Yuasa YT12-BS vs YTX14-BS
Discussion in 'Parallel Universe' started by Flopix, Sep 9, 2018.
  1. Flopix
    Flopix Been here awhile
    Aug 27, 2016
    125
    Hello guys
    My bike needs to be on a truck next Saturday, direction Las Vegas. As I was preparing it and testing everything, I noticed my battery wasn't doing so well. I used my 12V pump for like, a minute.... and then decided to fire the bike just in case.... and it started but there was a moment when I thought it wouldn't.
    I know the pump can pull a lot of amps so... maybe this is normal. But I've ridden the bike since and I feel the battery isn't 100%. I plugged my charger tonight, it will help a bit I guess but I can't say I feel confident.
    I could probably get a new battery before Saturday, it's tight, but doable.
    But I also have a YT12A-BS in my Aprilia Tuono, it's almost new (about a year), the size is almost the same (the YTX14 is a bit taller)... Could I simply use that battery?
    YTX14-BS has more CCA (200 vs 175) and has 1.4A vs 1.0... but a mostly new YT12A-BS is certainly better than the YTX14 at the end of it's life... Any opinions on that?
  2. Flopix
    Aug 27, 2016
    125
    Well, nevermind. I double-checked the specs and the YTX14-BS is 40mm taller. The smaller YT12A would probably work, but I don't think it can be installed safely.
  3. shuswap1
    shuswap1 Long timer
    Mar 30, 2014
    1,714
    British Columbia, Canada
    Maybe next time (hopefully there won't be one) you need the pump, with a questionable bat, just leave the engine running. Once a bat shows weakness, it's almost always down hill from there, unless it was discharged from sitting too long or has a parasitic draw.
