YZ250 Woods Build
Discussion in 'Thumpers' started by Auto-X Fil, Jan 2, 2015.
  1. Auto-X Fil
    Auto-X Fil Been here awhile
    Feb 17, 2013
    894
    Montrose, PA.
    I am currently setting up a 2000 YZ250 for woods use. Since these are pretty popular trail bikes these days, I thought I’d put together a build thread with my findings, to help others with their setups.
    Why a YZ250? They are dirt-cheap, and readily available. I was looking for a KTM, but couldn’t find one in good shape for a price I liked. If I wanted a ready-to-ride bike, I would have kept hunting for an EXC, and paid more. It would have been cheaper and less work in the long run. As it was, I wanted a project, and a YZ has all the right basics. Low weight, great power, high reliability, cheap, available parts, etc. There's no reason that a modified YZ can't be every bit as good a bike as a KTM or Husaberg or Beta of the same era.
    As-delivered, the YZ lacks in certain areas for woods/trail/enduro use:
    The suspension is high-quality, but valved for MX. 1996-2004 are all the same basic shock and forks. 2005+ are on odd year, not compatible with anything else. 2006+ are better-valved SSS forks. However, there’s no reason that well-valved 46mm forks can’t perform wonderfully. It’s just that stock, they have crazy stiff low- and mid-speed compression for woods. It seems like most people even tone them down for MX. I'll go WAY into depth on this in another post.
    The motor is great, but was a lot for a C-level rider like me to handle. A great rider might prefer it stock. It chugs well and pulls like a monster when it hits the pipe. It tends to roll onto the pipe pretty smoothly, more than hitting like a 125, which is a great characteristic for this kind of riding.
    The first thing I did – the first thing I do on any bike – was to get the controls set up for me. I chopped the bars 2”, put on new levers, cut/bend them to my liking, added handguards and new grips, replaced worn and sticky cables, and lubed everything. I also moved the shifter and rear brake into position for me. Once that was done, I felt more at home, and could begin to feel the bike out.
    As I rode around in stock form, the biggest thing I noticed was that the throttle was very touchy. On smooth terrain, I could modulate it. On bumpy, technical stuff, I was working incredibly hard to control the throttle and keep the bike from taking off on its own. I am used to mild four-strokes, but this was still way too hard to handle. There are two aspects to this issue: the control itself, and the way the engine responds to the engine. I tried everything you can do to solve this:
    13oz Steahly Flywheel weight. This didn’t really change the engine when the clutch was out. Any difference in acceleration or hit is very minimal. It really changes the feel when slipping the clutch or idiling along, but does nothing to the issue above. I’ll leave it on for stall-resistance, but good clutch control and a strong idle might be a cheaper solution for most riders. It's certainly not a "must-do" mod when converting a YZ.
    Steahly 13 oz flywheel weight:
    FMF Gnarly pipe. I needed a pipe anyway, so it was worth a shot. It did smooth out the powerband a little bit, but the stock pipe was very good on this bike. Save your money if the stock pipe is in good shape.
    It is quieter than the stock pipe, and more dent-resistant as well.
    Timing retarded by ~3 degrees. This was HUGE. I was afraid the bike would just run like crap at -3 degrees, but the stator basically works like a power-control on the YZ. I lost no low-end, and almost completely removed the hit. It’s almost EASY to ride now. I’ll dial it back and find the sweet spot between power and controllability. This is so easy, and completely free, so it's worth playing with. The best way to do this is with a dial indicator - see this thread:
    http://www.thumpertalk.com/topic/584339-yz250-timing-thread/
    I just did the math and figured out how much to move the stator in order to retard the timing. The said "screw it", made some arbitrary marks on the stator assembly, and eyeballed it. It's very easy to tap it a little bit, ride it, tap it again, ride again, etc. The absolute timing numbers mean way less than engine feel to me, so I am just going by the butt dyno on this one.
    See that blob to the top-left of the flywheel weight? That's the pickup for the ignition system. To retard the timing, loosen the bracket that's attached to. It's held on with four big #3 Phillips screws. Mine came loose without much trouble, but some people say you need an impact driver to break them free. Once it's loose (don't remove the screws), you can slide it around. Sliding the ring counter-clockwise retards the timing.
    G2 Throttle cam, and loosening the throttle cable. Extra slack in the throttle cable makes it less likely to whiskey-throttle from a closed position. The G2 cam makes the bike less responsive to small throttle inputs during the first portion of throttle-tube rotation, but then gets more and more responsive as you turn, so you reach full power at a similar rotation to stock. I've only ridden it briefly with this, so I'll report back on how it works over the next couple days. I hope that it'll reduce touchiness enough that I can dial some power back in with the timing.
    I also added a 13t front sprocket, vs. the stock 14. This made stalling less likely, and crawling easier. No photos of that, hopefully everyone knows how to swap front sprockets.
