Zero Motorcycles
Discussion in 'Electric Motorcycles' started by T.S.Zarathustra, Jun 27, 2018.
  1. Lidja
    Lidja --- Supporter
    Jul 29, 2014
    1,018
    Salt Lake City
    A generator inside a trailer is always a bad idea—it’s usually loaded into the truck bed of the tow vehicle or in an exterior storage space on the trailer.
  2. liberpolly
    liberpolly Nu, shoyn, nudnick!
    Sep 21, 2015
    5,284
    Seattle
    Another thing I don't understand - a car is already a generator. Just put a small power converter in it.
  3. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    2,739
    Ventura, CA
    Most car alternators are less than 150w. At 12v, that's only about 10 amps max 12v.. with the engine 'off idle'. At idle, it's about 1/2 that. To use an inverter to 110v ac you're looking at a couple amps. So, you'll be running a whole engine for a very long time to charge very little. Most of the current generators, like the Honda EV, are 'inverter' type generators and will run all day with about a gallon of gas and at 2000w, is putting out near 18 amps.
  4. liberpolly
    Sep 21, 2015
    5,284
    Seattle
    I dunno, my Jeep's stock alternator is rated at 160 amp, which at 13 v produces 2000 watt. Are you sure you are not confusing watts and amperes?
  5. Todd157k
    Aug 14, 2012
    2,739
    Ventura, CA
    oops.. ya, sorry. Was writing that from the Dr. office yesterday. I really should take my meds BEFORE reading chit.
    None the less, even though I confused the issue, your car still has to be off idle to get up that current. Much cheaper to run a genny all day.
  6. NoMoreIdeas
    NoMoreIdeas Adventurer
    Jan 31, 2018
    73
    Olathe ks
    Also if your near a campsite, 50 amp 220 service can charge an EV bike pretty quickly.
    voltsxamps likes this.
  7. liberpolly
    Sep 21, 2015
    5,284
    Seattle
    How is it cheaper? Car engines are usually more efficient than generator's, so same amount of gasoline will produce more electricity, or same amount of electricity will be produced with less gasoline. The ECU will send more gasoline to the engine when electric load goes up.
  8. Todd157k
    Aug 14, 2012
    2,739
    Ventura, CA
    cuz running one small cylinder is far less than running 6 or 8 large cylinders. :y0!
    voltsxamps and MJSfoto1956 like this.
  9. jas67
    jas67 Long timer
    Oct 13, 2011
    2,322
    Pennsylvania
    Yep.
    The pumping losses alone to idle a car engine are more than what a small single cylinder engine uses at full power, especially one like the 100cc Honda inverter generator.
  10. NoMoreIdeas
    Jan 31, 2018
    73
    Olathe ks
    There was a guy running a Zero FXS at the track and charging on a gas generator, after all was said and done he still got 60mpg.
    Vegas800XC, wheresbaoskee and Lutz like this.
  11. futureborder
    futureborder Been here awhile
    Jul 5, 2019
    374
    Italy
    They are definitely not. Not even half as efficient. The efficiency numbers typically given for modern car engines are only at max power, with the throttle fully open. In ordinary daily use you may get between 10% and 15% efficiency out of a normal gasoline engine. A generator engine that is 100% optimized for a super narrow RPM and load range can easily get 30-40%.
  12. liberpolly
    Sep 21, 2015
    5,284
    Seattle
    See figure 1: https://www.energy.gov/sites/prod/files/2014/04/f15/10097517.pdf
  13. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,134
    Portugal
  14. T.S.Zarathustra
    T.S.Zarathustra Been here awhile
    Apr 26, 2018
    384
    Noord Holland
    Monkeyshines and Vegas800XC like this.
  15. MJSfoto1956
    MJSfoto1956 Been here awhile
    May 12, 2017
    488
    Boston, MA
    gonna need DOT reflectors on those outboard side panniers -- BMW got caught with that and it wasn't pretty.
  16. m0t0-ryder
    m0t0-ryder RYD
    Feb 15, 2003
    515
    Bay Area, California
    I was suggesting and requesting full fairing (or at least improved air management) the whole time I worked at Zero.
    Took them awhile but hopefully they will "get it" and make it.
    I'd also suggested a SM (supermoto) version of the FX back then.
    elmontanero and Andrew like this.
  17. WagonWillie
    WagonWillie Been here awhile
    Nov 3, 2015
    185
    California
    m0t0-ryder: I'm glad to hear that there are people pushing the management at Zero for those kinds of upgrades. I'm sure that they have a full plate already, but better aerodynamics offers many benefits and I'm glad to see that they appear to be working on it. I love my SR and it's actually pretty smooth to ride because I'm in clean air most of the time. I moved the mirrors down to the bar ends and that helped quite a bit. I just wish that it had the IMU of the SR/F because all that "instant" torque does try and bite you occasionally. I haven't ever put it down, but I respect it a lot especially on cold tires.
  18. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    8,174
    NH
    Does anyone know if the SR/F's custom mode would allow for Sport mode with full regen braking?
  19. Jarrett2
    Jarrett2 Been here awhile
    Apr 11, 2018
    391
    DFW
    It will.
    That said, it doesn't make a lot of difference in stopping power nor battery consumption.
  20. hamiamham
    hamiamham Been here awhile
    Jun 6, 2010
    660
    I was in my local (NYC) Zero dealer yesterday checking out what he had on offer. I can see the appeal; the performance, the lack of maintenance, etc. One thing I wanted to ask is if you guys miss the shifting, the noise, etc of ic bikes? Or does the instant torque of electric make you forget all that ..lol
