    Dismiss Notice
Yamaha T7 TENERE Thread
Discussion in 'Japanese polycylindered adventure bikes' started by VTbeemer, Apr 7, 2017.
  1. hookeniggy
    hookeniggy Good at getting lost
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    I thought it was the other way around?
  2. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    Pump gas in Europe more resistant to knock, or detonate.
  3. Schlug
    Schlug JockeyfullofBourbon
    Jan 23, 2006
    12,401
    put something on and stay in that position.
    Doesn't a BMW 1150 GS have about 76 hp? I've ridden two up loaded for camping and never had a problem. With modern, and in the case of the 1150, not so modern FI, power loss is mitigated.
    daveburton likes this.
  4. Harvey Krumpet
    Harvey Krumpet Long timer Supporter
    Dec 26, 2011
    2,197
    The Shaky Isles
    Yeah, 75hp from my TDM has always been plenty for family getaways.
  5. Kommando
    Kommando Long timer
    Nov 28, 2006
    12,333
    By the Great Lakes
    When in doubt, try forced induction out.
    A turbo could be interesting. It seemed to make a WR250R power-wheely in the first 7 gears.
    When are those drum-charger things gonna be developed and brought to market?!
    Maybe a ram-air intake would help at altitude.
  6. DavidM1
    DavidM1 Unicorn hunting
    Mar 3, 2013
    1,996
    UK
    I like getting pretty close to flat-footing, but at 5' 10", 31", no chance with this. Has anyone got the lowered version? If so, what's that like?
  7. MGG
    MGG Adventurer
    Oct 7, 2019
    46
    Montreal, Canada
    Is there a reason for all that waisted volume? ... maybe expansion room?
    I guess a sharp metal punch would do the trick to put multiple small holes on either side of the neck?
  8. DavidM1
    Mar 3, 2013
    1,996
    UK
    The low seat is 20mm lower, which might be enough (probably not very comfortable, though). And the low link another 18mm. Either might be OK.
    At 875mm, the T700 is the same as a CRF250L which is manageable for me since it's about 60kg lighter, but with anything over 200kg I really need to be able to flat-foot (especially for city riding).
    The other rental company in Antalya will have the T700 soon, maybe next year I'll give it a go - http://www.turkeybikerent.com/en/yamaha-t-700
    LOL, I'm beginning to think there are a lot of mahouts out there.
  9. Dualsport4ever
    Dualsport4ever Been here awhile Supporter
    Dec 2, 2012
    938
    Canada - East Coast
    I think this looks so good to me because it makes the fuel tank and fairing look like one cohesive unit. Kinda like the original Dakar racers. Also it appears to visually lower the fuel tank ( i.e. makes it look "less tall"). Very sharp indeed.
    erey likes this.
  10. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,180
    Jefferson, GA
    Junglejeff1 and Singulano like this.
  11. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    Yes, thats exactly how it works, just one hole will do the trick:clap
    MGG likes this.
  12. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    A test team in The Netherlands got 426 km out of the T7 on one fill up.
  13. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    Kinda like the rims in blue.
  14. rideforzen
    rideforzen Long timer
    Feb 26, 2016
    1,430
    N.W. Oregon
    Many motorcycles come with an evaporative emission system designed to collect and store fuel vapors, but these systems are not designed to deal with excess fuel. So if you overfill your motorcycle fuel tank, the fuel can enter the fuel-vapor separator and then eventually the rest of the system, thus resulting in stalling or hard starting.
    HOW TO FILL A MOTORCYCLE GAS TANK
    The best way to prevent this problem is to read the instructions in your owner’s manual for refueling. When you fill your gas tank, the fuel level should barely touch the bottom of the fuel tank filler neck. This is how to fill a motorcycle gas tank the right way.
    https://powersportsandmore.net/scooters/shouldnt-overfill-motorcycle-fuel-tank/
    Unless you remove your evap system overfilling can cause problems. And I would leave some room for expansion also.
    MGG and Bt10 like this.
  15. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    We've done this trick with all sorts of Tenere's for 35 years now, on some models you gain 4 liters! Never any issues, it works fine on the T7 too.
    tonyubsdell likes this.
  16. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    420 / 260 km/mls on a full tank on the T7 now.
  17. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    A few used T7's already for sale in Germany.
  18. daveburton
    daveburton Been here awhile
    Jun 6, 2012
    272
    With closed loop fuel injection systems the fuel to air ratio is corrected so the motors run well however they produce less power as there is less air pressure at high altitude. I covered 5,000 miles across the Andes 2 up on an XT 660. It was injected so ran well and had enough power at sea level. Whilst it was OK at 15K ft, it lacked power. My estimated 80HP at sea level is based on about 55hp at 15Kft. Those on BMW 800s found it OK at 15Kft and they had circa 80HP at sea level so that supports the number.
  19. daveburton
    Jun 6, 2012
    272
    Not sure I understand this, just buy a bike with 75 to 80HP and it'll do everything. These days that means around 700 to 800cc.
  20. hookeniggy
    Oct 20, 2007
    2,114
    Santa Pola, Spain
    And what if you're below sealevel?:lol3
