Yamaha Riva 180 Repair & maintenance information
Discussion in 'Battle Scooters' started by Kevinforesthill, Oct 15, 2018.
  1. rileyxo85
    rileyxo85 Adventurer
    Jun 1, 2019
    14
    califiornia
    Thanks I'll try to access it.
  2. Juvenile Senior
    Juvenile Senior Been here awhile
    Nov 17, 2019
    201
    Germany
    I suppose I have found the source of my leak at my pet cock.
    As seen on the photos, someone has already tried to seal the thread of the water separator with Teflon band, as common in plumbing.
    What he or she (yeah, right...) didn't know was, that teflon is not gasoline resistant. So I speculate that once I find the replacement for this seal ring inside there, my problem is solved. And I wont need to search for another pet cock.
    The seal is a ring but not an Oring, with abount 38 mm outer diameter.
    Any ideas where to get one?
    Thanks for your Support
    P. S: The ctc distance between the screws to the tank is indeed 46mm. I measured myself. Several old Yamaha pet cocks could fit on this gap: SR500 and some XS 650 models among others.
    Kevinforesthill likes this.
  3. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    There is something I do not understand about this petcock. All the similar petcocks that I find on the net have the vacuum connection on the cover, and the fuel connection on the body. This petcock has them both on the body itself. So I don't understand its mode of function. What membrane will I need?
    I am hesitating as to open it before I have a replacement, since I am taking in account that the 35 year old membrane might be ruined by opening.
  4. sanjoh
    sanjoh Purveyor of Light
    Feb 13, 2007
    9,094
    ADVmonster, CFL, WNC
    The bowl is likely cracked or will be when you install. 35yo plastic exposed to gas does not last!
    Best to have a solution for replacement.
  5. Kevinforesthill
    Kevinforesthill Been here awhile
    Oct 15, 2018
    263
    Foresthill, CA
    Its a super simple design that i am sure will make sense once you open it up. Here is a couple pics i found on the internet showing it torn apart.
    From Jacksscootershop (http://www.jacksscootershop.com/maintenance_tuneup_how_to.html#Fuel petcock):
    Fuel petcock
    This is the thing that controls the flow of fuel from the gas tank to the carb. Most of the time, it is located on the underside of the gas tank. This used to be a lever that you would have to manually turn on and off. If you forget to turn it on, your scooter will die after a short distance. Virtually all modern scooters have a petcock that works automatically. It is controlled by a vacuum line that attaches to the carb or the intake manifold. When the engine is spinning, a vacuum is drawn on the line. This will move a rubber diaphragm in the petcock, and allow fuel to flow through the petcock. As soon as the engine stops spinning, the vacuum will stop. Then the fuel flow stops. Cool, huh? As petcocks age, they can stop working. In order for the petcock to work properly, it must do at least 3 things:
    1. Fuel must flow when vacuum is applied
    2. Fuel must stop flow when vacuum is applied
    3. Fuel should not flow from the vacuum connection into the engine
    You can test the petcock to make sure it is working. It is easiest to test it when it is still connected to the gas tank. There should be two hoses running to the petcock. About 99% of the time, the smaller line is the vacuum line and the larger line is the fuel line. The fuel line will connect to the lower middle part of the carb. The vacuum line will connect to the intake manifold (between the carb and the engine) or to the back part of the carb. Disconnect both lines. Run the fuel line into a small container to catch the gas. Draw a vacuum on the vacuum line. You can do this with a vacuum tool or by mouth. As soon as the vacuum is drawn, fuel should flow. If not, you have either a bad petcock, a clogged filter screen in the gas tank, a cracked vacuum hose, or a clogged fuel line. Assuming gas flows, stop the vacuum. Fuel should stop flowing. Try this test a few times to make sure it is working properly. The petcock should be able to hold the vacuum and not leak. If it doesn't hold the vacuum it will probably need replacing soon.
  6. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    3,716
    Northern California
    I take gasket issues like that to a good hardware store. Often they can help, but bringing in the old one really is critical.
