Yamaha Riva 180 Repair & maintenance information
Discussion in 'Battle Scooters' started by Kevinforesthill, Oct 15, 2018.
  1. Kevinforesthill
    Kevinforesthill Been here awhile
    Oct 15, 2018
    304
    Foresthill, CA
    17x12 Roller/Slider Experiment log:
    under 5g overall - bad performance & very low max speed
    roller weights 4.5g/5.5g mix (red moly/wheel bearing grease) - Very quick acceleration, small lull @40mph, max speed 60mph @ ?k rpm, uphill max speed 55 mph
    Dr. Pulley Slider weights 6g all around (dry) - Acceleration is pretty close to the 5.5g combo [feels slower but reaches 50 mph faster], smooth acceleration/no lull, Max Speed 65mph (70 mph downhill), uphill max speed 50mph (felt like belt slipping).
    (I did not like using Lithium grease or graphite, both went dry quick and didn't perform well)
    Tools required for roller/slider change:
    Phillips screwdriver (JIS 2) - side fairing, air box cover & variator cover
    10mm Socket - floor board
    12mm socket - foot peg
    5mm allen head (aka 5mm hex key) - clutch/variator cover
    Flat head screw drive - Variator tab
    30mm Socket (I strongly suggest using an impact gun) - variator nut
    Pulley Wrench
    Brake cleaner - to clean variator belt surface
    approximate time start to finish = 1 hour
    **PRO TIP: The sliders should be installed with the "Dr Pulley" lettering on top
    Problems:
    (7/17/19) 1st attempt at the DR pulley sliders and something went wrong. Revs fine while on center stand. Will not go uphill at all, no power, feels like clutch is stuck engaged, Boggs down on ground. Will go downhill fine (and up hill at speed), got up to 55 downhill (not max speed), smooth acceleration and no lull - either installed sliders incorrectly (which is what I am thinking) or broke a clutch spring while installing belt.
    (8/14/19) Finally got around to fixing the Riva. It appears that 2 of the sliders fell out of place while installing and I had installed the sliders wrong. Amazed it drove as well as it did with it messed up like it was
    (11/18/19) Been running the Dr Pulley 6gr sliders for a couple months now and I really like them. No problems or complaints. Purchased 5g sliders today and plan on trying a 5g/6g combo to see how it performs
  2. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    Yamaha XC180 service manual (Quick reference)
    Chapter 1 - General information (page 7)
    Chapter 2 - Periodic Inspections and Adjustments (Page 39)
    Chapter 3 - Engine Overhaul (Page 73)
    Chapter 4 - Carburation (Page 187)
    Chapter 5 - Chassis (Page 205)
    Chapter 6 - Electrical (Page 251)
    Chapter 7 - Appendices (Page 325)
    Shortcuts:
    Periodic Maintenance chart page 42
    Engine oil & oil filter Page 47-48
    Tire Pressure Page 59
    Specific Tightening torques Page 334
    General torque setting (English) Page 339
    General XC180 specifications page 338
    General specifications Page 327
    Ignition timing specification Page 337
    General bolt/thread sizes Page 336
    General chassis specifications Page 335
    General carburetor settings & jet sizes Page 333
    Variator troubleshoot Page 151
    Carburetor/Auto-choke Troubleshoot Page 190
    Battery/Charging Troubleshoot Page 283
    Electrical diagram (uncolored) Page 255
    Variator removal Page 153
    Carburetor removal page 194
    Check motorscooterguide for information on owners manuals, sales brochures and other manuals
    http://www.motorscooterguide.net/Downloads/Downloads.html
  3. Grayirwin
    Grayirwin n00b
    Aug 7, 2019
    9
    On the Road
    60F84EC0-A1B4-4874-B61C-07A6CB0A18F0.jpeg Hey all, happy to finally find a current riva thread. I have an 83 riva 180. I believe it’s the one that the p/o made his own rollers for, previously mentioned in this thread (unless multiple people have done that)
    My current issue is a bad slip in the cvt from a stop. Once you get above 20mph or so it grips fine.
    Joe dirt/ scooter dude, where did you order that Gates belt from? Mine is drycracked badly, might also get replacement clutch frictions from eBay.
    I replaced the head gasket last summer, and also messed with some wiring and the BCV bypass, so I may be able to answer some questions as well!
  4. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    Welcome to the forum.
    I think the Gates belt can be found at a lot of places, I found it on Amazon for just under $50 (https://www.amazon.com/Gates-1430V375-Bandless-Multi-Speed-Circumference/dp/B00CJKSEMK) and at V-Belt Supply for $34 + Shipping (https://www.vbeltsupply.com/gates-1430v375-variable-speed-v-belt.html).
    I also have a problem with my CVT not working correctly at low speeds, but I know mine has to do with the sliders that I just installed since it was running perfect before I changed the rollers out for the Dr Pulley Sliders.....pretty sure I installed the wrong, but haven't checked yet since I got other projects I am working on as well. If changing the drive belt doesn't fix your issue, I would suggest changing the rollers out.
  5. Grayirwin
    Grayirwin n00b
    Aug 7, 2019
    9
    On the Road
    Thanks! I hadn’t found that vbelt site, just ordered it! Fingers crossed.
    I’ll take a look at my rollers when i replace the belt.
