XT250 Clank During Engine Shutdown
Discussion in 'The Garage' started by Lightyear68, Aug 17, 2019.
  1. Lightyear68
    Lightyear68 Adventurer
    Feb 22, 2018
    34
    Bel Air, MD
    I bought this XT250 with 1K and have ridden it another 1K so far. I don't recall hearing a clank when the engine is shut down until recently.
    Oil was 1/4 quart low--so I added to half-the oil view glass. Still making the noise during shut down. No always, but most of the time. Same noise shutting down in N or 1.
    Is this normal? Not sure if it's something to get checked out at the dealer, or the normal sound of shutting down.
    Here's the video:
  2. gonerydin
    gonerydin Been here awhile
    Feb 14, 2012
    466
    Iowa, USA
    My guess is that cylinder compression is causing the crankshaft to spin backwards slightly when it stops. The noise may be the one way starter clutch engaging when that happens. I bet the dealer will tell you it’s normal.
  3. DonM
    DonM Do-dah Do-dah Supporter
    Jan 13, 2008
    2,665
    Atlanta, GA
    I agree.
  4. cristi-mic
    cristi-mic Been here awhile
    May 7, 2008
    149
    Tulcea, ROMANIA
    Indeed, it's the starter sprag clutch engaging on a small backwards movement of the piston.
    kojack06 likes this.