  7. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    @Kevinforesthill If you dismantle it and have it in your hands and follow the routs of the vacuum, looping back and forth from the body through tiny holes in the membrane(s), the plastic plate and then into the space in the back cover, you will have to agree that it is anything but simple. I would even say, there are carburetors which are more simple than that construction.
    Today I couldn't resist the urge and made my own photos (see below).
    However, now I can take the time to source for new membranes (I suspect that the Seca II, the Kawasaki KX or the Suzuki DRZ400 might have somethin similar). Untill I do, I just swopped the tank with a second Cygnus that I have in my garage. My Cygnus is running again :dutch
    IMG_20201019_130911.jpg IMG_20201019_130902.jpg IMG_20201019_130831.jpg IMG_20201019_130823.jpg
  8. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    Just wanted to correct something I wrote above (post #682): Teflon band IS gasoline resistant. At least this is what the internet sais.
  9. sanjoh
    Feb 13, 2007
    9,094
    Having worked with teflon commercially, it will not last when exposed to hydrocarbons.
  10. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    Can you elaborate on that?
    It seems to be widely used with gasoline connections, and "my" Teflon also didn't show signs of deterioration.
    So what is your experience with it?
  11. sanjoh
    Feb 13, 2007
    9,094
    Is your other bike a BMW? Nothing to elaborate, long term exposure to hydrocarbons will deteriorate teflon.
    It's a gasket, use the teflon if you want, otherwise just get a viton oring of low durometer and let it deform to seal the bowl. I would still be using the stock petcock if it did not have the plastic bowl on it. Started just like yours, a small drip, PO tried to seal threads....
    Now if you could get someone to machine a bowl replacement from alloy, we would thank you very much:beer
  12. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    A BMW???
    No...
    I suspect that this petcock already has the machined bowl you are looking for. And the diafragm. And the gasket...
    P. S: it is a gasket in there, a flat one. There is no rill to hold a Oring in place. I know cause I tried
    P. P. S: and as for the Teflon, I guess I"ll stick to the information on the internet:
    https://www.calpaclab.com/teflon-ptfe-compatibility/
  13. Kevinforesthill
    Oct 15, 2018
    263
    Foresthill, CA
    The electronic turn signal relay works great, but sorry no vintage clicking sounds.
    Nice to see you updated your taillights, its a nice upgrade.
    Fast4wardFrisco likes this.
  14. Fast4wardFrisco
    Fast4wardFrisco n00b
    Oct 14, 2020
    4
    San Francisco
    Man, I just had some jerk throw my bike over. It was parked up on the sidewalk in front of my apartment, and I'd just had my eyes on it within the previous 10 minutes. That's San Francisco living. I spent the whole day working on it out there today, and some jerk must have taken notice and decided to teach me a lesson. And I had finally gotten the steering fixed and got to enjoy one short ride. Anyway, the left front blinker is completely smashed. Does anyone have a parts bike with a spare left front blinker they could sell me? I found a right blinker on ebay but no left. Sorry if this is the wrong forum to make that ask. Thanks.
  15. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    I just did :clap
  16. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    It is always frustrating to become victim of ignorant cowards. I feel your pain.
  17. Juvenile Senior
    Nov 17, 2019
    201
    Germany
    @sanjoh in case you were wondering, this bowl I presented comes from a Honda licensed Chinese OHV snowthrower engine.
  18. AG200man
    AG200man AG200 Nutjob
    Nov 27, 2013
    365
    Vic. Australia
    Great thread...that XC carb looks similar to the AG200 carb, except the AG carb is 26mm (Mikuni BS26), but it does have a cable operated choke exiting the top of the carb body. Just thought I'd throw it out there...
  19. Kevinforesthill
    Oct 15, 2018
    263
    Foresthill, CA
    Sorry to hear about your riva. I would suggest checking eBay, I know there was a guy in placerville selling riva parts a couple months back and he would pull whatever you wanted off his complete riva.
  20. Wentwest
    Feb 19, 2007
    3,716
    Northern California
    Try getting in touch with jack@jacksscootershop.com. He's in San Jose and he's got a bunch of parts and pieces in his back yard.