    Once the throttle was controllable, getting the suspension plush became my concern. The stock shock worked OK, but was bouncing me around a bit. The forks were awful, deflecting off everything. I ended up getting a bad, but rideable setup by cranking the fork and shock low-speed compression all the way soft, and leaving everything else alone. Other combinations were so bad as to be almost impossible for me to control. Again, I’m not a great rider, but they were BAD on trails. Between the touchy throttle and harsh suspension, I managed to whisky-throttle myself into a tree. There goes my MCL, and at least the start of my ski season. Ooops. (This was before I messed with the timing and got the throttle cam.)
  2. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
    It's suspension time!
    I used this how-to when I re-did the shock. It had been recently rebuilt, but with a faulty seal-head from Pivot Works. The dust-seal tore, and jammed itself into the main seal, which made it leak like crazy. I replaced it with an OEM KYB seal head.
    http://www.idriders.com/proflex/files/shock service.pdf
    I also re-valved the shock. Here are my original and modified shim stacks. The plan was to greatly reduce compression damping, especially in the low- and mid-low-speed ranges, to help suck up trail trash.
    I basically swapped the thin shim from the HS stack with the face shim, and pulled 5 shims from the LS stack and put them on the bottom to take up space.
    Code:
    STOCK				MODIFIED
    Compression	Float:	Clamped		Compression	Float:	Clamped
    Dia	Thick	Note		Dia	Thick	Note
    40	0.2	x11		40	0.15
    34	0.1	xover		40	0.2	x5
    30	0.1	xover		34	0.1	xover
    40	0.15			30	0.1	xover
    38	0.25			40	0.2	x1
    36	0.25			38	0.25
    34	0.25			36	0.25
    32	0.25			34	0.25
    30	0.25			32	0.25
    28	0.25			30	0.25
    24	0.25			28	0.25
    22	0.2			24	0.25
    40	4.5	washer		22	0.2
    				40	0.2	x5
    				40	4.5	washer
    Rebound	Float:	Clamped		Rebound	Float:	Clamped
    36	0.2	x6		36	0.2	x6
    28	0.1	xover		28	0.1	xover
    36	0.3			36	0.3
    34	0.3			34	0.3
    32	0.3			32	0.3
    30	0.3			30	0.3
    28	0.3			28	0.3
    26	0.3			26	0.3
    24	0.3			24	0.3
    23	0.2			23	0.2
    23	0.2			23	0.2
    26	3.1	washer		26	3.1	washer
    19	0.7	shim		19	0.7	shim
    Here is the stock valve assembly, on the shaft:
    The valve itself:
    Once I pulled the shims, I laid them out to measure them:
    Here's the modified stack:
    Assembled shock shaft, ready to go back together!
    Assembled shock valve, with the modified compression stack on the bottom:
    Now, onto the forks. The manual has a lot of detail on breaking them down, but not re-valving. I'll fill in some of the missing info.
    You don't need to separate the inner and outer tubes to revalve. If your seals and sliders are OK, forget that step. To only revalve the base valve, it goes like this:
    1) Loosen fork cap.
    2) Remove fork tube from the bike
    3) Remove fork cap with thin 17mm wrench, per the manual
    4) Remove the nut on the damper rod, and the spring and spring guide. Drain fluid.
    5) Pull cartridge and base valve apart and out with special tool
    6) Remove base valve nut - it's aluminum, so you don't really need to file off the peened end, but running a tap over it after you pull the nut is a good idea.
    7) Pull the shim stack apart, re-arrange, and put it back on the base valve.
    Then follow the manual to fill the fork fluid and put it back on the bike.
    KYB 46mm cartridge removal involves a special tool that fits that aluminum X on the end of the cartidge. You can make one and get to the base valve with a home-made PVC or metal tool - just get a piece of pipe and cut slots in the end.
    To break into the cartridge and access the rebound and mid-valve, you really should have the special tool. It requires a ton of force.
    1) Clamp it into a vice. I made a tool with a 2x4. Drill out the hole with a hole saw the same size as the cartridge, then slice it apart.
    2) Drill out the detents in the cartridge tube
    3) Use a torch to heat the end with the seal assembly to kill the loctite.
    4) Twist it out with the special tool.
    I ended up not messing with the valving on the piston, and I suspect most people can leave it alone and be happy. The compression has a ton (1.25mm) of float, so it's not too important and lower speeds. Rebound should be good unless you changed springs. This will save you a bunch of work.
