Yamaha XT500
Discussion in 'Thumpers' started by TimberlineAdventure, Mar 29, 2008.
  1. motocrossross
    motocrossross Been here awhile Supporter
    Dec 11, 2009
    280
    southern illinois
    It seems pretty good, not ungodly loud, not as much on top as an open silencer, but better bottom and mid. One thing, the supertrapp discs are stamped differently now. There's supposed to be .023" between the discs installed, ive got an .023 wire feed welder, and the wire will not fit between the newer discs. I had a stack of 3" discs from eons ago, .023" will fir between those, so im running the old discs. It wouldnt run right with the newer ones, too much back pressure, even with 16 discs.
    I'm working on another muffler, its a street bike can, it will be longer, with 4" supertrapp discs. Its round though, and i can't figure out how to keep it from invading on the tires space. Im a hammer mechanic, not an engineer.
    Old Smokey likes this.
  2. ReidCycles
    ReidCycles Adventurer
    Sep 16, 2011
    69
    Nor-Cal
    Hey Old Smokey, the FMF can on that yellow TT MX’er is for a Honda CRF150R. We’ve done a few like this. Use a TT head and mid pipe, then grafting on the 150 slip on takes minimal fab work and the can’s mounting bolt lines up about perfectly to the TT’s mounting tab. Not period correct, but they sound great, not obnoxiously loud and come in USFS versions. Cheers, Reid Cycles
    motocrossross and Old Smokey like this.
  3. motocrossross
    Dec 11, 2009
    280
    southern illinois
    New 390mm Hagon trail shocks. Much better than the originals. IMG_20200424_175642336~2.jpg
  4. Old Smokey
    Old Smokey Long timer
    Dec 9, 2014
    1,047
    First trail ride on the rebuilt xt in the books. Got a few paint scratches and battle scars. Makes the bike look a bit nicer to be honest. In its element.
    enduro16, joe cool, plugeye and 3 others like this.
  5. motocrossross
    Dec 11, 2009
    280
    southern illinois
    Your bike looks brand new, Old Smokey. Nice job!
  6. motocrossross
    Dec 11, 2009
    280
    southern illinois
    Old Smokey, how is the TM carb working? Mine has VM34ss from a '76 TT500 at present. I've been thinking of replacing it with something....
  7. Old Smokey
    Dec 9, 2014
    1,047
    It’s so good. I love it. Easy starting, and great throttle response. Very crisp. I can share my jetting if you go this route. Very much recommended.
  8. morini
    morini Newbie
    Jun 3, 2013
    78
    AFDD4FA5-2291-4DF8-A041-74DC93ACE9D5.jpeg Last year I bought a ´79 TT500 which I think is one of the coolest bikes ever made. This example is original, has some battle scars from being used as intended, but has been kept technically in shape. Since I always end up trying to optimise my bikes I have been thinking about replacing the shocks with YSS 390mm and possibly installing a YZ fork (since I have a good one offered to me for a good price). The 390 swap is mainly for the esthetics (and for the higher quality shocks) since I think these bikes are a little low in the rear. To be honest I am a rookie off tarmac so the extra height is mainly vanity and hoping for a bike that looks a bit like HL500:-)
    1. How much taller are the YZ forks? Will the relative height front/rear be the same as original with 390 + YZ? Any pictures of 390+original fork vs 390+YZ fork for comparison?
    2. The YZ fork I am offered come with steering stem and clamps. Will they fit directly in my bike or do I need to use the originals and bore them up? I understand I need a brake plate from the YZ for this to work.
    3. My bike has the aluminium swingarm. Does this have the same geometry as original so that 390 is the highest I can go on shocks?
    Mr Puffin and Tritwin like this.
  9. plugeye
    plugeye MC rescue
    May 11, 2007
    7,238
    Garland, Texas USA
    airbox flange cracked, on with a pod filter
  10. plugeye
    plugeye MC rescue
    May 11, 2007
    7,238
    Garland, Texas USA
    not too obnoxious...yet
  11. Old fart
    Old fart Keen AG100 rider
    Oct 21, 2006
    1,146
    South By Southwest near the dotted line
    Trouble with those breathers is they blow oil when you do a long wheelie after about 1 K. With your setup it would just fill the filter with oil, with the standard airbox and a long wheelie the oil travels up into the bottom of the box and sprays into the foam. It sprays that much oil onto the filter that the engine gets oil straight into the carb. You loose power, the front wheel drops and you leave a trail of smoke screen :D called doen a smokey in the olden days
    Chevette likes this.
  12. plugeye
    plugeye MC rescue
    May 11, 2007
    7,238
    Garland, Texas USA
    dont worry, i aint doin any long wheelies
    mrsdnf likes this.
  13. plugeye
    plugeye MC rescue
    May 11, 2007
    7,238
    Garland, Texas USA
    revision A, mate up with DR350 case vent
  14. plugeye
    plugeye MC rescue
    May 11, 2007
    7,238
    Garland, Texas USA
    top end time
    Mr Puffin and brg like this.
  15. plugeye
    plugeye MC rescue
    May 11, 2007
    7,238
    Garland, Texas USA
    77 XT500 been ridin since last year, running well. my buddy dave mic'n the works. low mileage barn find with standard bore & rings still in spec.
  16. plugeye
    plugeye MC rescue
    May 11, 2007
    7,238
    Garland, Texas USA
    back on the road
  17. Old Smokey
    Dec 9, 2014
    1,047
    Had my xt out for a couple hundred KM this week. Switched to a 4” supertrapp muffler from a wide open cone engineering big mouth. Volume is better (10 discs) though still suitably loud. Jetting had to go way leaner to run well though. Think I got it now.
    Mr Puffin, g®eg, JohnE65c and 3 others like this.
  18. g®eg
    g®eg Canadian living in exile
    Jul 13, 2004
    8,756
    48.8436788,-122.599317
    2 quick noob question for the XT500 aficionados..
    I am going to look at a pretty clean '78 on Wednesday (and by look I mean bringing cash & riding it home).
    1) I used to have a Honda XR 650L, and one of the issues was making sure the oil temp didn't get out of control. For that I added the XR's Only Oil Temperature Dip Stick. Is oil temperature something i should be aware of with the XT?
    2) Curious about fuel mileage since I don't want to be a complete boob on the side of the road. Fuel capacity US 2.3 / 8.8 l, so I am guessing 80-90 miles between fill ups?
    thanks!
    if successful I'll post some pics after the deal.
  19. Old Smokey
    Dec 9, 2014
    1,047
    I also have an XR650L so I can comment on that.
    I haven't had any of the same overheating issues on the XT, and I'm running a 10:1 piston and hotter cam. I've read that oil coolers are often not a great idea on the XT as the cooling system is more than adequate. Adding a cooler can make it difficult to reach temp on shorter rides and burn off condensation, etc.
    I have seen them on the Dakar bikes, but riding full-out in the desert isn't something the average rider is likely to do.. Also have seen them on SR race bikes occasionally. I'd not bother with it.
    Fuel milage - it really depends on the engine setup, and if it's in good tune. For reference, I have a 36mm TM36-68 pumper carb, 4" supertrapp, 89mm 10:1 and megacycle 251040 cam, Rex ignition. I get about 41mpg when riding on the pavement at about 50mph, with a 14/44 gearing. That puts me at 92 miles till I'm bone dry.
    With stock gearing, stock engine and carb, I think you could do closer to 45-50mpg.
  20. g®eg
    Jul 13, 2004
    8,756
    wicked!
    thanks for the quick & detailed reply!
    teaser pic... how could anyone say no to this beauty?
    Belgradian, brucifer and plugeye like this.
