in on brazing and trying to eliminate all the leaks. Still haven't gotten them all and it's proved to be more of a pain in the ass than making the original tank was... :bluduh
    Then I went in with the metal filler on the top part. Dries really hard and i'm not concerned with it flaking off... I guess unless I hit something hard enough to bend the tank... but then we have other issues. :cry Hopefully we'll get the brazing/filler done tonight and all the leaks located and fixed. Then I can start prepping for paint! :clap
    Anyone have any cool ideas for paint? the base color will be silver... I was thinking either a spoof of the red bull logo using a funny little deer (it is a SEROW!) or the yamaha block stripe things in black with a little blue... Maybe i'll photoshop something up tonight...
    #33
  14. Blinkerfluid
    Feb 23, 2008
    1,181
    Port Orchard WA
    Well as you can see I gave up trying to fix the leaks with the MIG.. Seemed like everytime I'd fix one leak, I'd create a new one.. The brazing seems to work a bit better since it will flow into holes without burning new holes in the tank.. Which is especially handy when trying to repair a pinhole in the original tank metal caused by rust.. Much easier ot just braze over the area, instead of fabricating/welding on a patch panel.. I know it looks kinda crappy right now, but we'll sand it all down and smooth it out and it'll look pretty good.. Just have to find all the leaks frist.
    #34
  15. tripletom
    tripletom Been here awhile
    Jul 14, 2008
    119
    The Lower
    I love how it's going so far. Looks a monster compared to the stock tank. Great stuff and keep it coming.
    #35
  16. kubiak
    kubiak Long timer
    Nov 25, 2007
    4,837
    madera california
    heres a pic of my tank i welded up on my xr650l,it came out to 6 gallons and i went with silver too and added some flat black on the bottom and a charcoal stripe to break it up so it doesnt look too big.i used a mig too and got all the leaks seald but when i preasurized it it had some little seeping so i put a coat of fiberglass resin on the welds to seal it.works great!i cant wait to see your tank done!
    #36
  17. FIDOLLAZ
    FIDOLLAZ Dirty D
    Oct 18, 2007
    759
    to be determined
    Nice work and I do not discount it but it would be far easier to adapt a common plastic tank, like a XR or KTM one. The steel is prone to denting, especially in the extended size. I'd have been borrowing buddys tanks to find a close match and built a mount/adapt a seat. Nice work though.
    #37
  18. underkill
    May 24, 2008
    1,710
    Port Orchard, WA
    I went this way because it would bolt right up to the seat and side panels. Nothing would have to be fabricated to physically mount the tank and get everything lined up. I had considered building a fiberglass tank, but this probably worked out better. KTM tanks don't attach the same way, FYI... and I would have just had to throw away the side panels and find a way to mesh 2 different seats together. I figure the bike comes stock with a metal tank, so no real loss there.... I might make some carbon fiber guards to keep the tank from being dented when I drop it too.. just to help it out. Kinda like they make for the 640Adventure tanks... well, another thing to add to my list I guess! ;):eek1
    #38
  19. milk budda
    milk budda Been here awhile
    Oct 8, 2008
    159
    never in one place
    sweet tank, long live and long ride the Serow! Hats off to you for a job well done. :clap
    #39
  20. leewildwater
    leewildwater rrrrRide Man rrrrRide
    Dec 21, 2004
    418
    out riding my two legged horse near Bryson City NC
    PLUS 1 +++
    #40
