Yamaha WR250R Mega Thread
Discussion in 'Thumpers' started by Sock Monkey, Apr 7, 2008.
  1. Dastard
    Dastard Just another guy
    Sep 25, 2004
    612
    wherever I am told to be
    My 08 pump just started crapping out (low fuel level and hot temps) and I have a new one on order that should arrive by friday. I can yank the old one tonight and get it mailed tomorrow, can't guarantee it will get there by friday though. PM me with what you think it is worth.
    D
  2. madisonreid
    madisonreid Long timer
    Dec 31, 2008
    1,709
    OK....Safari tank is on :D. Thank you to those who offered some suggestions. I also would like to thank the Aqualine Safari Tank crew for working with the service tech here to conclude the issue. It turned out to be confusing details in instruction and photos. With that said, many of you seemed to manage under the same conditions when installed. So [email protected]@T happens. Just glad she's on, airbox is modded, radiator guard is secured etc.... She's almost too pretty but as a commuter she be just fine. I do see a need for possible second set of wheels for more dirt oriented tires. Very happy with the overall package though. Will take pics later. Thanks again. :freaky
  3. SkidMarx
    SkidMarx Long timer
    Mar 27, 2006
    3,520
    USA
    Thanks, PM Sent.
  4. tshrey
    tshrey Been here awhile
    Sep 1, 2009
    219
    Mine was -5, the two others I did this to were -3. Mine wound up being happiest at +1, other two were zero and +2.
  5. MoBill
    MoBill Smiles when says dat
    Mar 10, 2007
    14,374
    NJ
    Which chain from them?
    I love the rear 48 I just got from them, coupled with the 13...it's a good mix for me, thinking 112 links (I'm running 110 right now, and it's all the way to the front)...but which chain? and just any master link?
    I'm dumb here.
  6. Chadx
    Chadx my toot toot
    Oct 29, 2007
    2,196
    Bozeman, Montana
    Used a 112 link Primary Drive 520 X-ring chain from Rocky Mountain (many other retailers carry them). I got the X-ring rather than the O-ring. The X-ring had a bit higher tensile strength rating and, they say, a bit better sealing ring than the O-ring. In the drop down menu, you select the number of links. Once you add that to your cart, you can order a master link from the same drop down menu.
    By the way, 112 link chain (with the 13/48T) even fit the Pirelli MT43 tire, but it was close. A 110 link would be OK with a stock tire height, but might be tight or not possible with a D606 or MT43.
  7. thirdcoaster
    thirdcoaster Been here awhile
    Oct 21, 2010
    135
    South Texas
    I picked up a barely used '09 WR-X recently with a Two Bros pipe & can and programmer. The emissions stuff is gone, the airbox door is open, and a NoToil filter was installed. I run av-gas, so my fueling tends to be weird anyway. As the weather heats up (95-100F), I've been chasing a stalling issue at idle, particularly when just cracking the throttle open, such as when leaving a red light in traffic:huh.
    I discovered the post below in this Mega Thread, and decided to play with the CO mixture setting. The stall is gone after richening the mixture, and the bike RIPS!!, but my '09 seems to have a little different setup than what is described below. I have a wider range of adjustment than the +-30 described below, and have run mine all the way to 50(in increments of 5) before performance started to suffer! I ended up leaving it at +40 for the day, and will try again tomorrow with a cold start to be sure I haven't created any new issues, then I will tweak the 2 Bros programmer.
    Does anyone have any additional information about the '09 CO menu that may shed some light? I did search, but didn't find anything useful besides the post below.
  8. skierd
    skierd Wannabe Far-Rider
    Jan 29, 2008
    3,477
    Fairbanks, AK
    Does the jumper wire have to remain in place, or can it be removed once the change is made?
  9. theBikeman
    theBikeman Dual Sport Rider
    Oct 12, 2010
    79
    Palatine, IL
    It can be removed. I removed the jumper after adjusting, and when I went in to readjust the settings remained at the changed level.