    Base valve out:
    Base valve apart:
    Shim stack removed:
    Shim stack apart:
    Base valve ready to reassemble:
    Clamping the fork in a vice to fill the fluid:
    Here's the stock piston valving, which I ended up leaving alone:
    Code:
    Mid Reb	Float	Clamped
    Dia	Thick	Note
    27	0.1	x4
    12	0.1	xover
    20	0.1
    18	0.1
    16	0.1
    14	0.1
    11	0.25	x3
    Mid Comp	Float	1.15mm
    Dia	Thick	Note
    27	0.1	x7
    25	0.1
    20	0.1
    16	0.1
    14	0.3
    14	0.3
    25	0.4
    And here's the stock and modifed base valve:
    Code:
    STOCK				Modified
    Base Valve	Float	Clamped		Base Valve	Float	Clamped
    24	0.1	x10		24	0.1	x5
    22	0.15			16	0.15	from the HS stack
    20	0.15			22	0.15
    18	0.15			18	0.15
    16	0.15			14	0.15
    14	0.15			13	0.15
    13	0.15			12	0.15
    12	0.15			11	0.3
    11	0.3			18	0.5	x3
    18	0.5	x3		24	0.1	x6
    24	0.1			20	0.15
  3. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
    This bike was a bit neglected, and I needed to tear into the linkage, as all the bearings were shot. Removing the pivot link bolt that goes through the swingarm was awful - it was completely rusted to the bushing sleeve. It took a couple days of torching it, spraying it with penetrating oil, and smashing it with a hammer. Once things were apart and cleaned up, it was time to get down to business!
    Pressing first bearing:
    Pressing in second bearing - note the plastic filling the hole. I always jam something in there to prevent from losing a needle. They are usually just held in with grease.
    One was to get the right spacing from the end of the link is to use washers or shims of the proper thickness under the bushing. Then you just press down until it hits.
    5mm worth of washers:
    Or, mark the depth of the bearing on the socket with tape:[​IMG]
    Don't press on the outside of the swingarm, it'll flex the arm in. Generally, swingarm bearings are a pretty easy press, so you won't damage the swingarm, but it'll flex enough that it's tough to keep things square. A 1/2" ratchet extension is a great way to access the lower side once you have bearings in place.
    Pressing the connecting link bearings in:
    Lubricating the bearings with the good stuff:[​IMG]
    In general, bearing depth isn't super-critical. But I'm anal. [​IMG]
    Ok, sometimes you CAN press on the outside of the swingarm. My biggest impact socket just so happens to be a perfect fit for the gap in the center, to prevent flex or deformation.
    The bearings on the outside of the swingarm have thrust washers that go over them, so they can be pressed flush with the face of the recessed hole.[​IMG]
    I just pressed them in with a large washer, so that when it bottomed on the face of the hole, I was done.
    Thrust bearings:
    Polishing a horribly rusty linkage bolt.
    Forks back on!
    Swingarm back on!
    It looks like a bike again! Bonus points if you can spot what's missing:
    After a quick test-ride:
  4. EastBoundAndDown
    EastBoundAndDown Ron - 300XC-W DR650 T1050SE
    Aug 22, 2010
    2,932
    Outskirts of Gwinnett, GA
    Killer!
    I decked out an 03 RM250 for woods years ago. It was great once the suspension was revalved. Handled nimbly and always power on tap.
  5. brucifer
    brucifer Long timer
    Nov 27, 2007
    3,314
    Eureka, Ca.
    Excellent! Nice write-up and pictorial. :thumb
  6. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
    Well, I just got a nice hour-long ride in. It's still way too much bike for my novice skills, but it has no evil habits for woods riding anymore. The new suspension valving works very well - it feels quite similar to my WRR, just a bit stiffer. There's no more deflection, though. I got bounced a couple times, so I might need to dial up the rebound, but it was hard to say. There's so much to get used to with this bike that I don't notice subtle changes very easily.
    The G2 throttle cam and a little extra slack in the cable got rid of all the touchiness. It was actually a little flat, so I dialed the timing back a degree. I'm having a little trouble popping the front tire up without accelerating too fast - the pilot screw seems OK, but that might be part of the issue. It might just be me needing to use the clutch on that stuff, when I'm used to just cranking the throttle on the four-stroke. It's 20 degrees right now and riding in cold, low-traction conditions is so different than the summer that I'm not going to worry about fine-tuning the engine or suspension, yet.
    Here's one of my favorite spots to ride. It's all open woods, where I can just putt around popping off rocks and logs, or string together a 2nd-gear shot through the trees.
    mrsdnf likes this.
  7. vandiesel
    vandiesel Adventurer
    Apr 22, 2014
    20
    What a great write up. Thanks for taking all that time to share.
    Sent from my iPad using Tapatalk
  8. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
    I did some riding with the G2 throttle cam. It's awesome. As the weather had gotten a lot colder, I needed to tweak my air screw before the bike had good throttle response. Once I did that, the bike was responsive, yet controllable. I backed the timing to within 1 degree of stock, as I don't need to kill the hit so badly with the throttle cam.
