Zeta Universal 7/8" Handlebar Offset Mounts on f650gs?
Discussion in 'Parallel Universe' started by leungevity, Apr 3, 2018.
  1. leungevity
    leungevity Adventurer
    Aug 3, 2017
    21
    hi, i don't have a lot of specific information about my bike (2011 f650gs twin), but i think this would work and not cause me to have to get new cables or wires. can anybody please confirm or deny that it will mount correctly?
    https://www.partsgiant.com/p348068-zeta-universal-7-8-handlebar-offset-mounts
    they are 20mm offset, 26mm rise, 7/8 handle bar, i'm not sure what this means:
    • Bar clamp width in between 32 mm to 35
    Mike
  2. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,201
    Lanark County near Ottawa ON
    They won't work. The space between the bolts is too small. If you measure the distance on your bike you will see what I mean.
    Sent from my SM-T530NU using Tapatalk
  3. leungevity
    Aug 3, 2017
    21
    thanks for your response... boo for not fitting :( seemed like the right solution for me.
  4. bmwroadsterca
    Jan 3, 2007
    1,201
    You can find other choices that have the correct 39mm (I am pretty sure that is the right dimension) bolt spacing.
  5. malloy
    malloy Long timer Super Supporter
    Sep 25, 2006
    6,388
    SOUTH OF THE BORDER
    ROX Risers - 20mm high should do it. Search