    Now does anyone know if this effects the fueling at all throttle postions or just idle? I have heard conflicting statements on this.
  10. MoBill
    Mar 10, 2007
    14,374
    NJ
    Thanks pal, mucho
    Updating the data thread too...I know a lot don't need it but I swear, I can't remember this stuff, when it's time to buy, every time is the first time.
  11. Wildhair
    Wildhair Adventurer
    Feb 13, 2008
    40
    South Carolina
    Can someone please tell me which radiator guard works with the new IMS 4.75 tank. I ordered a flatland guard, but it doesn't work. Sorry if this has already been answered, but I searched for sometime without finding an answer.
  12. mordicai
    mordicai Adventurer
    May 11, 2009
    42
    San Diego
    Force Engineering
  13. mordicai
    mordicai Adventurer
    May 11, 2009
    42
    San Diego
    If I remember correctly, Shewolf has her sag set at the minimum and has very little slider wear.
  14. rydnseek
    rydnseek reluctant poster
    Sep 9, 2006
    5,905
    I have the flatland & it works.. with just a simple mod. I bent the edge so no contact is made with the tank. No worries about vibrating a hole in the tank.
    <a href="http://s118.photobucket.com/albums/o84/rydnseek/wr250x/?action=view&amp;current=1105imstank09e.jpg" target="_blank"><img src="https://s3.amazonaws.com/advrider-photobucket-images/images/r/rydnseek_wr250x_1105imstank09e.jpg" border="0" alt="Photobucket"></a>
  15. EnderTheX
    EnderTheX Dirt Rider
    Mar 14, 2009
    2,823
    DFW Area, TX
    +1 on Force as mordicai answered.
    I have the Force radiator guard, high quality... installs easy.. fits well with 4.75 tank... as a mechanical engineer I will recommend them :D (also received in a timely manner from overseas).
  16. rydnseek
    Sep 9, 2006
    5,905
    No reason to remove it. I played with the co settings for a bit when i got the bike, but not since. The ground wire is still in place. It is for the o2 sensor, iirc, but it won't hurt anything.
  17. SkidMarx
    SkidMarx Long timer
    Mar 27, 2006
    3,520
    USA
    Good news.
    I was actually able to fix my fuel pump fitting.
    I was going to try a threaded pipe fitting, but there wasn't enough to thread.
    Instead I used some 8mm brake line.
    First I took the connector out of the pump housing. Major PITA because of the line in the pump it connects to.
    Then I drilled a pilot hole through the top of the pump fitting(I removed some material first).
    I heated the brake line up and pushed it into the hole. The plastic melted nicely. once it cooled, I couldn't pull it out if I wanted to. I jb welded it to be sure.
    On the other end, I rounded and smoothed the tip so it wouldn't chew up the soft orings in the fuel line, slipped a small oring over the line and put it where the ridge on the connector is. I JB welded that in place also.
    The only problem I has was that the bend needed to be sharper, and the line pushed a little farther into the pump. I had to make an extra ugly bent after I put everything back together so the fuel line didn't hit the valve cover.
    I should have took more pix, but I did get one crappy cell pic.
  18. SkidMarx
    SkidMarx Long timer
    Mar 27, 2006
    3,520
    USA
    Idle and something like the first 10% throttle. Think Pilot screw.
    I left my wire connected.
  19. DougZ73
    DougZ73 Fading off.........
    Oct 10, 2009
    7,544
    NJ
    What pressures you guys run in tires for dirt/gravel roads??
    I tend to run my tires about 25 PSI for pavement, and usually 12-14 for the soft sandy trails we typically ride on. I was thinking 20 PSI or so for dirt/gravel roads??
    I am going to be doing the southern part of the TNJT in the near future, and am guessing there is going to be a lot of dirt roads.
  20. MoBill
    Mar 10, 2007
    14,374
    NJ
    I never change it. 25. Just me, I think how much tread I have left is more important. :dunno
    And Doug, you know I ride that sand too. :D
