Yamaha WR250R Mega Thread
Discussion in 'Thumpers' started by Sock Monkey, Apr 7, 2008.
  1. rsteiger
    rsteiger Bob Supporter
    Jul 2, 2011
    1,088
    Hotlanta Area
    From what I have seen a lot of the issues with some of these kits have to do more with the installation than the kit itself. That being said I know of a couple of guys that had issues with cylinder base gaskets leaking and went through a few before finding something that worked.
    That being said I probably would not go that route myself since all of the bike's systems (cooling and transmission come to mind) have been designed and tested around it's stock configuration. Then again that is me.
    I say if the setup works for you then just go out and enjoy the ride and don't worry about other peoples opinions. :photog
    max384 likes this.
  2. rsteiger
    Jul 2, 2011
    1,088
    Hotlanta Area
    You may just want to try and pulling the programmer and see how it runs.
    I have ran my WRR with a modified airbox and a cat delete stock pipe for many many miles. There is some throttle hesitation when cold but is gone once the bike is warmed up. Plus I get better fuel economy without the programmer so they extra potential performance was not justified in my mind.
    I am currently running a FMF Q4 Hex with out a programmer and the bike runs fine as well. That being said my riding buddy has a similarly setup WRR with a FMF Q4 and he cannot get his bike to run as well without the programmer so there could be differences from bike to bike.
  3. AdvNener
    AdvNener Been here awhile
    May 29, 2013
    548
    Marseille, France
    About 47k km with a leovince exhaust and no programmer or whatnot.. so far so good.
  4. wwguy
    wwguy Been here awhile
    Apr 29, 2015
    591
    Boise, ID
    The communication from Athena below was posted today by a WRR rider over in the WR250X & WR250R Facebook group. He got a mere 5000 miles out his Athena kit before he starting experiencing leaking gaskets. 25 hours is ridiculously short life span for a piston, especially applied to a dual-sport bike. (Even my Beta 300 two-stroke can easily go 150+ hours between piston changes.)
    Bitingdog and FLICKIT like this.
  5. sperduton
    sperduton Been here awhile
    Oct 29, 2003
    601
    Lebanon Township, NJ
    Do you have the official name of that Facebook group? I'm having trouble finding it..I agree 15-25 hours is insane.
    Sent from my XT1585 using Tapatalk
  6. wwguy
    Apr 29, 2015
    591
    Boise, ID
    I've run two sets of Evolution Air pegs on my WRR and another set of the same on my Beta 200 2T dirt bike. I'm currently running a set of the new Evolution 4 pegs on my Beta and they appear to have the same mounting footprint as the billet Evolution Air pegs.
    With all that said I haven't experienced the issues in your photos. But I have mine mounted in the lowboy position and it appears yours are in the standard position. Looking at my photo below I can see how mine would probably do the same if in the standard higher position. (Not sure why they call it "lowboy" and "standard", because it's really "high" or "low".)
    Any chance you can mount yours in lowboy position without compromising comfort and ergonomics?
  7. wwguy
    Apr 29, 2015
    591
    Boise, ID
  8. woofer2609
    woofer2609 Less flow, more Gnar
    Sep 7, 2011
    1,654
    Extreme Pacific SouthWest (of Canada)
    Looks great!
    I like to have my axle tucked up as far as possible under the bike. Does it make a noticeable difference in the handling? IDK, but IMHO, it looks better.
    The only reason for keeping your chain long is that it will allow you to go to a 51 or 52t if you desire later on. It took me about 6 years, but I finally settled on 14/51 for most stuff, and switch to 13/51 when I need to.
    Bitingdog likes this.
  9. slomo
    slomo Labels Defying
    Dec 7, 2003
    299
    SoCal
    Thanks for the reply, I am actually trying to mount it in the low boy position ( but the springs are in the wrong position in my photo), any tips on compressing the spring during installation? I am going to look and try again tonight
  10. FLICKIT
    FLICKIT Long timer
    Aug 9, 2011
    2,052
    Down-under Down-under
    The installation instructions say much the same:
    "Service piston limit: we suggest replacing the piston after 15 running hours."
    http://www.athenaparts.com/files/pdfs/P400485100031-P400485100032.pdf
    No Ironbutts for the Athena, lol
  11. RideEm50
    RideEm50 n00b
    Oct 19, 2016
    2
    Los Angeles, CA
    I must have my EVO 3 mounted like WWGUY on my WRR. I don't have interference with the camber adjusting screw, but when the pegs pivot up there is contact with the upper mounting bolt or brake lever.