    In summary, here's my recipie for a YZ trail bike:
    Buy a stock, steel-framed YZ.
    Re-valve per my specs above ($50 for tools and oil).
    G2 throttle cam ($60)
    If you're feeling spendy, and ride real slow stuff, add a flywheel weight and lower gearing ($120-200).
    That's all it needs! Well, unless you buy a $1000 bike that needs tires, chain, sprockets, bearings, rings...
    #8
  9. BIG ED XT FAN
    BIG ED XT FAN Long timer
    Feb 18, 2006
    1,261
    Finger Lakes Western New York
    Thanks for the write-up. I am going to redo my forks and shock on my WR400f! :eek1
    #9
  10. Barnman
    Barnman Been here awhile
    Oct 6, 2010
    281
    'up north England
    Great write up
    Do you know if it is possible to remove the compression adjustment needle from the base valve? Mine has started leaking from the adjustment screw, so I am guessing an o ring has failed. However it looks like the adjustment screw and needle are pressed into the base valve.
    #10
  11. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
    Sorry, I didn't mess with it. You might try the tech forums over at Thumper Talk - they know this stuff better.
    #11
  12. Barnman
    Oct 6, 2010
    281
    'up north England
    Thanks for the reply
    For the record, it is pressed in, although it is possible to use a lathe and just trim the punch points off from the bottom and then push it out to get to the seals.
    #12
  13. Auto-X Fil
    Feb 17, 2013
    894
    Montrose, PA.
    That's very good to know, thanks for the update. Base valve assemblies are expensive!
    #13
  14. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    38,623
    Pittsburgh PA
    Looks like Yamaha saw your build and decided to copy it. :ear It is nice to see the Japanese investing a little in two stroke.
    #14
  15. EnduroAmerica
    EnduroAmerica YouTube.com/enduroamerica
    Feb 22, 2012
    817
    EARTH
    Awesome writeup! I am currently building a '' works'' 1995 Yz250 for desert racing. Still debating if it was a good idea but I'm committed at this point. I've gone through everything, literally everything, on the bike and am waiting to put on the rest of the goodies that have been sitting in boxes cluttering up the garage, skid plate, flywheel weight, pipe guard, hand guards, radiator guards, tubliss and new maxxis desert It's. Could definitely have bought a new bike for what I have in it but it's been a fun build. Sometimes that's really what they are all about, just having fun. Cool to see someone else who is passionate about these older 2 strokes. I've always loved them. Traveling now but this is an old photo of the main work I have done to it. My buddies can't believe it is 20+ years old! IMG_1864.JPG
    #15
    petew likes this.
  16. SloBlue
    SloBlue Plugger
    Oct 25, 2009
    36
    Berthoud, CO
    Hey, thanks for taking the time to put all of your work on ADV Rider for us to see. I enjoyed seeing someone else who likes the YZ's. I bought a 2003 in August to ride at the MX track while my kids ride their road racers around the paved track at IMI Motorsport Complex in Dacono, CO. I too have gone through mine front to back. It's almost like new and a lot cheaper!
    #16
    EnduroAmerica and Rogue_Ryder like this.
  17. sbk750
    sbk750 Adventurer
    Oct 28, 2017
    17
    Romania
    nice work man , maybe u can help me a little , do u have idea if cylinder are the same on the 2001 model to 2007 lets say , in the future i will buy a brand new cylinder from US and it write it fits 2003 + , nothing from 2001 .... , it locks the same ...
    #17
  18. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,283
    Denmark
    Do a partsnumber search. Google "yz250 2001 parts fiche" and do the same for the 2007 model, and see if the number for the cylinder is the same.
    #18
  19. turbo_bird
    turbo_bird I'd rather be riding.
    May 14, 2007
    419
    Kamloops, BC, Canada
    Old thread, but what the hell. I've been thinking the last year or 2 that I need a lightweight two-stroke woods bike instead of trying to ride technical singletrack on my xr650r. I eventually decided on a 2006+ yz250, and kept my eyes open for a deal. Just recently bought a 2007 for $2200 in Canada, so pretty cheap. Has anyone here played with revalving the newer stuff for woods riding? I'm cheap and hate paying someone else to do stuff I can do at home, but might end up having to send the suspension out.
    Kristian
    #19
  20. dakarchef
    dakarchef Been here awhile
    May 1, 2008
    611
    I set up an 01 Yz250 for the woods. Converted to 07sss front and back. I ended up having the forks done. Best money spent. I think I would be having it done for what you have in the bike. My rear was off a 250f and the rear shock is very good. Front is brilliant now.
    Lined up at a race on my 18 year old bike. Flag dropped and my bike wouldn’t start. Got off the line dead last when the bike finally lit. Put my head down and won my class. I really believe these bikes can be made to work as well as any new bike.
    I would really love e start though. My 56 year old short inseam struggles a bit.
    #20