    Keep me updated on your situation, I’ve also wondered what to do about the rollers. I’ve put over 4K miles on it with the homemade rollers, and the guy gave me anough material to make more if needed.
    ConcordeRiva likes this.
  6. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    You can buy 17x12 rollers for it. That is the stock size, and the stock weight is 6 grams (6rollers total) more rare than some other sizes, but if you look around enough you'll find them in whatever weight you want (I have them in 4g, 4.5g, 5g, 5.5g, 6g, and 6.5g). I have done a little bit of experiment with different weights, but I would need to do top speed tests to know the best combination. I can say that a 4 1/2 gram overall (4g & 5g or all 4.5g) is probably the lowest it can go and doesn't run great. I was running a combo of 4.5g and 5.5g and liked the acceleration but the top speed was below what I wanted (around 60 mph), so I decided to try all 6g sliders, which is where I am at now. If you haven't read many of the past posts, you should go through them as I listed many parts and information on the first few pages of this thread. I originally started this on G+, but when it died I moved all of the good information over to here so that it could help others with fixing their Rivas.
    dot_dash likes this.
  7. Grayirwin
    Grayirwin n00b
    Aug 7, 2019
    9
    On the Road
    I read them all lol. In reference to the belt, do you know if anyone actually rides with that gates belt? A guy on fb is saying he tried one and it didn’t work.
  8. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    I have not installed the belt myself since mine is still in pretty good shape, but Joe Dirt/Scooter Dude installed it on his. I had posted some measurements and the belt angle off of mine on G+ and Joe Dirt/Scooter Dude came up with almost identical measurements, so he contacted Gates and they said that the Gates 1430V375 fit that size, angle and specification. I saw that he had a different Riva 180 thread on here (Advrider) in regards to the clutch if I remember correctly, you might try to look up that thread and try contacting him through there.
    *** Found the thread he started - https://advrider.com/f/threads/yamaha-riva-180-issues-big-surprise.1376105/#post-37495249
  9. FreddyBiz
    FreddyBiz n00b
    Aug 26, 2019
    4
    Slc
    Omg thank you all for this Riva revival thread!!! Much appreciated. Thank you thank you!
    I picked up one in decent shape in Cali and am working on it now. Wouldn't start up cold, but did with some starting fluid. Wouldn't idle after that either, but ran fine with throttle open. Needless to say I gotta mess with the Godzilla carb I guess.
    The hoses on mine seem hodgepodge, I will rerun them with new. Can we confirm the sizing of the hoses on the diagram on page 1? 1/4 and 3/16 I.D. seems really small for those!!
  10. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    yes, 1/4" and 3/16" inner diameter are the hose sizes. I re-did that hose size diagram a few different times, fixing it every time I was wrong. If you find any specific hose size that is wrong, I'll happily change it but those are the sizes that are on my bike currently and my bike runs pretty well. I would suggest getting vacuum lines and not fuel lines, because the fuel lines are much larger in outside diameter and can give you trouble when you try to put it all back together.
    Welcome to the forum Freddy
  11. Grayirwin
    Grayirwin n00b
    Aug 7, 2019
    9
    On the Road
    I installed the gates 1430V375 belt, along with new clutch frictions, which fortunately are still being made. My slip is completely gone, and it also fixed a loud rattle my scooter has made since I bought it, which I thought was engine related.
    Thanks to scooter dude and Kevin for the advice!
    dot_dash and Kevinforesthill like this.
  12. Grayirwin
    Grayirwin n00b
    Aug 7, 2019
    9
    On the Road
    Also, how many miles do you guys have on your Rivas? Mine’s a little over 19k
  13. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    Glad to hear that the belt worked out for you and everything is running good. My Riva has just under 7k on it , so hopefully it will end up lasting for a while.
  14. dot_dash
    dot_dash Adventurer
    Feb 9, 2019
    16
    East Coast USA
    Hey all, good to see the new faces!
    I still haven't revived the 86 180cc... one day. One day.
    However, I did just find a 89 200Z!!! Just brought it home. After riding a big Riva for the first time, WHOA! What an awesome scooter. This thing goes fast!
    Also, from what I was told the 200 has half the issues the 180 has.
    Need new tires and brakes but it's soon to be my daily @6000~ miles. IMG_20190901_150542.jpg
    Kevinforesthill likes this.
  15. fullmetalscooter
    fullmetalscooter Let me take this duck off
    Apr 28, 2009
    5,176
    BC
    Some mods here well ban you for a short time if you post a link to copyright OEM manuals . It's happened to me so that s why I m saying something .
  16. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    I didn't know that, and I removed the link (wasn't working anyways).
  17. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
    Damn that is a pretty one. That seat looks awesome. I also hear that the 200's have less problems, but I have no clue where to find parts for the 200's.
    Nice find
  18. rileyxo85
    rileyxo85 Adventurer
    Jun 1, 2019
    14
    califiornia
  19. Kevinforesthill
    Oct 15, 2018
    304
    Foresthill, CA
  20. FreddyBiz
    FreddyBiz n00b
    Aug 26, 2019
    4
    Slc
    Hey Kevin,
    Thanks for the reply and putting the carb diagram house sizes together and confirming!!! I ordered some vacuum lines and got the engine removed and carb off. My problem now is I want to take the carb apart to thoroughly clean but no shop online seems to have the float bowl gasket anymore. What are y'all doing for the gasket?!
