Yz250x
Discussion in '2 smokers' started by Bump Stop, Jun 4, 2015.
  1. Bump Stop
    Bump Stop 2 Wheeled Drifter
    Aug 17, 2009
    8,371
    finding Jesus
    New woods 2 stroke from Yamaha! Basically a Mxer with wide ratio, kick stand, and timing/porting changes.
  2. Rot Box
    Rot Box Been here awhile
    Oct 31, 2010
    393
    Cape Coral, FL
  3. offroadtoys
    offroadtoys Been here awhile Supporter
    Feb 14, 2013
    351
    Oak Harbor, OH
    Looks great, but where's the light (or at least the lighting coil)?
  4. Bump Stop
    Aug 17, 2009
    8,371
    finding Jesus
    I was thinking the same. Then I could install one on my 05!
  5. jimroid
    jimroid Long timer
    May 14, 2013
    1,234
    Pisgah Forest,N.C./USA
    I thought the same thing about the lighting. Nice having the wide ratio,but I thought a 6 speed might be nicer. Glad to see this bike though.:clap
  6. Yard Sale
    Yard Sale let's be bad guys
    Jan 17, 2008
    4,702
    Northern Nevada
    Nice try but I'll be holding on to my 2006 YZ250 with large tank, 18" wheel, and milled head.
    They should have at least done a 3 gallon tank for hare scramblers and trail riders.
    But good on them for addressing the one thing the aftermarket hasn't, and which is too much hassle for the rest of us, a WR tranny.
  7. Bump Stop
    Aug 17, 2009
    8,371
    finding Jesus
    A six speed would be a case change I would think? I don't think the wr trans should be a problem with the adjusted torque curve. I did a 5th gear swap in mine to have a taller road gear, I rarely see 5th on the stuff I ride. Maybe we'll see a factory 300 kit?!:evil
  8. adam728
    adam728 Long timer
    Dec 1, 2014
    2,488
    Michigan
    Yamaha already has the Athena 300 cc kit in their accessories catalog online.
    I'm glad Yamaha is finally putting out a bike like this. Sure are a LOT of haters already though for it not being setup exactly how they want. Its a step in the right direction guys!
    #8
  9. Bump Stop
    Aug 17, 2009
    8,371
    finding Jesus
    not having a larger tank from the factory is a sin.:deal
    #9
  10. slideways
    slideways EspaƱa
    Mar 1, 2003
    14,360
    Spain
    Plus 1
    I still believe that the 06 on YZ's are the best suspended bikes out there. I loved my 09 250 XCW but could never get the suspension tuned to the level of the SSS suspension on the Yamaha.
    #10
  11. Yard Sale
    Jan 17, 2008
    4,702
    Northern Nevada
    Because it's a two-stroke with an exhaust power valve. No. The compression ratio is irrelevant. It's the same engine Yamaha has been using since 1999, with some tuning tweaks.
    #11
  12. avc8130
    avc8130 Long timer
    Nov 14, 2008
    1,702
    Northern NJ
    "All-New" :rofl
    #12
  13. adam728
    adam728 Long timer
    Dec 1, 2014
    2,488
    Michigan
    Piston can't compress anything until the exhaust port is closed. So when the power valve is down theoretical compression is higher than at high speeds when the valve is open.
    Same way 4 stroke guys often look at dynamic compression, that is, after the intake valve closes. One parameter in the list of variables of why a short duration cam might cause detonation on a 10:1 engine where a longer duration cam might run that same engine fine even with 12.5:1 compression.
    #13
  14. Bump Stop
    Aug 17, 2009
    8,371
    finding Jesus
    If it ain't broke.:deal
    #14
    Ebayru likes this.
  15. EEKAMOUSE
    EEKAMOUSE Been here awhile
    Oct 6, 2012
    400
    PA
    Should be same frame right all existing yz parts will fit im assuming at least i hope will make outfutting very cheap
    #15
  16. FreeRiders
    FreeRiders n00b
    Feb 7, 2014
    5
    Front Range Rockies
    I've got this on my radar...can you pwr a led headlight with the stock stator?
    #16
  17. Bump Stop
    Aug 17, 2009
    8,371
    finding Jesus
    Just run a small battery and recharge it. Not sure but I think it produces AC so you'd need to convert it to DC and get it lowered enough to not fry the LEDs.
    #17
  18. FreeRiders
    FreeRiders n00b
    Feb 7, 2014
    5
    Front Range Rockies
    Thanks Bump Stop.
    I did buy this bike and I'm in the process of doing just that...using battery pak and led light setup. That's way cheaper than a new stator. I bought a high powered batt pak and charger for $40 off amazon. Stator $179
    #18
    Bump Stop likes this.
  19. Bump Stop
    Aug 17, 2009
    8,371
    finding Jesus
    Post up the part numbers/suppliers and pictures when you're done so I can copy you!:D
    #19
    FreeRiders likes this.
