Yet another dual-sportster
Discussion in 'Some Assembly Required' started by Aiden, Apr 29, 2020.
  1. Aiden
    Aiden Adventurer Supporter
    Aug 23, 2021
    35
    NYC
    I figured I'd share my dual sport sportster project while I'm stuck in quarantine.
    It started life as a '99 883 Custom with lots of chrome and skulls.
    Here's how it sits now:
    Ginger Beard likes this.
  2. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,023
    What do you have for ground clearance? What size front wheel?
    bike looks good.
  3. Aiden
    Aug 23, 2021
    35
    NYC
    This is how it started life. It had been sitting on the side of the road under a blue tarp gathering rust when I got it.
    First things were some longer shocks, an 18" rear wheel, and new fenders. I also cut up an old ironhead seat and put a new exhaust on.
    Then the big project was putting on a KTM frontend with WP 50mm forks. The ugly tank lift was to provide clearance for the forks.
    Someone took some beauty shots at a local motorcycle show:
    But the tank had to go in favor of an old superglide tank for more fuel capacity. It also allowed for a larger steering lock, which it really needed.
    Add an oversized Supermoto rotor + a thicker seat and we get here:
    Ideally, I'd like some longer shocks for more ground clearance and maybe lowered footpegs.
  4. Aiden
    Aug 23, 2021
    35
    NYC
    Thanks, it's the stock 21" wheel from the KTM frontend.
    I haven't actually measured—ground clearance is ok, but not great. I thinks some 16" or 16.5" shocks would help. The forks can also still drop about a half inch lower in the triples if needed.
  5. davide
    davide Been here awhile
    Aug 14, 2006
    634
    Elizabeth, Colorado
    Bad ass!
    -sarge- likes this.
  6. c1skout
    c1skout Long timer
    Sep 29, 2009
    1,906
    Western PA
    Looks good! How much fab work to mount the superglide tank? I was always partial to those.
    CopyCat likes this.
  7. h0lger
    h0lger Adventurer
    Oct 5, 2016
    48
    Tallinn, Estonia
    Do you get a lot of angry looks from "real Harley riders" on this thing?
  8. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    826
    behind the cheddar curtain
    Yes, please elaborate on the Superglide tank. I have severe restrictions with my Magnums. And tell me about the fairing please
    #8
  9. Aiden
    Aug 23, 2021
    35
    NYC
    The superglide tank's pretty straightforward to mount. I don't think there are any aftermarket versions—I got a crusty one off of ebay.
    I trimmed the front tabs and drilled them so they lined up with the stock mount on my frame. Then I added some rubber U-shaped tank bumpers from an old dirtbike to keep it from rubbing on wiring etc. The rear mount uses the small hooks on the superglide tank and a rubber strap to hold the tank down.
    You probably need a 90 degree petcock too since the tank will sit a bit lower than stock. I can take some pictures next time I have the tank off.
    The headlight/cowl is just a universal Acerbis piece. Mounts up super easily with some rubber straps around the fork legs and some simple wiring. I swapped the bulb for an LED one and drilled holes to mount the turn signals.
    #9
    spokester and CopyCat like this.
  10. Aiden
    Aug 23, 2021
    35
    NYC
    Most Harley guys I've run into like it. But I rarely see the half helmet and fringe crowd, so who knows.
    #10
    scot_douglas likes this.
  11. CopyCat
    May 16, 2015
    826
    Thank you. Do you think it might fit my 2000? Im not much of a Harley guy yet, what years were these on Superglides? And may I ask the stated capacity?
    #11
  12. r60man
    r60man Long timer
    Mar 14, 2013
    2,692
    Centralish PA
    I really like this a lot. I am looking to build one myself. The white seat cover is a bold choice, I applaud that! :clap
    I really like the looks of this build. Any idea how much you have into it overall?
    #12
  13. Aiden
    Aug 23, 2021
    35
    NYC
    I have a 99, so we should have the same frame. There have been a few "Superglide" models over the years, but I believe you want a 70s tank. If you do a search on ebay for "superglide tank" and filter by used, you'll see them—it'll be obvious.
    I believe fuel capacity is a little over 3 gallons.
    #13
  14. Aiden
    Aug 23, 2021
    35
    NYC
    Thanks! Looking at the cumulative cost of a build is scary, but I have just under 4k in it.
    #14
    r60man likes this.
  15. r60man
    r60man Long timer
    Mar 14, 2013
    2,692
    Centralish PA
    That isn't bad at all. You looking at adding panniers?
    #15
  16. humancertainty
    humancertainty Annihilate all week long Supporter
    Jan 2, 2015
    7,982
    Chicago
    @aiden what era forks/trees did you use? I’m rebuilding and updating an 88 FXRP right now but I’d like to do something like this in the not-too-distant future.
    I actually have a 1990 Sportster project I was thinking about doing up like this but I kinda want to have a five speed.
    #16
  17. Aiden
    Aug 23, 2021
    35
    NYC
    I have some Nelson Rigg soft bags that go over those racks. They seem to work well.
    #17
  18. Aiden
    Aug 23, 2021
    35
    NYC
    I used the frontend from a 99 KTM EXC, which has the 50mm WP Extremes and brembo brakes. The wheel is actually off of a SX from the same era, so I didn't mess around with the speedo parts that the EXCs have. Helps to give it a cleaner look.
    I believe a bunch of KTMs from 98 and 99 used that same setup, but it's hard to find new parts for them. Lots of ebay hunting.
    You'll have to get stiffer springs and probably heaver oil too.
    #18
    madrider5150 and humancertainty like this.
  19. Glenflo
    Glenflo n00b
    May 17, 2020
    5
    Indonesia
    It's a great build, mate.
    If you don't mind, you can check my video on YouTube. Harley Sportster Dual sport by Jim Carducci
    #19
  20. madrider5150
    madrider5150 Riding somewhere
    Oct 15, 2013
    1,446
    PNW
    Have you shortened the length/travel on the forks? Do you recall what weight springs you are using? Mine are .58 I believe which are custom but my suspension guy doesnt think thats heavy enough. Covid has threw a wrench into getting my suspension sorted.
    #20
