Yamaha T7 TENERE Thread
Discussion in 'Japanese polycylindered adventure bikes' started by VTbeemer, Apr 7, 2017.
  1. Gravis1982
    Gravis1982 Been here awhile
    May 31, 2019
    117
    Edmonton
    or you just ADJUST THE STOCK SUSPENSION which these guys repeatedly said they did not do. If you think you are going to be doing THAT, you had darn well better adjust it first. That is not something to do with the rider, that is a 450lbs bike going off a jump. You max out those clickers if that is what you are intending to ride. The difference between 150lbs and 200lbs rider in that scenario is not what you worry about here.
    Don T, powder85 and twinrider like this.
  2. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,524
    日本
    No kidding, he didn't touch the adjusters at all before writing off the suspension as too soft. Lorry's intentions are in the right place, but he's got a lot to learn about doing meaningful reviews. His guards look good though. :D
  3. Timemachine
    Timemachine Been here awhile Supporter
    May 12, 2015
    204
    Longwarry, Victoria, Australia
    They should repeat that test on a gravel road.
  4. readonly24
    readonly24 Been here awhile
    Jun 5, 2015
    437
    In the dirt
    And under water.
  5. Timemachine
    May 12, 2015
    204
    That won't prove anything useful like how well they get the power down on loose ground or if the KTM traction control actually makes things better or worse. Although it might test the quality of the electrics and with the lower fuel tanks, the KTM might float a little better.
  6. 97707
    97707 Vulture capitalist
    Aug 19, 2014
    14,099
    Oregon, USA
    Doesn't that coolant pump and lines look vulnerable hanging out there. Just asking to get dropped on a rock.
    Looks plasticky. Even if its metal, I'd want it protected.
  7. powder85
    powder85 Been here awhile
    Feb 22, 2019
    147
    Barcelona
    I'm waiting for all the manufacturers to release their final designs for the crashbars. As far as I know, only Hepco&Becker have done lower engine crash bars, the rest protect the fairings like the original Yamaha.
    ssandijss likes this.
  8. victay
    victay Enthusiastic Noob
    Aug 27, 2016
    316
    New Zealand
    Outback motortek is busy developing some. Still in prototype phase by looks of it tho.
  9. Quercus petraea
    Quercus petraea Been here awhile
    Jan 11, 2019
    180
    Spain
    Yes, I read Lorry from OM that they’re planning to protect the hoses with a large skid plate
  10. r1d3rg652gs
    r1d3rg652gs Tenere700
    Oct 22, 2012
    676
    Greece
    The sw-motech bashplate won't protect the suspension linkage..
  11. twinrider
    Aug 20, 2002
    17,524
    日本
    The HBs look strong and, as a bonus, highway-peg friendly. Heck, they might even make good footrests without highway pegs.
    James Adams likes this.
  12. Quercus petraea
    Jan 11, 2019
    180
    Spain
    But Outback Motortek’s will, Lorry said
  13. r1d3rg652gs
    Oct 22, 2012
    676
    Greece
    When will the outback mototrek be ready?
  14. Quercus petraea
    Jan 11, 2019
    180
    Spain
    I can’t say, i’m just following them in facebook and instagram. Crash bars and pannier racks are almost ready, and skid plate is next.
    Zilvinas likes this.
  15. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,092
    Jefferson, GA
    Dyno Run. Very similar to the MT-07.
    Less top end.
    A bit more torque in the 2,000-3,000 RPM range. The sweet spot is in the 3,800-6,200 RPM range.
    Can anyone give a Re-Cap?
    For comparison (Cycle World FZ-07 Dyno) . . . wider torque sweet spot
    IMO, no real reason to rev beyond 8K
    BygDaddee and Deathsoswiftly like this.
  16. Timemachine
    May 12, 2015
    204
    A few things to keep in mind with this result. We don't know the conditions that this result was achieved or if the result is corrected (it is the middle of summer after all), and we don't have other results from the same dyno to gauge if it reads high or low. I am also dissappointed that they didn't graph the full rev range of the engine, taking it to redline, because the extent that it holds power in the top end has a lot of bearing on performance. Some reviewers commented how it held power into the upper rev range.
    We probably won't get a true comparable result till Cycle World get their hands on one, so try not to read too much into it just yet, especially when comparing to 790R dyno results tested in late winter / early spring. For me personally, I won't be too interested until someone uncorks it. Ben Plummer I am talking about you.
    Edit - I think this means the ambient temperature was 27 degrees c.
  17. MotoSpen
    MotoSpen Adventurer
    May 28, 2017
    37
    Southern Ontario
    JBird likes this.
  18. hookeniggy
    hookeniggy Good at getting lost
    Oct 20, 2007
    2,102
    Santa Pola, Spain
  19. hookeniggy
    Oct 20, 2007
    2,102
    Santa Pola, Spain
    This was a pretty cool moment, not because its my bike, well a little bit, but if you love Tenere's….and their brand spanking new proud owners, T7's are also pretty hard to get now, some guys find suspension on the T7 hard, didn't expect that.
    97707 and Madscientist like this.
  20. RPM25
    RPM25 Adventurer
    Feb 17, 2018
    17
    Arizona
