    Dismiss Notice
Zero valve clearance ?!
Discussion in 'The Garage' started by Uncle Ernie, Mar 2, 2009.
  1. Uncle Ernie
    Uncle Ernie Long timer
    Jul 3, 2007
    3,964
    Asheville NC
    Royal Enfield says to set the valves with NO clearance. They say as long as the valve lifters turn (spin) without any up & down play, you're good to go.
    This goes against everything I know. It's a set-up not entiorely different from a BMW single. They say the valves loosen up as the engine gets hot. I'm really want to put a guage between the rocker end and the valve. I'm twitching.
    Am I nuts?
  2. JohnTM
    JohnTM Who's my daddy? Supporter
    Oct 20, 2001
    29,259
    Cornersville, TN
    Nuts? Well, maybe...:lol3
    But it isn't impossible that they use zero clearance. Vincents do too.
  3. VonHelm
    VonHelm corona ring
    Oct 12, 2007
    6,141
    Grapevine, TX
  4. JPSpen
    JPSpen At Large
    Sep 3, 2007
    1,186
    Keeping up with the Joneses, OK ?
    Take a ride, check the valves while it's still hot...
    Then you'll know...............wait for it................
    The Rest of the Story..
    RIP PH
    John
  5. AzB
    AzB Fattest thin man
    Jul 2, 2008
    4,821
    Directly above the center of the Earth
    Do they have hydraulic lifters?
    Az
  6. Mista Vern
    Mista Vern Knows All - Tells Some.
    Dec 1, 2005
    23,984
    McMinnville, Oregon
    Older HDs ran zero clearance also. You can go to Old School and ask, as a number of folks have REs there.
  7. Uncle Ernie
    Jul 3, 2007
    3,964
    Asheville NC
    I guess this old dog needs to learn a new trick.
    As described, the procedure seems so amorphous- like throwing the rocker up against the side of a barn. If it bounces once, you're good to go. I spent a long time learning just the right tug on a feeler guage on my Beemers.
    I'll do it- but it's scary.
  8. GreaseMonkey
    GreaseMonkey Preshrunk & Cottony
    Jun 16, 2006
    5,952
    The only county in Illinois with no train tracks
    It really depends on the physical design of the engine. Since everything heats up and expands differently the clearance can change by getting bigger, smaller, or possibly be designed that it all expands at the same rate. Just depends on how the engineers planned it.
    #8
  9. Uncle Ernie
    Jul 3, 2007
    3,964
    Asheville NC
    I think these engines are made by using lava flows for molds. This process hasn't changed in millions of years.
    3 nuts in there to screw with. Damn- what do they do...? BMW's are so easy.
    #9
  10. Mista Vern
    Dec 1, 2005
    23,984
    McMinnville, Oregon
    :lol3 Now I gotta get one of these just to see what the hell you are talking about!
    #10
  11. Mista Vern
    Dec 1, 2005
    23,984
    McMinnville, Oregon
    Good stuff GJ - keep the cool info coming!
    #11
  12. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    55,990
    San Rafael, Marin County
    Do what, now? The Vincent has a two guides for each valve which reduces the side load and guide wear. The rocker arm is in between the guides.
    #12
  13. JohnTM
    Oct 20, 2001
    29,259
    Cornersville, TN
    As for the construction, you're both saying the same thing.
    The purpose of the design is to place the spring above the rocker. There is still only one guide (ET41 in the parts list) but the shorter effective length of the valve does provide for less expansion effect from heating. Keeping the pushrod short by having the cam high up in the timing case combined with the short valve stem and the angle the pushrod sits at in relation to the barrel makes everything expand at approximately the same rate. Thus, zero-clearance adjustments.
    #13
  14. JohnTM
    Oct 20, 2001
    29,259
    Cornersville, TN
    I still don't see the second valve guide. :scratch
    And the higher RPMs are handled by the optional third spring on the valve to help eliminate float.
    #14
  15. JohnTM
    Oct 20, 2001
    29,259
    Cornersville, TN
    If you'll bother to read my earlier post about the short pushrods and the angle they sit at in relation to the barrel, you'll see that I don't think it was pointless - much the reverse - it is an ingenious design.
    But as for the two guides, I'll trust my own experience and the parts diagram over the opinion of a magazine writer any day. You're quoting bad info. What the writer is referring to as the top guide is actually the lower spring keeper which does act somewhat as a guide, but no more so than in any other engine.
    #15
  16. JohnTM
    Oct 20, 2001
    29,259
    Cornersville, TN
    At the last Vincent rally we held in North Carolina, a gentelman arrived toting a big binder filled with all sorts of Vincent memorabilia, fact sheets, magazine articles, and even sung "Vincent Black Lightning". Although he had never owned or ridden a Vincent, he was an expert! Or so he seemed to think...
    #16
  17. bwallca
    bwallca Been here awhile
    Aug 4, 2007
    221
    Edmonton, Alberta Canada
    Back to the original question. Some old British singles had zero valve clearance, Matchless/AJS for sure. These engines have a lot in common with the RE, designed shortly after they invented dirt. On the plus side you no longer need a feeler gauge, just do it.
    Ben
    #17
  18. Anorak
    Jul 23, 2004
    55,990
    I knew that would drag you in. I got the explanation from a story Kevin Cameron did about Vance and Hines Prostock Harley engine. He compared it to The Vincent in that they both used high mounted cams to minimize the length of the push rods. Anyhow beyond that I will definitely defer to your expertise. Wanna sell me a Vincent. I'll trade you an autographed Arai helmet worn by Don Angel in Max Lambkey's streamliner at 212.98 mph.
    #18
  19. JohnTM
    Oct 20, 2001
    29,259
    Cornersville, TN
    Sadly I'm down to two Vinnies in the shed right now. :cry Can't spare one. :lol3
    #19
