Yamaha FZ1
Discussion in 'Road Warriors' started by skysailor, Aug 4, 2008.
  1. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    4,712
    Nashville
  2. jointbeaker
    jointbeaker Adventurer
    Jul 21, 2015
    63
    N Illinois
    I'm an hr west of Chicago, and this is what I've got (minus the top box not shown)
    I've never used the setup, and coming to terms with not really needing the bags, as travel is incredibly limited right now. Bags are brand new (I'll use them for the first time this weekend), side racks I bought used of FZ1OA, and top rack and box came with the bike.
  3. oldtouring B
    oldtouring B Long timer
    Oct 9, 2009
    1,076
    Green valley Arizona 85622
    I need your advice. My fz1 is a 2006 silver grey. The gas tank is getting extremely hot. Much hotter than my Street Triple. If there is a solution that will lower the heat it will be much appreciated.
    Picture attached.
  4. Vrode
    Vrode Still half-fast... Supporter
    Jan 21, 2014
    6,623
    Northern Vermont
    I used this setup for years...
    Carlo Muro and rauchman like this.
  5. greasyfatman
    Oct 18, 2014
    4,712
  6. Vrode
    Jan 21, 2014
    6,623
    Northern Vermont
    Soft saddlebags (30L) top case, waterproof duffle (med), tank bag. Cross country and back, no problems.
    I ride a STenere now and upgraded to waterproof saddlebags.
    Yes, racks and hardcases are nice, but liked being able to ride without all the hardware most of the time.
  7. greasyfatman
    Oct 18, 2014
    4,712
    No rack under there? Is it a top case plate?
  8. Vrode
    Jan 21, 2014
    6,623
    Northern Vermont
    Yes, it’s a rack ( SW-Motech I believe)
  9. EastBoundAndDown
    EastBoundAndDown Ron - 300XC-W DR650 T1050SE
    Aug 22, 2010
    2,990
    Outskirts of Gwinnett, GA
    If you know anyone looking, selling my 03 FZ1. Black and yellow pretty good shape. 24k miles
  10. greasyfatman
    Oct 18, 2014
    4,712
    That is a great color scheme. What are trying to get for it?
  11. EastBoundAndDown
    Aug 22, 2010
    2,990
    I am looking to get 3K. I usually dont post stuff here on ADV but CL instead. This bike has heated grips, yoshi pipe and a givi top case. New chain sprockets and rear tire but forks are leaking
  12. rauchman
    rauchman Long timer
    Oct 4, 2005
    1,099
    Northeast, NJ
    What a classy kick ass looking bike!
  13. jointbeaker
    Jul 21, 2015
    63
    N Illinois
    Sure been quiet in here lately. *crickets*
    dsilver1007 likes this.
  14. Treedguy
    Treedguy Long timer
    Mar 24, 2008
    5,253
    NY Hell
    Fz1 guys are out riding!!
    greasyfatman and dsilver1007 like this.
  15. WRC51
    WRC51 Long timer
    Sep 8, 2008
    1,602
    Santa Rosa, Calif.
    My 08 FZ-1 probably the best bike I had ever owned. Should have keep it. Picture 070.jpg
    jointbeaker likes this.
  16. jointbeaker
    Jul 21, 2015
    63
    N Illinois
    added a second gen retro FZ a few weeks ago. Got a few things to do to it yet...but nothing major. Installed a PCV, loaded up a map, swapped to some Proton signals out front, and X-Arcs out back. Still have a header to swap, and it'll honestly be "done."
    Will not be adding hard bags to this one. Maybe a nice tank/tail bag combo...and no more. Drawing the line here. Hahah.
  17. greasyfatman
    Oct 18, 2014
    4,712
    Lol, no more I am done, that means turbo right?
  18. jointbeaker
    Jul 21, 2015
    63
    N Illinois
    Hehehe. I like how you think, but no. Fingers crossed an Ivans flash and PCV will be 'enough' for now. :p
  19. greasyfatman
    Oct 18, 2014
    4,712
    I took my 1st gen to the gym last. Don't know if it was motorcycle ride or deer hunting.
  20. vsvn
    vsvn Been here awhile
    Jul 1, 2015
    585
    Mallorca, Spain
    Hey buddies.
    Finally did a valve check at 87.000km. Intake ones were on the lower limit, but exhaust ones were all between 0.11 to 0.16. (spec is 0.21 to 0.25). Put the new shims in there and clearances are fine now.
    However after reassembly I took it for a test ride and now it makes a whirl noise which seems to come from the camshafts. At first I thought I somehow messed up the timing but the bike rides perfectly. Maybe the cam chain tensioner expanded all the way out and the cam chain is now too tight? What do you guys think?
    EDIT: Regarding the above, I indeed had installed the tensioner incorrectly. You're supposed to compress it back in and engage a clip that will hold it compressed. I then bolted the tensioner back on the engine and problem solved.
    Engine seems to be running a few degrees cooler with clearances adjusted.
    TonyKZ1 likes this.
