Yamaha T700 Tenere owners thread
Discussion in 'Japanese polycylindered adventure bikes' started by BDG, Jul 17, 2019.
  1. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    5,811
    New York... The Finger Lakes
    I misunderstood what you were asking....
  2. powder85
    powder85 Been here awhile
    Feb 22, 2019
    179
    Barcelona
    I have a set of Motoz Enduro I/H FIM enduro tyres around, do you know if I can run the rear 140 safely on the T7 rim which has a 150 stock size?
  3. philratton
    philratton Been here awhile
    Aug 29, 2010
    524
    Nowhere
    Probably.
  4. Chalk
    Chalk Been here awhile
    Feb 14, 2016
    507
    England
    Picture from the rear
    amboss87 likes this.
  5. Chalk
    Feb 14, 2016
    507
    England
    It’s nothing to do with the license plate assembly. Just the photo makes it look that way
    Don’t forget, these are just a set made to work with the Yamaha rear rack for our upcoming trip.
    Nothing like what will be the production versions and the rear cross brace clears the exhaust exit, again photo is miss leading.
  6. Michel59
    Michel59 Adventurer
    Nov 7, 2017
    83
    France
    500km on road plus 100km off-road in Belgium 10 days ago.
  7. al803
    al803 Tenere700
    Oct 22, 2012
    790
    Greece
    Question on front brakes. Is the caliper radial or axial? What is the piston caliper diameter? 32mm or lower? Are the calipers floating or not? Thanks...
  8. ptgarcia
    ptgarcia Make America Great Again!
    Apr 26, 2009
    1,329
    Alta Loma, CA
    Looks like standard axial mounting in the picture.
  9. Olmer
    Olmer Been here awhile
    Oct 19, 2006
    157
    Land of Wine
    Hello, what size is your 21brothers bag ? (if i'm not mistaken !).
    Thanks,
    Olivier
  10. Michel59
    Michel59 Adventurer
    Nov 7, 2017
    83
    France
    It's a ROGAL XL (50L) from 21brothers. Great size for my needs.
    Michel
  11. Kommando
    Kommando Long timer
    Nov 28, 2006
    12,470
    By the Great Lakes
    ...unless you wheely everywhere.
  12. Kommando
    Kommando Long timer
    Nov 28, 2006
    12,470
    By the Great Lakes
    A lowly DR650/790 will tour/slab 2up with luggage. Cruising 90MPH might be a stretch, but that's not exactly legal in most locales. A TR650, G650X, or Dakar/Sertao would be even better on the slab.
  13. Kommando
    Kommando Long timer
    Nov 28, 2006
    12,470
    By the Great Lakes
    'Advantages of being wheely-capable.
    The front end of my DR feels pretty loose when it's hanging in the air too. Try riding a gear higher and/or sitting closer to the tank while kicking your inner leg forward as you accelerate out of a turn.
  14. Tobers
    Tobers Been here awhile
    May 23, 2003
    342
    Guildford, England
    Kriega tool roll fits beautifully under the Rally seat, which has a bigger storage area than the standard seat. Bit of a pain getting the seat back on as you need to simultaneously lift one bit of it while pressing down another bit.
    Did a couple of hundred miles of slab today on my T7 for a business meeting. All quite easy. 60mpg (Imperial) average. The bike sits nicely at 85mph but most of the time I was at 75mph. It will pop up to 90mph without a problem. There’s no buffeting as such (as per old 1150GSs which shook your teeth out), but there is what I’d term “thrumming” which I don’t find annoying but could be tuned out with a bit more airflow under the screen. I might take a look at those screen risers that have been created by someone on the Facebook group.
    Could do with cruise control for boring motorway trips. I might get one of those plastic throttle clip thingys.
    Otherwise all good, absolutely no ownership hassles whatsoever to date.
  15. Aleksandar_the_Great
    Aleksandar_the_Great Been here awhile
    Aug 20, 2019
    302
    Uk
    Do you mind me asking how tall you are? My 1200 gs adventure gives me buffeting.
    I
  16. Kommando
    Kommando Long timer
    Nov 28, 2006
    12,470
    By the Great Lakes
    I ride a lot of superslab 2up, but the dirt that I ride is sandy/muddy/rooty/rutty. A hopped-up DR does pretty well for my usage, but ABS and EFI would be nice. The DR is pretty smooth on slab, but a bit more power would be nice, and the roughly 100lb weight gain might add some slab stability. I have yet to do much for DR power mods though, like big-bore, cam, exhaust, or head.
  17. MotoPolo
    MotoPolo So many places, so little time Supporter
    Jun 4, 2015
    923
    Portland OR
    A steering damper will help the shimmy.
  18. al803
    al803 Tenere700
    Oct 22, 2012
    790
    Greece
    Does the clutch have an anti-hop mechanism or function? I mean to prevent the rear wheel from blocking when you go down the gears.
  19. Olmer
    Oct 19, 2006
    157
    Land of Wine
    Merci ;)
  20. Michel59
    Michel59 Adventurer
    Nov 7, 2017
    83
    France
    Bah, de rien Olivier!
    A pluche :jack
    Michel
    gpfan likes this.
