Yamaha RZV500R The 35 year quest...
Discussion in 'Some Assembly Required' started by busa1300, Jan 27, 2019.
  1. busa1300
    busa1300 Been here awhile
    Feb 22, 2014
    331
    Frozen North...
    With 4 months of winter I wish I was removed from here.
    DiggerD likes this.
  2. busa1300
    Feb 22, 2014
    331
    Frozen North...
    Oh I will for sure.
    I’ll probably put at least a few hundred miles on it with only the gas tank and seat to sit on.
    I have a lot of tuning ahead and also want to keep an eye on if anything is going to fall off.
  3. busa1300
    Feb 22, 2014
    331
    Frozen North...
    Finally put the rings on the last piston and dropped the cylinder onto it.
    Need to get a crows foot 12mm so I can torque the cylinders down now.
    CF27C968-46B7-45E2-8D17-C705450DDD84.jpeg C75DBB73-DBF0-41E0-8D9E-B8248EABDCEF.jpeg
    And one more of the pipes....
    Because I love to look at two stroke pipes
    Twinguy, nzrian, motocopter and 12 others like this.
  4. DiggerD
    DiggerD DougFir from SuperDuke Days
    Mar 14, 2013
    4,232
    Mid Wet Or A Gun
    Great chance you would not be who you are with out those long Indiana nights...how did Tom Petty sing that...some thing about growing up right with the Indiana boys... more than they ever seen..
    busa1300 likes this.
  5. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    11,029
    Orange County, CA
    those pipes are pure sex.
    interesting that the silencers are of different lengths.
    any reason behind that? or just to make em the same exit length? the cone segments to my eye from across the country and on a computer screen look pretty close to the same.
    AK650 and busa1300 like this.
  6. busa1300
    Feb 22, 2014
    331
    Frozen North...
    Short silencer on top pipes so I do not have to cut out body work on tail
    Pipes will stick out of stock holes....no cutting on this bike.
    AK650, villageidiot and Fast Idle like this.
  7. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,353
    Oakland, CA
    IN!
  8. busa1300
    Feb 22, 2014
    331
    Frozen North...
    A little more progress with the engine.
    Got the cranks properly timed, generator mounted, new oil lines installed, and the clutch put back on. Still waiting on my tool from motion pro to torque down the cylinders.
    DC50D665-BC78-4510-9080-850ABCC42E1F.jpeg B9DCB90B-5E75-454F-B81A-40149D0C0F87.jpeg 409030F1-F08E-4F96-B7F5-CCB0EE2AE557.jpeg 2584CCD2-F044-47AA-BE2F-27BB3E067C69.jpeg
  9. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,886
    Los Angeles
  10. busa1300
    Feb 22, 2014
    331
    Frozen North...
    Put my clutch cover on, and put in a new oil seal in my water pump.
    But I seriously fucked up when I went to put the pump on.....
    .....the last couple turns of the screws and I heard a snap. Initially freaking out thinking I cracked the housing, I pulled the pump and found I snapped off a drive tooth. Found the tooth, and gear is easy to replace, except.....they are no longer available, and only used on the RZV/RZ/RD500 :bash
    896E3F74-8EA3-4068-8EBB-38FA64F383E3.jpeg E91E696C-F3E5-4C51-BA02-CE4920291CE0.jpeg
  11. NoelJ
    NoelJ Been here awhile
    Apr 7, 2016
    730
    USA
  12. busa1300
    Feb 22, 2014
    331
    Frozen North...
  13. busa1300
    Feb 22, 2014
    331
    Frozen North...
    Carried the engine over onto the table.
    I'll block it up a little so I can maneuver the frame around it, and get the engine bolted in......still waiting on my 12mm torque wrench attachment first.
    Fast Idle, Richarde1605 and AK650 like this.
  14. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    3,979
    Long Beach, California
    nzrian, busa1300, zzzak and 2 others like this.
  15. anonny
    anonny What could go wrong?
    Mar 20, 2007
    6,687
    Beautiful Revelstoke BC
    Those pipes are the cock for Dolly, that thing is gonna be sweet
    busa1300 and Richarde1605 like this.
  16. Fubars
    Fubars What would Scoobydo?
    Aug 20, 2003
    2,142
    Ventuna, CommieFornia
    We must hear that bike when you're finished, please..
  17. Simosez
    Simosez go ride your bike.
    Oct 13, 2010
    1,631
    eternally sunny lithgow
  18. busa1300
    Feb 22, 2014
    331
    Frozen North...
    I will for sure.
    At least one when I first fire it up, then I hope another when I think I have it running right on a dyno.
    Here is the only vid of it running, right after I got it out of the box and together.
  19. Roadracer_Al
    Aug 5, 2007
    2,353
    Oakland, CA
    You should save the broken gear and have it reverse engineered by someone familiar with gears. If you have a CAD file, a CNC shop can make them in one of the modern engineering plastics.
    Anachronism and busa1300 like this.
  20. busa1300
    Feb 22, 2014
    331
    Frozen North...
    If you like strokers.....
    Here is my 1996 VJ23 on the dyno on one of about 25 runs....the last street stroker ever developed.
    After 7 months of production, Suzuki's agreement with the Japanese government (Kyoto Agreement) saw the end of any more development.
    And production stopped........forever.....
    Not the best run, but the only one I have on record....
    KneeDrachen, plumer1kt, NoelJ and 2 others like this.
