    Dismiss Notice
Your favorite Macgyver moments\tricks
Discussion in 'The Garage' started by HaChayalBoded, Sep 21, 2008.
  1. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,600
    Middletown, PA
    And if you need something larger in diameter than a toothpick (or don't want to use a number of them), bamboo skewers work well and are a tougher fiber than what toothpicks are made from.
    Zahnarzt and Dave MP like this.
  2. 2000RSV
    2000RSV Go Fast, Go Long Supporter
    Nov 21, 2007
    6,192
    FDL, WI
    Done both toothpicks and bamboo skewers several times - with some Elmer's glue. Interesting thought of using wall anchors. :hmmmmm
  3. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,600
    Middletown, PA
    I would still prefer glued-in wood stock to reinforce the door's original wood frame. The plastic wall anchors are OK for lower weight uses, but door hinge fastening - IDK. Toggle bolts would work much better but would be a more permanent fastening of the hinge to the door.
  4. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,600
    Middletown, PA
    Great minds and all that... The Sept 2020 edition of Fine Homebuilding just came and in it was a reader tip to use - Chinese takeout chopsticks for reinforcing screw holes.
    goD giB likes this.
  5. Wadester
    Wadester Rides a dirty bike
    Jun 21, 2008
    2,389
    'Cruces
    If you really want the fix to last, use steel wool saturated with Elmer's glue.
  6. MiamiMotorcyclist
    MiamiMotorcyclist used to be -MiamiUly
    Jul 11, 2007
    6,957
    Miami, Fl.
    The door I “fixed” should really be replaced but I don’t think it’s an off the shelf item and wanted to see what I could do in the mean time. Had the anchors handy so I figured why not try?
    Bottom hinge so maybe that will help.
    The owner can replace it when he’s ready.
    zap2504 likes this.
  7. goD giB
    goD giB Long timer
    Dec 2, 2016
    1,119
    Mate, if it's hanging and opens and closes the rest is academic.
    (You done good)
    MiamiMotorcyclist likes this.
  8. Billyj7175
    Billyj7175 Been here awhile
    Feb 4, 2017
    157
    Sooner State
    Years ago (mid 80's) my boss and I were out in a welding truck (Ford F250 w/utility bed) and the throttle cable broke. He finds some bailing twine in the field and ties it to the throttle arm on the carb, routed it through the firewall and tied it off on the wind window lock/lever. Pretty ingenious I thought until we get back to the shop and he opens the door to get out and unlock the building....floated the valves on that motor until he got the door back closed.
    longwaypyder and keepshoveling like this.
  9. Beemeup
    Beemeup 1978 R100/7
    Sep 1, 2014
    1,428
    Washington State
    I use a wooden dowel and drill bit the same size.
  10. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,304
    Denmark
    A friend had a hanging idle, and rough running of his bike. It turned out the fuelscrew fell out.
    I Installed an earplug instead of the fuelscrew, so the bike wouldn't suck air in through the hole.
    The idle settled pretty good, and the bike no longer stalled on the ride.
    vanislejay, Overdog and z_rider like this.
  11. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    13,969
    SF Bay Area
    Heh... a week or so ago I needed more than toothpicks, golf tees, or chopsticks could easily provide. I chucked a bit of scrap broom handle into my lathe (sacrilege, I know) and turned it down to an appropriate size. I glued the plug in place before drilling a pilot hole for the screw that had pulled out. Took me longer to clean up the lathe than make the repair.
    X5- and Ladybug like this.
  12. ROAD DAMAGE
    ROAD DAMAGE Long timer Supporter
    Jun 3, 2007
    3,306
    Steamboat Springs, COLORADO
    I've installed hundreds and hundreds of doors over the years.
    My "go to" screw hole reinforcer are Domino Kitchen size matches.
    Then I keep a few golf tees for the larger screws in big entry doors.
    Dip then in wood glue, insert, and break off.
    I'm always surprised at just how many NEW pre-hung doors have stripped screws because of impact drivers and inattentive "craftsmen".
  13. Beemeup
    Beemeup 1978 R100/7
    Sep 1, 2014
    1,428
    Washington State
    A lot of doors have some very short screws too. Normally, just driving in longer screws does it.
    Mjpickering and z_rider like this.
  14. goD giB
    goD giB Long timer
    Dec 2, 2016
    1,119
    Ah, like the aluminium joinery in our sleepout?
    Been meaning to look for a suitable fix for the 2/3 screws that some freely but won't back out either.
    P.S. as an IT guy, if a human can fuck it up, a machine can fuck it up faster.
    Mjpickering, z_rider and RolyKBiker like this.
  15. ROAD DAMAGE
    Jun 3, 2007
    3,306
    As an IT guy, you must be very familiar with "PIBCAK" issues .....................................................
    "Problem Is Between Chair And Keyboard" :lol3
    :imaposer
  16. MN_Smurf
    MN_Smurf Capt_Confusion
    Nov 5, 2010
    4,270
    Oxford, MI
    The proper acronym is PEBKAC......Problem Exists Between Keyboard And Chair
    :lol3
    z_rider, thanosgp and goD giB like this.
  17. jfauerba
    jfauerba Been here awhile
    Dec 18, 2015
    456
    Asheville, NC
    Or PICNIC....Problem In Chair Not In Computer
  18. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    36,615
    Annapolis, MD
    I ran across this old picture from 77 or 78.
    IIRC, a length of clothes line cable buried in a mud hole broke my shifter off and tied up the back wheel. By the time I got it out of the back wheel, I had a shit ton of "safety wife".
    It got me home.
    GotDammitDave, thanosgp and goD giB like this.
  19. z_rider
    z_rider Goin' plaid!!
    Jun 4, 2019
    59
    South OC
    100% embodies the spirit. And it's also a reminder of why I love to do this. Stop me or someone in my entourage? Good luck! In case ya didn't notice we're goin' thata way...
  20. theothersean
    theothersean dirty boy
    Jul 28, 2005
    1,743
    middle of nowhere (central mass)
    First world problems. Wife’s new four wheeler is slightly longer than the old one so I can’t get the tailgate closed, which is an issue if I want to tow a trailer. Simple fix. Some scrap plastic tubing , couple nuts bolts and washers. When it’s in place the tailgate doesn’t move up or down and stays locked in the 3/4 closed position. Just saved my self $69 on the store bought solutions. Takes less than minute to install each side.
