1. eNewsletter Sign Up
Yamaha WR250R Mega Thread
Discussion in 'Thumpers' started by Sock Monkey, Apr 7, 2008.
  1. Circus Bear
    Circus Bear FKA oldsteed Supporter
    May 6, 2015
    227
    Marietta, GA
    :deal
    I'm still running the original pump on my 2008. No issues yet, but I have a replacement ready when it fails. I run 87 in it with no issues and only put ethanol free gas in there when I know it will sit for a while. I have other bikes that only get ethanol-free, but the WRR is tough enough to handle it.
  2. woofer2609
    woofer2609 Less flow, more Gnar
    Sep 7, 2011
    1,914
    Extreme Pacific SouthWest (of Canada)
    Well now you've done it!
    I definitely notice more green oxidation in carburetors that have sat with ethanol gas in them than I used to. I try and let the bike winter over with a tank of Seafoamed Chevron 94 octane.
    Circus Bear likes this.
  3. coresports
    coresports DS4Life
    Aug 3, 2011
    124
    USA
    Me too...2008 WRR original pump...bone stock bike.
  4. PlowHand
    PlowHand Ancient, ugly and happy :-) Supporter
    Jan 3, 2015
    1,477
    North-Central-Indiana
    Seafoam is the best invention since the wheel - or the carburetor - or the fuel injector.
  5. eakins
    eakins Butler Maps
    May 29, 2002
    35,415
    Fort Collins, Colorado
    It was just a pump supplier issue and that supplier building the pump slightly different so it does not bind when hot.
    I just replaced my 08 proactively.
  6. eakins
    eakins Butler Maps
    May 29, 2002
    35,415
    Seafoam was in the bike that had a fuel pressure regulator go bad from sitting.
    Yes Seafoam is loved but never really claimed as an ethanol solution unlike
    https://www.goldeagle.com/product/sta-bil-360-marine/
    I use this for winter storage and Walmart has it on the shelf. Avoid the cheaper Stabil red, it's for storage but not storage and ethanol.
    https://www.amazon.com/STA-BIL-22240-Marine-Vapor-Technology/dp/B001CAW2DK
    Or
    http://www.starbrite.com/startron
    Which is available at Napa.
    https://www.amazon.com/Star-Tron-Enzyme-Fuel-Treatment/dp/B002E9A6PO
  7. Border411
    Border411 Been here awhile
    Sep 24, 2017
    400
    Northern Virginia
    Best avatar I have seen....FYI
    Yinzer Moto and PlowHand like this.
  8. PlowHand
    Jan 3, 2015
    1,477
    Thanks, my girls are getting old like me but unlike me they are still cute. :-)
    Border411 and Yinzer Moto like this.
  9. Border411
    Sep 24, 2017
    400
    Northern Virginia
    Dont sell yourself short. Every night when I look in your window you still look good. I mean....um....disregard.
    rsteiger and PlowHand like this.
  10. woofer2609
    Sep 7, 2011
    1,914
    I add Seafoam to Chevron 94 octane which is ethanol free, so I have no expectations of it treating ethanol.
    eakins likes this.
  11. eakins
    eakins Butler Maps
    May 29, 2002
    35,415
    Ah got ya, you didn't mention that.
    That must be an local area thing you just expect to find. Not so around here.
    And no Seafoam does not claim to solve ethanol problems. If find it does not do much vs other products.
  12. eakins
    eakins Butler Maps
    May 29, 2002
    35,415
    If you guys are looking to really clean up your injectors and carbon deposits, PEA - polyether amine, is the best ingredient.
    If a cleaner does not have that then it's just using less effective & cheaper distillates.
    Redline SI-1 has the most (more than 44k, Techron & others) and is thus tops. It can be found at O'Reillys.
    https://www.amazon.com/Red-Line-Complete-System-Cleaner/dp/B000CPI5Z0
    Of course these are not ethanol treatments like marine Stabil or Startron or everyday additive like Lucas fuel treatment.
  13. eakins
    eakins Butler Maps
    May 29, 2002
    35,415
    An excellent fuel routine would be Redline clean in the late fall, oil change right after, fresh tank of gas w/marine Stabil for winter storage, use Lucas every tank the next season till the next Redline clean & repeat.
  14. Magestyk
    Magestyk Da'Salty^Soldier
    Aug 10, 2006
    409
    Planet Earth
    eakins likes this.
  15. mikko
    mikko 60% of the time it works every time
    Apr 6, 2011
    1
    Sconnie
    Winter appears to be here in Wisconsin and am looking to store the bike for winter. Looking to store this year without heat or power for a tender. Is it okay to remove the battery for winter to store at home? I recall reading of some head units dying from dead batteries, or is that unrelated? Never had a problem pulling batteries for winter in the past, but want to confirm.
  16. toddhopper
    toddhopper Old and in the way
    Apr 15, 2011
    15
    Elk River,Mn
    For what its worth, I'm in Minnesota and have pulled the battery on my '13 every winter since new. No issues with dash or anything electrical. Same with the '03 SV650.
    Plebeian and drifteast like this.
  17. inder
    inder Adventurer
    Jan 31, 2011
    11
    Atlanta, GA
    I'm trying to re-install the EXUP on a new to me WR250R. Can anyone confirm the orientation of the cables? Is it really as simple as cable 1-1 and cable 2-2? The only reason I even ask is because this orientation forces the cables up against the hot exhaust pipe (in my case).
    Also, Is there a diagnostic test like the fan test to confirm the correct functioning of the unit?
  18. Proud Highway
    Proud Highway one hand waving free
    Jan 16, 2011
    283
    Get it into Diagnostic Mode:
    and select D1:53
    Demo of EXUP operation in Diagnostic Mode:
    woofer2609 likes this.
  19. PlowHand
    Jan 3, 2015
    1,477
    Ethanol sucks, avoid it if you can...
  20. drifteast
    drifteast Adventurer Supporter
    Dec 27, 2014
    98
    Ottawa, ON
    Yep, saw that recently as well :eekers Incidentally, one of the best Youtube channels going IMO!
