Yamaha T700 Tenere owners thread
Discussion in 'Japanese polycylindered adventure bikes' started by BDG, Jul 17, 2019.
  1. boboneleg
    boboneleg we can rebuild him.
    Mar 8, 2006
    1,802
    Bristol UK
    Those are just ads for dealers, none of those bikes are actually available at this moment
    Aleksandar_the_Great likes this.
  2. Aleksandar_the_Great
    Aleksandar_the_Great Been here awhile
    Aug 20, 2019
    302
    Uk
    I have called a few dealers and some of them don't even have a demo bike.
    The one I tested today he bought himself to have a demo and said he has 8 or 9 bikes on order.
    Season is almost over here so I'm not bothered as I don't plan on riding in the winter anymore.
    The bike is very very good.
    Bring on January :)
    Chalkie62 likes this.
  3. Chalk
    Chalk Been here awhile
    Feb 14, 2016
    497
    England
    Going back to spring rate. We are currently on a trip, two up loaded. The panniers total weight is probably under 20 Kgs and the preload is on max. So stiffer rear spring required.
  4. true grip
    true grip Been here awhile
    Aug 2, 2011
    573
    Centerville TN
    Trick is to find spring that’s stiff enough for 2 up/luggage but still soft enough for rider/no luggage. Really glad bike comes with pre load knob. Sometimes it takes a couple of tries but springs are not to expensive. Enjoy the trip!
  5. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,776
    uk
    The hydraulic PA on the T7 has 10mm of travel, which, based on the standard spring weight, can allow adjustment for up to approx 70-80kgs of extra preload.
    Like you say, the bike needs the correct spring for rider only, low fuel, then everything else is plus.
    We are nearly finished our bike to offer a range of heavier, linear-wound springs, and a selection of shims, so that owners can dial in exactly the correct weight of preload to get maximum use from the PA.
    mcmann and true grip like this.
  6. Chalk
    Feb 14, 2016
    497
    England
    So on short, your suspension won’t work for me.
  7. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,776
    uk
    Not sure what you mean?
  8. Chalk
    Feb 14, 2016
    497
    England
    If the range of the preload adjustment is 70-80 kgs. I use the bike one up, two up and as at the moment two up traveling. So a conventional shock adjustment screw will give me more range of adjustment than the hydraulic preload type.
  9. yokesman
    yokesman Long timer
    Sep 12, 2008
    2,802
    SW. Idaho
    just get a spring for 2 up
  10. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,776
    uk
    Not necessarily, when you change to a stiffer spring then you automatically increase the range of adjustment probably up to 90 to 100 kg,
    You are correct that generally a threaded colour will give more preload adjustment range than the hydraulic version, but the threaded colour is more difficult to adjust preload with, whereas the hydraulic version is just a few minutes turning of the handle, much easier to do before you leave for a ride
  11. Chalk
    Feb 14, 2016
    497
    England
    Your right, a hydraulic preload adjuster is easier. At the moment the biggest concern is although the bike isn’t heavily loaded the stability two up loaded is questionable. Lots of head shaking and in the wet the front ABS is very easy to activate unless you gradually applied the brake to transfer weight on to the front.
    I don’t think Mr Yamaha had two up travel in mind when they built this bike.
    djfoell likes this.
  12. jacinto
    jacinto Been here awhile
    Mar 7, 2009
    311
    South Belgium
    max load is 188kg, that is not much so traveling with pillion = stiffer spring
  13. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,776
    uk
    Check your PM's Chalk
  14. true grip
    Aug 2, 2011
    573
    Centerville TN
    Chalk you could move the fork tubes up in the triple clamps to get some geometry back. It would help with the light front end. Try 20 or 25mm see how it feels.
  15. wheresbaoskee
    wheresbaoskee Perpendicular to Everything
    Aug 8, 2017
    404
    No Matter Where I Go, There I Am
    Forgive the intrusion, but is there some recommended reading on this topic? How does one determine how many mm of change equates to changing in kg load range.
    Also, when you say 70-80 "extra" do you mean moving the range up from the baseline to that range, or adding that much to the baseline? The later seems like a *lot* of change for very little adjustment so I am thinking the former.
    So yeah, any recommended reading on this? The "how to" videos are fun and all, but I'd like to get a little deeper understanding.
  16. AdvNener
    AdvNener Long timer
    May 29, 2013
    3,188
    Marseille, France
    It is a spring.. displacement*rate = force
    about 7-8kg (or about 70-80N if you want to use a force unit) per mm is the kind of spring rate that is found on this kind of bikes for the shock.
    So 10mm of adjustment range => 70-80kg.
    Note these 10mm are directly on the shock.. due to how it is connected to the linkage/swingarm the corresponding wheel travel is always higher (about 2-3x ?)
    wheresbaoskee likes this.
  17. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,551
    Jefferson, GA
    https://www.cycleworld.com/sport-rider/suspension-setup-guide/
    wheresbaoskee and Motomantra like this.
  18. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,353
    Beaverton, OR
  19. Chalk
    Feb 14, 2016
    497
    England
    I’m not sure if dropping the forks through the yokes would help. One thing I’m going to check when we get home is the front wheel balance, sometimes the simplest things get overlooked. I know it won’t help the braking but it might be the cause of the wobble through the bars.
    One thing I have noticed which supports my thoughts about the lack of weight on the front wheel is
    The front tyre still has the nipple marks from the mould visible in the centre after 2000 miles !
  20. Chalk
    Feb 14, 2016
    497
    England
    Where did you get this info from please.