    As far as the spring is concerned I recall wishing I had another pair of hands to set the pin while I fought the spring to line things up. I did it by myself, but another person would have saved me a lot of time.
    slomo likes this.
  12. eakins
    eakins Butler Maps
    May 29, 2002
    31,495
    Fort Collins, Colorado
    That's a joke. I would replace a piston every long weekend backroad tour I take.
    Why would anyone buy that for a WRR and why so low? They can't make a piston any better to last longer?
    max384 likes this.
  13. Star_Platinum
    Star_Platinum Adventurer
    Oct 16, 2018
    82
    USA
    What's the best tank upgrade once I get my wr250r? Anything else I should know about upgrading gas tanks?
  14. KevinMTB
    KevinMTB Been here awhile
    Dec 4, 2007
    205
    The middle of the Pacific
    There has been a lot of talk about the Athena big bore kit and how it will reduce the reliability of the WR which I'm sure it does. However, it might not be as extreme as some say. I believe that it was Crawdaddy who asked me about mine and installed one on his bike and had issues at low miles. I put one on my bike because I didn't like that when I twisted the throttle I had to wait for the engine to slowly build up speed. My buddy left his stock and it was terrible to ride, however, we both realized that by changing the gearing to 13-50 it made the bike much more fun to ride in stock form. It's interesting that I put on a Power Commander and Auto Tune with my big bore but took it off when I was having an issue with my bike, it turned out the issue was with an aux LED light that I had installed that had developed a short. I never did put the PC back on and have had no issues since, seems strange but my buddy and I both have a temp gauge on our bikes and my bike usually runs cooler so I figured it can't be too lean. Anyway, I have just over 20,000 miles since I put the Athena on (I put it on with just over 1,300 miles on the bike) and the only issue I had was I thought it started burning oil so I changed the rings only, some time ago. You might be taking a chance by putting on a big bore kit but it worked out so far with me, besides, I still have the original cylinder and piston that I can throw back on if I want.
  15. max384
    max384 Bandaided Supporter
    Nov 23, 2011
    5,840
    Eagle Rock, PA
    One of the best things about the WRR is it's reliability and long service intervals. Ruining that for the sake of a few extra horsepower is dumb IMO.
    PlowHand and Plebeian like this.
  16. ridepjride
    ridepjride Migrant
    Jan 28, 2006
    462
    Vacaville, CA
    I’ve bought several tanks from justgastanks. Lots of info on their website.
    Size depends on your range requirements, 3 to 4.7 gallons.
  17. slomo
    Dec 7, 2003
    299
    SoCal
    So I figured out how to mount the pegs and springs on the Evo4 pegs, but the springs supplied must not be the right ones since they look nothing like @wwguys’ pegs and the part that hooks onto the peg falls into the step of the peg after a few rotations of the footpeg up and down.
    [​IMG][​IMG]
    Gonna call the dealer and maybe PMB to figure out if maybe I was supplied the wrong springs.
    I like the pegs, the fitment on my WRR just isnt the best.
  18. Stebbo
    Stebbo Adventurer
    May 16, 2011
    90
    North Queensland, Australia
    Thanks for that. I'm going to order in the next couple days. Nobody else sees any issues with those tyre sizes?
  19. IanInCalgary
    IanInCalgary Been here awhile
    Nov 22, 2011
    261
    I'd avoid tires that are more than one step lower in load capacity. The front tire is three steps lower..
    If you get the small tire you'll need to run higher pressure, and you'll be more at risk of pinch flats. One of my riding partners used a small front tire and had problems . Two pinch flats and one overheat failure when his pressure was too low.
    I use 90/90 front tires.
    Ian
  20. sperduton
    Oct 29, 2003
    601
    I have the same thought process..I have stock parts to put back. Im going to assume if piston starts to wear, it will be rings and bike will start using oil. Then I'll do a ring change. I am mechanically competent. I don't pile miles on my bike as all my riding is off road trails so if in 5 years or so I need change a piston, I'm ok with that. With not having ridden a stock bike. I sure love the way this bike performs with the kit. I came from riding a drz 400 for 18 years and still have it for a spare bike.
